Can I use 17x8.5 without flares???
8 replies to this topic
#1 dat240z
dat240z
  • 1,119 posts
Posted 23 June 2012 - 06:56 PM
Hi, im getting a set of Rota RKRs and am hoping to see if anyone out there has a solid answer as to whether or not they will fit without scrubbing on my 71 240z.  i have coilovers which are 3 way adjustable (more room than stock) and currently run lotus performance 17x7.5 with 17/235/45 all round. Currently they sit about an inch in from the guards. Some people on hybridz reckon theyd be fine (17x8.5) with a +4 offset???
want to confirm before ordering from the states...
any help would be appreciated fellas
#2 Agno
Agno
  • 1,334 posts
Posted 23 June 2012 - 07:33 PM
I run 15x8 -3 on the front of my car with a few degrees of camber (I forget how much) and they fit easy so you should be fine.
My car did used to scrub the castor rod at full lock with a big tyre when I used to have 15x7 +12 (equivalent to a 7.5 +6) on the front but for some reason nobody else seems to ever have this problem *shrug*.
#3 Zedman240®
Zedman240®
  • 5,198 posts
Posted 23 June 2012 - 07:39 PM
I used to run some 17x8 Simmons with 225 tyres with lipped guards with coilovers and they did scrub slightly on some big heavy bumps. Forgot what offset they were but I do have the receipt somewhere with all the info.
#4 d3c0y
d3c0y
  • 2,950 posts
  • Tagline:Forum Jerk
Posted 25 June 2012 - 09:39 AM
What offset are you running. I've made a Z wheel calculator in excel and I'll be able to tell you where they will sit.
#5 dat240z
dat240z
  • 1,119 posts
Posted 25 June 2012 - 12:53 PM
I was going for a +4 offset......
thanks mate
atm with 7inch wide on 235's (0 offset) it sits about 3/4 inch in  from guard...
#6 sco_aus
sco_aus
  • 2,484 posts
  • Tagline:Scott
Posted 26 June 2012 - 09:22 AM
If it is driving, bring your zed around and we can fit my Rota RBs on your car
#7 d3c0y
d3c0y
  • 2,950 posts
Posted 26 June 2012 - 12:21 PM
Dont you have 9J and 9.5J? I can tell you now they wont fit without flares as you probably know. What does that acheive?
#8 sco_aus
sco_aus
  • 2,484 posts
  • Tagline:Scott
Posted 26 June 2012 - 12:22 PM
Me?  I know what size wheels I have...
#9 d3c0y
d3c0y
  • 2,950 posts
Posted 26 June 2012 - 12:26 PM
Havent had a chance to set up my home computer after moving house yet to get to the spreadsheet but this should answer your question:
http://forums.hybrid...hat-size-tires/
