offset lower control arm bushes
12 replies to this topic
#1 zr240
zr240
  • 721 posts
Posted 11 July 2007 - 12:02 PM
Hi all
does anyone know were to get the offset lower control arm bushes to suit the zed? Or anyone with rose jointed lower control arms they want to sell?
Thanks
Ash
#2 JP
JP
  • 157 posts
Posted 12 July 2007 - 09:53 PM
Hi Ash,
AllZParts in Sydney had them at one point.
Good luck
James
#3 Toecutter
Toecutter
  • 2,274 posts
Posted 15 July 2007 - 06:08 PM
Any progress on this Ash? I'm sure I've seen them on the net before. Craig L had some made for his V8 Z, I've got the artical he wrote up that supplies all the details. Pretty sure it will be posted very soon on the articals section of front page, will check.
sulio
#4 zr240
zr240
  • 721 posts
Posted 15 July 2007 - 08:23 PM
na no luck yet?
Ash
#5 Toecutter
Toecutter
  • 2,274 posts
Posted 23 July 2007 - 11:39 PM
http://cgi.ebay.com/...135931196QQrdZ1
http://cgi.ebay.com/...136171291QQrdZ1
#6 zr240
zr240
  • 721 posts
Posted 24 July 2007 - 09:41 AM
The ones on ebay are aparently for bumb stear. I want the bushes that replace the rubber and steel bush on the lower control arm.
Thanks for tring though
Ash
#7 620Z
620Z
  • 1,710 posts
Posted 24 July 2007 - 10:51 AM
Re drill the holes in your front cross member. By relocating your hole up some 40mm or so and out slightly this will adjust your roll centre. I and many others have done this to there cars.
#8 620Z
620Z
  • 1,710 posts
Posted 24 July 2007 - 12:03 PM
This is how my car looks fixing the bump steer problem. You can see I don't have any plates to correct the roll centre. This is because the inner control arm has been relocated up some 40mm. Sorry no picture of that as the splash pan is in the way.
#9 Scando
Scando
  • 932 posts
Posted 24 July 2007 - 12:46 PM
Yep, my car has had the same thing done.  Seems to work well  ;)
#10 Toecutter
Toecutter
  • 2,274 posts
Posted 24 July 2007 - 05:19 PM
Very neat Craig. We do have an artical Craig has written on this topic complete with pics and we are hoping to post at some point in the near future.
#11 Scando
Scando
  • 932 posts
Posted 25 July 2007 - 07:53 AM
One thing I forgot to mention earlier,
If you don't want to re-drill the holes then try Noltec for bushes.  I got adjustable rear castor/toe bushes through them.  Not sure if they do adjustable front ones or not.
#12 nat0_240_chevZ
nat0_240_chevZ
  • 845 posts
Posted 27 July 2007 - 12:51 PM
not flaming,
but i had some new but old tc rod bushes from noltec and the split and fell out with just 3 hard laps around the block testing everything out, dropped the nolathan redies in (used) and still no dramas!!!
just me exp so far, and yes noltec do/did make rear adj bushes but havent investigated lately.
nato
#13 Scando
Scando
  • 932 posts
Posted 27 July 2007 - 12:59 PM
That's damn unlucky!  Haven't seen any signs of wear/damage on mine.
Pulled half a second of my laps time when I put them in too  ;)
