Dellorto DHLA questions!
23 replies to this topic
#1 Agno
Agno
  • 1,334 posts
Posted 29 June 2012 - 11:55 AM
Hi guys,
Going triple Dellorto and at the moment I'm stripping the carbs before rebuilding them. I'm making this thread because I get the feeling I'm going to have a few questions about how these carbs mount, linkages, etc.
First question is this, what is in this hole?
Posted Image
While I was stripping them I found that 2 carbs have these screws covered in really hard gunky stuff while the third one is missing these screws (has the holes, but they are open to atmosphere). I assume these two screws are vacuum blanking screws like below but I just wanted to be sure I'm not missing some jets or something crucial.
Posted Image
Also, just wondering how do the linkages work with these carbies? The instructions provided by Redline aren't exactly helpful...
Cheers in advance,
Alex
#2 luvemfast
luvemfast
  • 4,143 posts
Posted 29 June 2012 - 12:23 PM
Are you rebuilding these yourself?
Do you have any literature or manuals? I'm sure Scoota has whatever you need.
Do you have a sync tool?
As far as linkages go, they should be the same as any other triple set-up.
I can help you when you're getting that close.
#3 Scoota G
Scoota G
  • 4,213 posts
  • Tagline:Mark
Posted 29 June 2012 - 01:31 PM
That screw is the idle by-pass adjustment screw it's an emission type dellorto. I do have the Des Hamill book and a sync tool if you would like to lend them!
#4 Agno
Agno
  • 1,334 posts
Posted 29 June 2012 - 02:22 PM
That would be very generous of you thanks Scoota, do you happen to have a picture of what those screws look like? I'm trying to order everything I need in one go so I can get these done asap!
Also would anyone know why these screws are covered in a gunky putty stuff? It is rock hard and to me looks like body filler. I know alfas are prone to rusting but surely the previous owner of these carbies didn't try to bog their carbs! :P
Cheers Simon. I'm getting the Des Hammill tuning/rebuild book on the weekend. I will be rebuilding these myself but the jets/tubes/screws/carb bodies will be professionally cleaned before assembly I think and I have a Unisyn but I'm thinking about getting one of the other carb balancing tools that fit into the trumpets... I forget what they are called!
The goal is to have the carbs rebuilt and in a somewhat drivable state before I get Gordon Dobie to tune her up :D
#5 luvemfast
luvemfast
  • 4,143 posts
Posted 29 June 2012 - 02:37 PM
If Gordon's on the case, you'll be fine  ;)
Does he have a selection of jets?
#6 Agno
Agno
  • 1,334 posts
Posted 29 June 2012 - 03:01 PM
He recommended just the stock 2000cc alfa jetting, which is what these carbs have and so do ashs (zr240)
#7 Scoota G
Scoota G
  • 4,213 posts
  • Tagline:Mark
Posted 29 June 2012 - 05:11 PM
I do like that set up but i change the idle jets to 52's or 50's
#8 Scoota G
Scoota G
  • 4,213 posts
  • Tagline:Mark
Posted 04 July 2012 - 09:56 AM
http://www.ebay.com....=item4cf8fabc50
These are the wheels my setup uses. Heaps better than the redline ones!
#9 luvemfast
luvemfast
  • 4,143 posts
Posted 04 July 2012 - 10:00 AM
I've got some of these in the garage.
http://www.ebay.com....=item4cfadc1d87
Interested?
#10 dat2kman
dat2kman
  • 4,085 posts
Posted 04 July 2012 - 02:33 PM
The hard gunky gooey putty set stuff is factory fitted, after car has been fitted with carbs, under it will be some form of progression hole air bypass adjuster.
They do not need altering once set, for that particular car it is tuned for.
It was an emisdions requirement.
Other thing it could be blocking, is a hole drilled further into body, to access another hole, again for the carb to operate as designed, and the blanking putty just seals it up, same as Weber carbs get little soft lead ball plugs to seal up drilled holes.
#11 Agno
Agno
  • 1,334 posts
Posted 04 July 2012 - 06:38 PM
After a bit of reading I found they are idle air bypass screws, and yes they are factory putty lol. I ordered some new ones to replace the flogged rusty ones I was given and I'll fit them with the new seal kit. Hopefully they don't cause too much of a fuss.
Thanks for the info on the linkage Mark, I'm assuming those wheels bolt onto the throttle shaft and the linkage rods attach to those?
Simon from where I'm sitting it looks like that style of linkage wheel doesn't fit onto the Dellortos, they have a rounded rectangular hole like the wheels Mark linked so I'm not sure they will work. I'll search closer and see what I can find :)
#12 Scoota G
Scoota G
  • 4,213 posts
  • Tagline:Mark
Posted 05 July 2012 - 11:45 AM
Yes they do, the wheels in simon's link do the same job!
#13 Agno
Agno
  • 1,334 posts
Posted 06 July 2012 - 12:02 AM
Well if they work you might have a buyer Simon! Once I finish rekitting these babies I'll have a chat with you
#14 Agno
Agno
  • 1,334 posts
Posted 24 July 2012 - 05:21 PM
Well the carbs are almost done, had major headaches with missing bits, non-matching other bits, broken other other bits and general wear that should be expected from old carbies that have been sitting on a wrecker's shelf for a few years:
Posted Image
I won't be using a return line on these carbs so I was wondering what I should do with the stock return pipe that is chilling in the engine bay, just block it with a bolt+clamp?
Also does anyone have any tips for when I bolt these on and try to get the car running? I have wound the idle screws all the way in (full rich) and am going to back the distributor off to avoid any potential pinging/damage caused by whacky mixtures, any other recommendations?
Thanks in advance
Edit: Has anyone else had issues with their linkages touching the carb body? The first thing I thought of doing was to either cut the offending piece off the carb body or cut the thread on the rods to get everything to clear, but that seemed almost counter productive. This protruding bit where there is a hole for a bolt of some sort is the offending part:
Posted Image
(I won't be using the Redline linkage wheel but I figured I might have the same issue with any other type of wheel I could potentially use)
#15 Scoota G
Scoota G
  • 4,213 posts
  • Tagline:Mark
Posted 24 July 2012 - 05:55 PM
I would turn all the screws out to three on start. 1.5 is a minium 5.5 is a maximum and if you can't get it to idle in this range you will have to rejet idles.
You may have problems bending float tabs without a return but give it a shot!
Are you using soft mounts? I would.
The wheels have a tab for idle adjustment. I had to cut the pivot joint bolt down too.
#16 Agno
Agno
  • 1,334 posts
Posted 24 July 2012 - 06:42 PM
Do you mind explaining what you mean by that? Looking at the wheels they just bolt on and that's it.
I have some soft mounts that will be used when the carbs finally go on the manifold for good.
#17 mick74
mick74
  • 33 posts
Posted 24 July 2012 - 08:58 PM
Alex
I hope these photos explain a little with return spring mount (home made) and throttle link arm. The arms I found at a carby store.
Mick
#18 Scoota G
Scoota G
  • 4,213 posts
  • Tagline:Mark
Posted 25 July 2012 - 09:50 AM
Here we go!
#19 Agno
Agno
  • 1,334 posts
Posted 14 August 2012 - 12:30 AM
Bit of an update...
I bought some of the linkage wheels similar to what Scoota has on his carbs and the ones they sent me won't fit the linkage properly because they are the wrong side of the carb body. I'm hoping the seller can help me out and get me the right ones.
Also I don't have idle adjustment screws in those little holes on the carbs... or a thread at all on one carb. If I was to use loctite on the bolt would that be enough to hold them in place? Or should I be on the lookout for an appropriate spring and washer to hold the idle adjustment bolt in place?
2 steps forward and 1 back... They better be worth it!
#20 luvemfast
luvemfast
  • 4,143 posts
Posted 14 August 2012 - 10:07 AM
I wouldn't be using loctite anywhere that needs adjusting Alex.
Go to a carby or  fastener store and get the right bits  ;)
