280ZX diff mount
12 replies to this topic
#1 bullzed
bullzed
  • 435 posts
Posted 08 August 2012 - 10:27 PM
Hey guys,
so I've been looking around for a new diff mount as I get a massive bang every time I bring the clutch out too quickly. I can't find any listings anywhere, ebay USA has a diff mount insulator and supercheap has no listing for it whatsoever.
What do?
#2 dat2kman
dat2kman
  • 4,061 posts
Posted 08 August 2012 - 10:34 PM
guess what????
I got a good one here!!
no rips or tears and not grease encrusted
pm me an offer, pick up early next week!
#3 JDSM
JDSM
  • 120 posts
  • Tagline:Jamie
Posted 23 March 2015 - 02:47 PM
Reviving an old one here. I'm refreshing my diff at the moment. Does anyone have a source for NEW R180 rear diff mounts/bushes? I've only come across R200 ones and looking at non-Z R200s, I'm fairly sure that they wont fit.
Cheers,
Jamie
#4 dat2kman
dat2kman
  • 4,061 posts
Posted 23 March 2015 - 03:24 PM
I know i have a R200 one.
Could possobly file the rear of diff stid mount holes in a bit, to make fit.
Other option is to get the original bush re-rubbered.
We have a shop here in Brisbane that can do this.
You'd need to send it up, and wait till its done.
Other option, press stock bush out, machine up some 90 durometer Urethane bar , measure the length of inner bush tube, make up same, and using large doam washers or machined spacer rings, for correct crush and location, if cant buy new from Nissan.
Try Motorsport Auto n USA?
Ah, just checked MS Auto, $130 USD, but now no longer available.
Gonna have to get it re-rubbered!
#5 Roberto
Roberto
  • 740 posts
  • Tagline:No more sunroof's!
Posted 23 March 2015 - 08:09 PM
Cheers,
Jamie
Here you go.....
http://www.ebay.com/...f823300&vxp=mtr
#6 dat2kman
dat2kman
  • 4,061 posts
Posted 23 March 2015 - 11:02 PM
He said "rear" assume it is the back of diff to the single vertical pin from underside of floorpan.
#7 JDSM
JDSM
  • 120 posts
  • Tagline:Jamie
Posted 24 March 2015 - 07:47 AM
This is correct, thanks anyway, Roberto.
Thanks for the help, Jase. We jokingly said the other day that we'd have to go to Clark Rubber and make one...
#8 600Z
600Z
  • 273 posts
Posted 24 March 2015 - 10:09 AM
Is it this one?
http://www.courtesyp...0-p-569134.html
Justin
#9 dat2kman
dat2kman
  • 4,061 posts
Posted 24 March 2015 - 10:54 AM
I'm a thinking only difference is the width of the stud spacing on rear diff cover plate.
OP needs a R180, the above is R200
Have a scrounge around for a R200 one from local wreckers, or someone on here wrecking, and just file the two holes inwards to make a R200 one fit your R180 diff
Easier and cheaper!
#10 Rat1314
Rat1314
  • 108 posts
Posted 29 May 2015 - 07:46 PM
Shop name and details please. I need some things done.
#11 dat2kman
dat2kman
  • 4,061 posts
Posted 29 May 2015 - 11:39 PM
thay wont do "one off single item" jobs, minimum of 10 items for them to make it worth their while to do a batch of liquid compound for s.
I have here some 6-7 various diff, trans and engine mounts, welcome to add your into the pile to get done.
Other option is to turn it into a solid mount, i can do this
#12 Rat1314
Rat1314
  • 108 posts
Posted 30 May 2015 - 01:27 PM
Very interested. Just off the top of my head I might have 5 items, maybe more. How much does it cost?
#13 dat2kman
dat2kman
  • 4,061 posts
Posted 30 May 2015 - 04:01 PM
Last time I had it done was around $60-70 per item, depending on complexity.
Diff and trans mounts for 240-260 require a sort of "wall" to keep compound in while it sets.
