Kent Posted December 19, 2016 Share Posted December 19, 2016 Hi Guys, i am looking to install a set of 40DCOE webers along with a carter rotary pump (and FPR) on my series 1 240Z (with the original L24). Does anyone know where in australia (or online) i can buy a blanking plate to cover the hole left when i remove the mechanical fuel pump? Thanks Kent Quote Link to comment Share on other sites More sharing options...
Zedhead70 Posted December 19, 2016 Share Posted December 19, 2016 I got hold of some 6mm aluminium plate from the local hardware store and using the gasket as a template made up a blanking plate when I installed the Carter Rotary pump (about 20 yrs ago). I think I have since seen them on ebay and such places. From memory the aluminium plate was about 300 x 200mm in size and can be used for fabricating other bits and pieces. Hope that helps. Regards Craig Quote Link to comment Share on other sites More sharing options...
Zedhead70 Posted December 19, 2016 Share Posted December 19, 2016 2 min google search found this, http://www.thezstore.com/page/TZS/PROD/10-2081 andyk_79 1 Quote Link to comment Share on other sites More sharing options...
Brabham Posted December 19, 2016 Share Posted December 19, 2016 I think US ebay has some too. Quote Link to comment Share on other sites More sharing options...
Kent Posted December 19, 2016 Author Share Posted December 19, 2016 Thanks guys, but i was looking for a local source in Australia to get around the ludicrous shipping prices for a small bit of metal I unfortunately don't have the tools to make one up myself and the cost in labour to do so would likely be more than buying from the US If push comes to shove i will get it from the US Quote Link to comment Share on other sites More sharing options...
CBR Jeff Posted December 19, 2016 Share Posted December 19, 2016 Give Les at LCR a ring. I'm sure he will have a supply of them. Then you just need to see if Australia post delivers it! Jeff Quote Link to comment Share on other sites More sharing options...
GongZ Posted December 19, 2016 Share Posted December 19, 2016 Hi Kent - this is off-topic - but the link to your website isn't working. Quote Link to comment Share on other sites More sharing options...
Kent Posted December 21, 2016 Author Share Posted December 21, 2016 Thanks Jeff, i will give Les a call. GongZ.. unfortunately i am half way through switching hosting companies it will be up soon GongZ 1 Quote Link to comment Share on other sites More sharing options...
dat2kman Posted December 21, 2016 Share Posted December 21, 2016 (edited) Got a few OEM ones, can pack and post, from Brisbane. Got a brand new Carter Red too, suit Webers! Edited December 21, 2016 by dat2kman Quote Link to comment Share on other sites More sharing options...
d3c0y Posted December 22, 2016 Share Posted December 22, 2016 Hey Kent, We make them and are located in Brisbane if you want one $45 posted. Quote Link to comment Share on other sites More sharing options...
