260DET Posted January 15, 2017 Share Posted January 15, 2017 Custom fuel cell for the project Z, silicone is available in various diameters, proper fuel hose not so. Am thinking of general purpose silicone hose like is used for radiator and intake hoses. Quote Link to comment Share on other sites More sharing options...
Moderators PB260Z Posted January 15, 2017 Moderators Share Posted January 15, 2017 Hi, No not a good idea. To the best of my knowledge petrol will slowly disolve the silicon. Cheers PB Paul_S 1 Quote Link to comment Share on other sites More sharing options...
Paul_S Posted January 15, 2017 Share Posted January 15, 2017 I agree. It will be OK for a time but will cause you problems in the long run. Quote Link to comment Share on other sites More sharing options...
260DET Posted January 15, 2017 Author Share Posted January 15, 2017 Thanks blokes, looks like a trawl through the wreckers will be necessary. Quote Link to comment Share on other sites More sharing options...
Moderators PB260Z Posted January 16, 2017 Moderators Share Posted January 16, 2017 Hi Rather then spend ages crawling through wrecks looking for the right hose maybe try this, it worked for me on a previous project. - Grab the longest piece of filler hose (with the correct ID) that you can find. - Get some appropriately sized stainless exhaust pipe (get it bent to shape) - A few hose clamps. - Use the hose at each end and the exhaust pipe in the middle Just a thought Quote Link to comment Share on other sites More sharing options...
chartoo Posted January 16, 2017 Share Posted January 16, 2017 I remember being able to get 2 inch hose from enzed or some industrial places. Just typed it into google http://www.dayco.com.au/products.aspx?G=16002217&P=16027764 Remember it was about $50 a meter Quote Link to comment Share on other sites More sharing options...
nizm0zed Posted January 16, 2017 Share Posted January 16, 2017 our local industrial supplies joint has silicone hose in pretty much any size you needed, We used to use it between the fuel tanks, its rated for diesel and petrol.Im not sure who would be local to you, but a quick look at google would probably tell you.Definitely cant use the 'retail' blue or black type of hose normally used on intakes, the silicone breaks down in the fuel and the particles clog up your filter and pump.http://www.southernhose.com.au/ Quote Link to comment Share on other sites More sharing options...
