What are these electrical switches on 280ZX box?
7 replies to this topic
#1 wildy55
wildy55
  • 422 posts
Posted 16 December 2011 - 11:01 AM
Hi all, looking to find out what these three switches on my 280ZX box are. Using it in a 240Z so only need reverse switch.
#2 Six_Shooter
Six_Shooter
  • 733 posts
  • Tagline:Canuckian
Posted 16 December 2011 - 03:39 PM
The bottom one (in the picture is the reverse light, the middle one is 3rd or 4th gear switch (4th gear I'm pretty sure), the top one I'm not sure about, if it was nearer the shifter I would say a neutral switch.
#3 MaygZ
MaygZ
  • 1,456 posts
Posted 16 December 2011 - 05:08 PM
Put a multi-tester on them and select the gears.  That will tell you which on is the reverse and which is the neutral/park switch.
I would suspect that, unless neutral and park are managed separately, that the third would go back to the ECU to tell it which gear you are in.
MaygZ
#4 luvemfast
luvemfast
  • 4,124 posts
Posted 16 December 2011 - 08:03 PM
I don't have any of those extra switches on my box.
Why would the ECU need to know what gear you're in?
#5 Gareth. J.
Gareth. J.
  • 3,237 posts
Posted 16 December 2011 - 08:25 PM
The sensor with two black bullet terminals is a reverse switch  ;) the others I have no idea.
#6 dat2kman
dat2kman
  • 4,029 posts
Posted 16 December 2011 - 09:56 PM
Upper two are somehow used to tell the ecu you are in a top gear, and adjust tje timing or fuel delivery for more economical running, mainly to do with USA emisdions, especially stricter California.
Aussie deliveted cars had no need for this, dunno wether the ecu "read" these.
I treid using them to send false signal in order to overfuel engine for race use, nup, it reduces fuel, and alters timing the wrong way.
I ended up using other sensors signals into ecu to get desired effect. Blew four up though, trying!!
#7 wildy55
wildy55
  • 422 posts
Posted 17 December 2011 - 08:58 AM
Cheers fellas!
#8 MaygZ
MaygZ
  • 1,456 posts
Posted 17 December 2011 - 03:23 PM
What Jason said.
You just can't put a wise head on young, narrow, pretty shoulders  ;D
George
