Clutch problem L26 in 240z
8 replies to this topic
#1 Magnet
Magnet
  • 128 posts
Posted 08 January 2013 - 02:01 PM
Just hooked up my L26 hooked to my 240z flange type gearbox and it appears that the clutch/flywheel is too thin
The clutch fork hits the bellhousing before/as it starts to depress the clutch
Is there any differences between 240z/260z in the gearbox/clutch area that would give this problem?
Likely has a 260z clutch.
Very frustrating
Thanks, Ryan
#2 Magnet
Magnet
  • 128 posts
Posted 08 January 2013 - 02:21 PM
Seems there are differences, may even be 280 clutch
Does anyone know the longest thrust bearing carrier of the different models? Carrier needs to be a good 15-20mm longer to work properly
#3 pauly_adams
pauly_adams
  • 1,160 posts
Posted 08 January 2013 - 05:42 PM
from memory one is 15mm longer then the other I just cant remember which is what, you will need to order a new thrust collet and bearing to suit
#4 Zedman240®
Zedman240®
  • 5,198 posts
Posted 09 January 2013 - 09:32 AM
There are at least 4 (I know of) bearing carriers with different heights; try to find a zed wrecker or parts place that have several for you to compare your original and try to find a longer one. Bearing carriers and clutches are usually matched.
#5 Magnet
Magnet
  • 128 posts
Posted 09 January 2013 - 03:37 PM
Yeah cool, tried All Zed Parts today but he might be closed atm
I'll post any results I find
#6 satrat z
satrat z
    Member
  • PipPip
  • 27 posts
Posted 10 January 2013 - 07:15 PM
I had a similar problem with mine after fitting a new box and clutch, it was sorted by replacing the bearing carrier for a longer one. If you measure the one you have as a starting point, Stewart Wilkins Motorsport can supply them if you can't find them else where.
#7 Magnet
Magnet
  • 128 posts
Posted 17 January 2013 - 11:53 PM
Sorted. Got one 10mm long, would have been nicer if it was a bit longer but was free and works so can't complain.
#8 Daedalus-Z
Daedalus-Z
  • 33 posts
Posted 22 January 2013 - 11:26 AM
i had the same issue recently when I (apparently foolishly) used the carrier from the new gearbox instead of the old one.
I wouldn't necessarily recommend it, but as a bit of a bodge to get the clutch to engage correctly with the shorter carrier I just made a longer push-rod for the clutch slave. Possibly not a great long term solution for the clutch, but mine was stuffed anyway, I just wanted to test the box  ;)
That and I didn't fancy spending another hour doing gearbox-pushups!
#9 Lurch ™
Lurch ™
  • 5,684 posts
Posted 22 January 2013 - 03:23 PM
FWIW there are 13 different height thrust bearing carriers listed on the Nissan parts database...
