Andrew_L26 Posted August 8, 2016 Share Posted August 8, 2016 Hi all, So I've found out my motor is an L28 with the F54 block, P90a Head and flattop pistons. Seems like an odd combination, anyone know what this combination would be good for? I'm currently giving the British SU's an overhaul and I'm wondering what kind of power I could expect to push with a good tune on them? Cheers, Andrew Quote Link to comment Share on other sites More sharing options...
pauly_adams Posted August 8, 2016 Share Posted August 8, 2016 it will be fine in both NA and turbo application, dished pistons with a P90 head will give you under 8.1.1 compression with flatops its around 8.5.1 comp from memory which is fine for both applications Quote Link to comment Share on other sites More sharing options...
d3c0y Posted August 9, 2016 Share Posted August 9, 2016 I'd be very surprised if it's a P90A - does it have hydraulic lifters? Quote Link to comment Share on other sites More sharing options...
pauly_adams Posted August 10, 2016 Share Posted August 10, 2016 p90A come out with both hydraulic an mechanical. Quote Link to comment Share on other sites More sharing options...
d3c0y Posted August 10, 2016 Share Posted August 10, 2016 There you go, I stand corrected. Quote Link to comment Share on other sites More sharing options...
Andrew_L26 Posted August 12, 2016 Author Share Posted August 12, 2016 How are you able to tell if it had hydraulic lifters and what is the better Style for what applications. Cheers, Andrew Quote Link to comment Share on other sites More sharing options...
manya3084 Posted August 13, 2016 Share Posted August 13, 2016 I'll tell you how the turbo setup works out with the same combination. Booked a week off in September to finally assembled all the bits Ive acquired. Valve train noise should be really quite if you have a hydraulic lifter setup. Take off the valve cover and you should be lacking the valve adjusters that my P90 has. Quote Link to comment Share on other sites More sharing options...
Andrew_L26 Posted August 16, 2016 Author Share Posted August 16, 2016 (edited) I'll tell you how the turbo setup works out with the same combination. Booked a week off in September to finally assembled all the bits Ive acquired. Valve train noise should be really quite if you have a hydraulic lifter setup. Take off the valve cover and you should be lacking the valve adjusters that my P90 has. I decided to take my rocker cover of to polish and take some photos. Any ideas? Edited August 16, 2016 by Andrew_L26 Quote Link to comment Share on other sites More sharing options...
d3c0y Posted August 16, 2016 Share Posted August 16, 2016 They are the regular ones. To answer your original question the P90 heads generally came with flat tops as the combustion chambers are bigger and had a lower compression ratio. It will be fine with twin SUs and will make about the same as any stock L28 depending on the condition. Quote Link to comment Share on other sites More sharing options...
manya3084 Posted August 16, 2016 Share Posted August 16, 2016 Was there actually any Australian delivered Datsun with a factory P90 head? A lot from what I've read in the last few months point to it being a Turbo only head. Quote Link to comment Share on other sites More sharing options...
dat2kman Posted August 17, 2016 Share Posted August 17, 2016 Wrong Jake, P90 headed engines are all dished piston, they were made like that, so that factory could either fit it with the turbo setu, or fit it as N/A, to meet whatever missions requirements for that country, usually USA. Used two different ECU's and two different distributors. Quote Link to comment Share on other sites More sharing options...
d3c0y Posted August 17, 2016 Share Posted August 17, 2016 (edited) I just did a quick google and that seems to be an american thing F54 with P79 head had flat tops. I thought P90/F54 was available in Patrols at some stage. Probably wrong about that too. Edited August 17, 2016 by d3c0y Quote Link to comment Share on other sites More sharing options...
Administrators gav240z Posted August 17, 2016 Administrators Share Posted August 17, 2016 Was there actually any Australian delivered Datsun with a factory P90 head? A lot from what I've read in the last few months point to it being a Turbo only head. Early 1980 Patrol's had L28s some with P90 heads. Quote Link to comment Share on other sites More sharing options...
Andrew_L26 Posted August 17, 2016 Author Share Posted August 17, 2016 (edited) I thought that the P90a head had hydraulic lifters. Did we ever get turbo L28's in Australia and if so what were their configurations. Andrew Edited August 17, 2016 by Andrew_L26 Quote Link to comment Share on other sites More sharing options...
manya3084 Posted August 17, 2016 Share Posted August 17, 2016 No Turbo for us. USA, Europe, and Japan. Although, Japan got the smaller 2.0L motor. Quote Link to comment Share on other sites More sharing options...
