aircobra Posted September 19, 2015 Share Posted September 19, 2015 https://www.zcarsource.com/uimages/product_photos/trans_diff/1340117.jpg what size are all the bolts pls? pitch, tensile #,etc thank you Quote Link to comment Share on other sites More sharing options...
GongZ Posted September 20, 2015 Share Posted September 20, 2015 This link might help you - http://forums.hybridz.org/index.php/topic/98751-suspension-bolts-inventory I have found the zip file attached reply #3 particularly useful - it suggests that the Diff Crossmember bolts are; 10 x 1.25 pitch 30mm long, full thread, 14mm hex head, Grade 9 with a flat and split washer Quote Link to comment Share on other sites More sharing options...
aircobra Posted September 21, 2015 Author Share Posted September 21, 2015 they have the captive washers from factory? same as the ones that bolt to the vertical brackets into the body? Quote Link to comment Share on other sites More sharing options...
