Sign in to follow this
Kirby
Bodywork/Rust Repair/Panel Replacement in Adelaide
Hey Guys,
So I've been acquiring parts for my 260z for a while, but now I've moved to Brisbane for work and the car is stuck in Adelaide.
I need a good shop that is going to be able to replace a few panels on my car and prep the shell primer and new underbody coating so I can bolt the suspension back up and transport it up here.
I'd be looking for a shop that comes with a personal recommendation, has good experience in the area, good quality in welding & metal finishing. Most importantly is able to provide me adequate communication (photos, emails) because i'm not in the state.
Finally, with Warren at allzparts a bit crook at the moment, does anyone know where i can get a fuel filler surround replacement panel?
Cheers,
Kirby
Share this post
Link to post
Share on other sites
I got some rust work done at Stuart Crash Repair on Port Road. They did a good job. Give Dennis a ring if you are keen. Can send you some pics of the work they did, if you need
Share this post
Link to post
I recommend my shop in Murray bridge :) Bridge paint and panel I have good experience with the s30
would be VERY happy to give a member here the business...it also means the move for my car isn't huge (its near Callington atm).
Do you have any examples of your work?
Share this post
Link to post
HI
Make sure who ever you use knows how to fix rust properly.
We have fixed so many crap rust repairs from crash shops it makes me
sick that these guys continue to just slap holes full off bog. and my
all time favourite is just weld a bigger plate over the rust them hit it in and
bog over. We have seen cars that have had 20mm + of bog from
reputable shops.
zzzzed does good work, So does AHP in Nairne
and we do as well  http://www.finchrestorations.com.au/
We are in Mount Barker
Regards
Paul
Share this post
Link to post
Thanks Ledge,
I am pretty watchful when it comes to the quality of the work done, but also I've seen some horror work come out of bodyshops. So that's why I wanted to ask around here for recommendations, its a little frustrating not being in Adelaide to monitor the work so that's why I am looking for a shop that would be good with correspondence.
Basically I would supply all the replacement panels, and just need some blasting, cut and welding, etch and prime and some new rubberised undercoating.
I'll try and get some pics of the current status of the car.
Share this post
Link to post
I allways take lots of photos of my work regardless And can email them or post the here on the forum. We are close to finishing a resto at the mOment so there is a vacancy opening up now.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
