zeds4ever Posted October 9, 2017 Share Posted October 9, 2017 The thermostat control unit that I have been using in the past has failed . Want to use a different set up , any suggestions other than a switch system would be appreciated . Regards : Alan Quote Link to comment Share on other sites More sharing options...
KatoKid Posted October 9, 2017 Share Posted October 9, 2017 I'm using Davies Craig, so far so good http://www.supercheapauto.com.au/Product/Davies-Craig-Digital-Thermatic-Fan-Switch/374278?utm_source=shop_search&utm_medium=search_results&utm_campaign=g_shopping&gclid=Cj0KCQjwvOzOBRDGARIsAICjxodYw5ZjfpzJtOghGkZ2V-esEHb2Y1t9bPohZjGpzgwXJ7o0OtjKxHwaAqAeEALw_wcB Quote Link to comment Share on other sites More sharing options...
zeds4ever Posted October 9, 2017 Author Share Posted October 9, 2017 Thanks Kato . Noticed that there is a spare port in the 280ZX Thermostat housing which is blanked off , thinking of drilling blanking plate out & installing a lower rated sender in the port which will be hooked up to the earth set up on the fan . This should allow the motor to warm up without fan functioning until the Sender closes & then activates the fan in turn , as the active will be a solid connection . Wonder if Is this will be OK ?. Regards : Alan . Quote Link to comment Share on other sites More sharing options...
RLY240 Posted October 9, 2017 Share Posted October 9, 2017 Thanks Kato . Noticed that there is a spare port in the 280ZX Thermostat housing which is blanked off , thinking of drilling blanking plate out & installing a lower rated sender in the port which will be hooked up to the earth set up on the fan . This should allow the motor to warm up without fan functioning until the Sender closes & then activates the fan in turn , as the active will be a solid connection . Wonder if Is this will be OK ?. Regards : Alan . This will work if you use a fan control sender but you'll still need a relay to drive the fan and switch the relay with the sender. You can get fan control senders in various temp ranges, they usually have a small hysteresis window so they switch on at say 90 and then switch off again at 85. I'm using a generic BMW sender from eBay I think that mounts in the L28 thermostat housing. Roger Quote Link to comment Share on other sites More sharing options...
zeds4ever Posted October 9, 2017 Author Share Posted October 9, 2017 Thanks for your input Roger. Regards : Alan . Quote Link to comment Share on other sites More sharing options...
Yamahacam Posted October 9, 2017 Share Posted October 9, 2017 I removed the thermo vacuum switch from my thermo housing which has thread pitch of 16x1.5? Had a thermo switch at work from a Hyosung GT650R. On at 90ish off 85ish. Seems to work well at that temp. The one I was supplied with my thermos fan kit was too low and the fan would come on even when I was cruising along. Quote Link to comment Share on other sites More sharing options...
KatoKid Posted October 9, 2017 Share Posted October 9, 2017 Davies Craig is fully adjustable for cut in temp and also stages the fans if you operate two. Very cool. Yamahacam 1 Quote Link to comment Share on other sites More sharing options...
peter t Posted December 2, 2017 Share Posted December 2, 2017 I have got a on off thermos switch in line in the top rad hose. About the only time the fans turn on is after I have stopped. The big kick arse chinese radiator keeps it running cool. Page 18 of my build thread. Fans are run through a relay I have the craig davis switches that come with the fans if you want them. Quote Link to comment Share on other sites More sharing options...
