aircobra Posted November 29, 2015 Share Posted November 29, 2015 Unfortunately as was so keen to rip the seats apart that I didn't take any photos. So after looking thru a couple of posts, have a few questions 1. Where to buy the 2mm foam and how much do you need? Clark's don't have anything this thin 2. Why the plastic over the headrests? Is it for ease of fitting 3. I don;t remember if the foam blocks are supposed to be glued to the seat back or not? 4. I ordered the foam from US, so want to know if the 2mm foam goes just at the back of the seat or around the entire seat? 5. Paste vs spray 6. KMart contact adhesive vs specialised automotive ( I believe its higher temp rating) Thanks in advance Quote Link to comment Share on other sites More sharing options...
Administrators gav240z Posted December 4, 2015 Administrators Share Posted December 4, 2015 4. I ordered the foam from US, so want to know if the 2mm foam goes just at the back of the seat or around the entire seat? Sorry but if you ordered the foam insert from the US why do you need more foam? I assume you bought these? http://www.thezstore.com/page/TZS/PROD/40-2691 Quote Link to comment Share on other sites More sharing options...
Linton Posted December 4, 2015 Share Posted December 4, 2015 I have these Gav, you do need to add a little foam onto the back rest just to soften it a little, they are like leaning against a wall without it, very hard.. yes the plastic is to help you get the covers on, I used cling wrap. you don't need any glue but you will need the "c" clips and the tool I got one from the garden centre at bunnings. prior to fitting put the covers out in the sun and get them hot they will stretch when nice and soft from the sun. Quote Link to comment Share on other sites More sharing options...
aircobra Posted December 4, 2015 Author Share Posted December 4, 2015 yes, i have the foam blocks, but what i'm talking about is this http://s87.photobucket.com/user/camaroguy1969/media/1972%20240z/Seat%20Rebuild/13.jpg.html the one that goes around the back rest Quote Link to comment Share on other sites More sharing options...
Zedstar Posted December 4, 2015 Share Posted December 4, 2015 Clark Rubber does sell 2mm foam . Check blue foam on seat shoulder. If your new foam mouldings are as hard as indicated by Linton I would use the thicker medium density foam to insulate as installed in my seats. Consider 2mm too thin , my seats are very comfortable. Quote Link to comment Share on other sites More sharing options...
Linton Posted December 6, 2015 Share Posted December 6, 2015 Yep that's what I did If your new foam mouldings are as hard as indicated by Linton I would use the thicker medium density foam to insulate as installed in my seats. Consider 2mm too thin , my seats are very comfortable. Quote Link to comment Share on other sites More sharing options...
aircobra Posted December 6, 2015 Author Share Posted December 6, 2015 you can see the 2 mm foam in the photo above - its used whenever vinyl bare touches bare metal eg around the back and sides Quote Link to comment Share on other sites More sharing options...
Administrators gav240z Posted December 6, 2015 Administrators Share Posted December 6, 2015 Although not exactly related this came through this morning and might be helpful? http://www.autospeed.com/cms/article.html?&A=113239 Quote Link to comment Share on other sites More sharing options...
aircobra Posted December 14, 2015 Author Share Posted December 14, 2015 dead end - i've tried dunlop foam and a couple of other places and 3mm is the thinnest. apparently there's slicing machine that slices the foam from a fat block does anyone know a source either here or o.seas? Quote Link to comment Share on other sites More sharing options...
aircobra Posted December 24, 2015 Author Share Posted December 24, 2015 found the foam - 2mm timber floor underlay from harvey norman Quote Link to comment Share on other sites More sharing options...
Moderators PB260Z Posted December 25, 2015 Moderators Share Posted December 25, 2015 found the foam - 2mm timber floor underlay from harvey norman Well Done, Perseverance does pay off Quote Link to comment Share on other sites More sharing options...
