How much does it cost to replace a crank seal
9 replies to this topic
#1 Bozo
Bozo
  • 654 posts
  • Website:http://www.vicspace.com/
  • Tagline:53-681
Posted 29 June 2012 - 08:40 PM
Hi guyz,
I just coughed up a heft fee replacing my crank seal today. I'd like to receive input from other Z owners as to roughly how much it would cost to getting this replaced including parts costs.
Please no smartass responses such as "I fix crank seals myself" etc.
Many thanks!
#2 Scoota G
Scoota G
  • 4,213 posts
  • Tagline:Mark
Posted 29 June 2012 - 08:53 PM
Front or rear sunshine?
#3 Riceburner
Riceburner
  • 3,261 posts
Posted 29 June 2012 - 08:55 PM
Rear main seal? IIRC the seal is about $12, the rest of the cost is all labour. You have to remove exhaust, gearbox, slave cylinder, clutch, flywheel, then fit seal and refit everything. I usually take 4-6hrs to do mine, flat on the floor with no hoist.
Probably why I'm a plumber and not a mechanic  ;)
#4 Bozo
Bozo
  • 654 posts
  • Tagline:53-681
Posted 29 June 2012 - 09:10 PM
Front Crank.
So how much including labour? which also includes trying to isolate the problem I guess?
I ended up paying around $246
#5 Bozo
Bozo
  • 654 posts
  • Tagline:53-681
Posted 29 June 2012 - 09:11 PM
I've got a sense of being ripped off...again... fuck
#6 Riceburner
Riceburner
  • 3,261 posts
Posted 29 June 2012 - 09:20 PM
Front seal is in the timing cover. So you would, loosen alternator, remove belt, remove the balancer to get the old one out and fit new one. Replace everything, test run, 2-3 hrs plus parts+GST?? Labour is prob $65hr and thats a cheap estimate I think.
If you buy/have a Haynes manual, It tells you how to do these sort of jobs in a step by step process. Time is the biggest cost in almost every job
#7 Lightmaster240z
Lightmaster240z
  • 1,609 posts
Posted 29 June 2012 - 11:08 PM
I would say you wern't rip this time. That seam about right to me.
#8 Gordo
Gordo
  • 1,112 posts
  • Tagline:Racing member.
Posted 30 June 2012 - 06:19 AM
Yep sounds about right. Sometimes I take the radiator out, it makes it a lot easyer ,but longer,but at least you can see what you are doing.
#9 Scoota G
Scoota G
  • 4,213 posts
  • Tagline:Mark
Posted 30 June 2012 - 08:14 AM
Labour is $110 up in Ballarat so i assume more down your way! Trick is to ask around before you have these repairs done!
#10 peter mc
peter mc
  • 1,573 posts
Posted 30 June 2012 - 10:54 AM
labour would have been 99 and the price was spot on to do it in a shop , if you can not do it your self you have to pay , old cars need to be worked on from time to time so if you wont one learn how to work on it . That's why we have them we like to play with them and enjoy there quirks
