Tim has no more Zed, so spare parts have to go UPDATED
48 replies to this topic
#1 RB30X
RB30X
  • 1,981 posts
Posted 15 January 2013 - 03:31 PM
So I'm getting rid of all the Zed stuff I've collected during the last few years of Zed ownership. I understand some of this stuff is quite common and may probably find its way into a bin. If you're interested in something just ask and I'll come up with a price for it rather than attempt to price everything here. All of this stuff has just been sitting in boxes, so its covered in dust etc.
Ok, here we have two new threaded sleeves from Otomoto with collars etc but no matching springs. Some stut tops, front castor arms, a diff bracket, one zed hub cab. Also some front coil over converted struts that I chopped the bottom off for ChevZ, with blue springs.
Posted Image
Here is some diamond print vinyl that I robbed from a 260 2+2 I think. Two rear strut top covers, two rear wheel wells, and the bit behind the seats. Could do with a clean obviously. One small rip in one of the wheel well ones.
Posted Image
Remains from a carpet kit I bought new. Looks like the two bits that run along on the outside of the front seats, two bits that go behind the front seats and the long bit across the back of the trans tunnel. Also some door linkage parts in pic.
Posted Image
Here is three sun visors, two perspex headlight covers SOLD, an electric aerial SOLD, a center console surround and vent, three headlamps and four surrounds.
Posted Image
Door linkage partsSOLD, mostly from a 2+2 but I'm sure theres some 260 2 seater parts in there. Windscreen wipersSOLD, hub caps, handbrake and leather coverSOLD, door, bonnet and hatch linkage mechanismsSOLD.
Posted Image
A 260 steering column with ignition barrel and key. Genuine original 240Z speedo and (tachoSOLD) with speedo cable, interior light and plastic bit that runs along the brake light and a choke knob linkage.
Posted Image
Thermo fan with bracket, L series coilSOLD, two hub caps, ash/coin tray and some L28 engine parts.
Posted Image
260 2+2 rear internal tail light cover, arm rests, two 2+2 stainless trims that run along the roof channel, three top of door/ base of window trims, and lots of front and rear windscreen stainless trims that slide inside the rubber seal.
Posted Image
Brand new Autometer fuel level gauge
Posted Image
Two new orange front indicator lensesSOLD, two bonnet inspection hatches with air flow ventsSOLD, a vacuum dizzy from a 2.4L, oil filter, and what is left over from a Black Dragon weather seal kit. Part numbers are below with links to black dragon ID with picture.
59-872(2), 59-877 , 59-876(2),  http://www.blackdrag...ll.aspx?Page=12
59-851(2)  http://www.blackdrag...ll.aspx?Page=13
Posted Image
240Z fuel tank. Good condition.
Rear control arms.
Front and rear sway bars.
Two zed jelly beans mags and tyres
LS1 parts. ARP head bolts, fuel rails and speedflow fittings and hoses, PAC racing springs, $200 each or all for $500.
Posted Image
Let me know.
#2 RB30X
RB30X
  • 1,981 posts
Posted 15 January 2013 - 04:24 PM
Sorry the coil over sleevs are 51mm ID for those who asked.
#3 sexual_sushi
sexual_sushi
  • 1,298 posts
Posted 15 January 2013 - 10:49 PM
Hey Tim, how much for the fuel gauge and the stainless steel trim that goes inside the windscreen/hatch rubbers?
#4 thriller
thriller
  • Donating Members
  • 398 posts
Posted 16 January 2013 - 01:59 AM
Fairly keen on electric aerial... 240z or 260z unit?? Or pretty well perfectly interchangeable?
Would need to get it boxed up for postage, and I'm away until the 25th. If you could PM me a price it'd be appreciated :)
Thanks.
#5 wildy55
wildy55
  • 428 posts
Posted 16 January 2013 - 06:02 AM
Hey Tim no Zed,
Been keen on the inspection covers. Wanna fire me a price from them?
#6 Johnboy
Johnboy
  • 219 posts
Posted 16 January 2013 - 06:32 AM
I can supply the pair of springs to go with the otomoto parts in either 5 or 6kg if needed.
John
#7 stevofoxono
stevofoxono
  • 309 posts
  • Tagline:My quarter life crisis car Z
Posted 16 January 2013 - 07:34 AM
What condition is the middle strip for the tailight?
Also I may be interested in the indicator lenses+headlight covers
cheers ^^
#8 import monky
import monky
  • 88 posts
  • Website:http://www.importmonky.com
  • Tagline:importmonky.com
Posted 16 January 2013 - 07:41 AM
Shotgun perspex heatlight covers... if youre willing to post to sydney? pm sent nonetheless :D
#9 sco_aus
sco_aus
  • 2,484 posts
  • Tagline:Scott
Posted 16 January 2013 - 08:27 AM
Do you have the clip piece that the sun visors clip into in the centre of the roof for a 260Z?
#10 pauly_adams
pauly_adams
  • 1,160 posts
Posted 16 January 2013 - 12:07 PM
whats that turbo impella from in the green box, is there any more of it
#11 RB30X
RB30X
  • 1,981 posts
Posted 16 January 2013 - 12:26 PM
Ha. I think that's from an old T3 I pulled off a VL turbo.
I will respond to everyone on here and the pms just very busy at work today.
#12 Brabham
Brabham
  • Donating Members
  • 1,056 posts
Posted 16 January 2013 - 01:08 PM
Hi Tim,
interested in 240Z tacho, handbrake lever, all the door linkage parts/catches, windscreen wipers, antenna (if other guy passes) and indicator lenses. Please pm me a price and postage to Sydney.
#13 RB30X
RB30X
  • 1,981 posts
Posted 16 January 2013 - 07:32 PM
Thanks.
It'll either be from a 260 2+2 or a 280zx. Let me know if interested and I'll test it to make sure it works.
#14 Scoota G
Scoota G
  • 4,213 posts
  • Tagline:Mark
Posted 16 January 2013 - 07:36 PM
I have one of them.
#15 RB30X
RB30X
  • 1,981 posts
Posted 16 January 2013 - 07:47 PM
You're down first for the fuel gauge.
Did you need any trim pieces in particular, I don't believe I have a full set, but I have most of them. I'd have to find a diagram to find out which pieces I do have.
#16 RB30X
RB30X
  • 1,981 posts
Posted 16 January 2013 - 07:50 PM
Hi Tim,
Your first inline for everything bar the indicator lenses, linkages and antenna. Just waiting to hear back from others about the other stuff.
#17 sco_aus
sco_aus
  • 2,484 posts
  • Tagline:Scott
Posted 16 January 2013 - 08:50 PM
I have one of them.
Are you coming to Bright?  Bring with and let me know how much.  Cheers
#18 Brabham
Brabham
  • Donating Members
  • 1,056 posts
Posted 16 January 2013 - 10:01 PM
No worries keep me posted cheers
#19 thriller
thriller
  • Donating Members
  • 398 posts
Posted 16 January 2013 - 10:53 PM
Just done some googling and ... pending price and working-ness, I'll grab the antenna :)
#20 sexual_sushi
sexual_sushi
  • 1,298 posts
Posted 17 January 2013 - 09:58 AM
Nah no pieces in particular, I know I have a few bits lying around in my dads shed in Gladstone but not sure what they are. Just hoping I can make a decent set out of the parts I have.
Just let me know how much you are thinking.
