Vindicare Posted June 25, 2016 Share Posted June 25, 2016 (edited) Hey guys Model: 1973 240z L28ET Location: Busselton W.A Price and Payment Conditions: I'll put $35kono on it but im not sure what to expect let me know if it's fair? Item Condition: Good Body: Rust in drivers floor and sill area, bubbles in one wheel arch, and in one door top front. Otherwise not too bad, paint is old and has chips here and there, paint is about 19 years old. Mechanical: Running good, made 302rwhp on the dyno(hyperdrive MS), havent run it down the 1/4 Registration: Registered in WA, Due to several mods it wouldn't get over the pits without changing items(wilwoods, not engineers with the L28, no handbrake, etc etc etc) Suspension/Brakes: HSD coilovers AZC knuckles AZC 4pot wilwoods front and rear(no handbrake) DATRAT CV Halfshafts R200 open diff, have a OBX center and spare 3.9? diff to come with car RT diff mount All bushes, ball joints and bearings replaced when the coilovers were put in approx 10000km Strut braces front and rear Engine: Made 302rwHP on the dyno, when tuned on the engine dyno by Les it made 450hp, Currently running 16psi, To make more will require a bigger exhaust housing., Done roughly 6000km with the engine PMC Build motor Metal head gasket from SWM Peter completed the water bypass mod to help alleviate spot boiling on 5 and 6 Ross forged pistons 87mm Spool conrods AZC sump Wolf racing intake Trust stainless turbo manifold Tial 44mm wastegate Gt35r .63 housing, HPC coated and blanket/wrapped China spec cooler 800cc bosch injectors Sard fpr Rather expensive rewire of the ecu loom all labeled Petermac dizzy to suit the Autronic 500r cdi system and m&w double coil packs Rebuild, porting, cam all done by peter Tuned by les Collins and run in on the engine dyno Bosch 044 fuel pump 3" exhaust turbo back with 2 mufflers, dump is mild steel. Turbosmart manual boost controller for 2 boost levels on toggleswitch, currently wg pressure 10psi, or 16psi Gearbox is a RB25 item(big), with a Jim Berry organic clutch single plate, new tailshaft, mounts moved to suit box, adaptor plate, Short shifter Link to engine buid thread http://www.viczcar.com/forum/topic/7763-l28t-build/ Interior: Pretty shabby, needs new carpet/ door trims, Dash is perfect, Autometer Boost guage where clock used to be, Tacho is a Speedhut item, Seats are aftermarket buckets. Has Dapperlighting HID's classic kit Contact: Pm me on here and i'll pass on my phone number. I'll get more photo's, but there plently of the engine in the build thread. I'm sure i've forgeotten stuff Comes with Matching numbers L24(has injection and turbo, so no carbs) BAMF flares Edited June 25, 2016 by Vindicare Delaynomore and Vindicare 2 Quote Link to comment Share on other sites More sharing options...
Vindicare Posted July 1, 2016 Author Share Posted July 1, 2016 Anyone have any thoughts? Quote Link to comment Share on other sites More sharing options...
Administrators gav240z Posted July 2, 2016 Administrators Share Posted July 2, 2016 On the car or price? Seems very reasonable price to me, considering work gone into it and cost to do the same. Quote Link to comment Share on other sites More sharing options...
Vindicare Posted July 2, 2016 Author Share Posted July 2, 2016 Just the motor and injection/tuning was 30k+ gav240z 1 Quote Link to comment Share on other sites More sharing options...
Delaynomore Posted November 8, 2016 Share Posted November 8, 2016 Does anyone know if this is still for sale? Quote Link to comment Share on other sites More sharing options...
ScottyD Posted November 9, 2016 Share Posted November 9, 2016 Try sending Vindicare a PM. Quote Link to comment Share on other sites More sharing options...
Delaynomore Posted November 9, 2016 Share Posted November 9, 2016 Try sending Vindicare a PM. Last online 4 months ago Quote Link to comment Share on other sites More sharing options...
Delaynomore Posted November 10, 2016 Share Posted November 10, 2016 Cars not for sale anymore incase anyones wondering, contacted Aaron today via Sms! Quote Link to comment Share on other sites More sharing options...
