74zzz Posted August 9, 2015 Share Posted August 9, 2015 Hey guys just wondering if the rear a arms and struts are the same in 2+2 and in 2 seaters? Quote Link to comment Share on other sites More sharing options...
Moderators PB260Z Posted August 9, 2015 Moderators Share Posted August 9, 2015 Gidday Struts change have a read of this. http://www.viczcar.com/forum/index.php/topic,16368.0.html Not sure about the arms though. Quote Link to comment Share on other sites More sharing options...
gilltech Posted August 9, 2015 Share Posted August 9, 2015 Haven't noticed any difference, the A arms of a 2+2 I had here until recently looked identical to those on my 2-seater. 2+2 struts are definitely taller though, designed for a different back end able to seat additional passengers. Unless you want additional ground clearance!!! then 2+2 rear struts are only suitable for 2+2s, unless you modify them I suppose. Quote Link to comment Share on other sites More sharing options...
74zzz Posted August 9, 2015 Author Share Posted August 9, 2015 ok just found a set of control arms and struts so was thinking of buying to powdercoat and install and use the struts to section for coilovers eventually.......just saves me having to have the car in pieces while i get the work done and would allow me to just exchange all in one hit Quote Link to comment Share on other sites More sharing options...
zcar63 Posted August 10, 2015 Share Posted August 10, 2015 Rear lower arms are the same size but some have heavier construction than others duty ,i presume the heavy duty ones are off the 2+2.I found this out when making the Chromemoly ones. I had two pairs under the bench, and noticed two types of construction. Quote Link to comment Share on other sites More sharing options...
74zzz Posted August 10, 2015 Author Share Posted August 10, 2015 ok no worries how bout the struts? as they will be sectioned for coil overs the height shouldnt matter should it? Quote Link to comment Share on other sites More sharing options...
