Another headlight problem!
#1
Posted 14 December 2011 - 07:51 PM
My headlights suddenly stopped working. My dash and taillights work no problems, but nothing up front.
I ran a bypass switch that allowed me to turn on the high beams so they are working up the front end (power and earth are making it to the beams.
Any ideas? Why has my headlight disappeared? And why would the new switch turn on the highbeams rather that the indicators?
I am running h4 globes, does this create a problem? They were fine for 14 months or so....
#2
Posted 14 December 2011 - 08:21 PM
#3
Posted 14 December 2011 - 08:48 PM
#4
Posted 14 December 2011 - 10:24 PM
#5
Posted 15 December 2011 - 08:05 AM
Basically check all wiring and if not already done set the lighting circuit to run through relays and upgrade all wiring from the lights to the battery and relays with some 20 amp wire and take all the load off teh light switch. 40 year old wiring gets pretty ordinary for handling anywhere near what it's rated at.
#6
Posted 07 January 2012 - 08:53 PM
Regards: Alan.
#7
Posted 03 March 2012 - 01:19 PM
have look at my reply in your car journal, that may help.
So here is my problem if anyone can help. About to fit relays etc to H4 lights but here lies the problem. I have two wiring diagrams, one from Atlantic Z Car site and one from Benny and have looked at others on this site but they are different in what wires go to what terminals on the relay. Car is a 75/260 2+2, and I will try to explain what wire colours are where and hope someone can help.
LH side body. LH side light
RW RW
RB RY R RB
RH side body RH side light
RW RW
RB RY R RB
Now I need in laymans terms what wires to go to what nos on the relays. I know 30 is the main wire from battery to relay and what AMP wire is best to use? To explain my plugs RW goes to RW, RB goes to RB and R goes to RY.
Switch terminal has RY RW and B[earth]
Call me dumb but when people post wiring diagrams they should mark the colours in what is in the car not what they think will do with pretty colours. I am no IT expert or auto sparkie so any help is greatly appreciated.
#8
Posted 03 March 2012 - 04:24 PM
If you are available next weekend, you are more than welcome to come up to my place and we can rewire to suit the relays. It is probably easier to do it that way than to try to explain over the interweb or phone.
Matt
#9
Posted 04 March 2012 - 06:04 AM
Sounds good to me if Saturday is ok with you. Sunday is out for me.Peter,
Matt
#10
Posted 04 March 2012 - 09:43 AM
Saturday is fine, will PM my address.
#11
Posted 22 March 2012 - 05:39 PM
#12
Posted 06 April 2012 - 08:58 AM
I have purchased a new headlight stalk and indicator stalk. Both have been proven to be working be the sellers.
I currently have everything working with my existing equipment except the headlight globes (dash and tail lights are fine).
The wiring to the headlights are fine as I can bridge the loom inside the cabin to create light.
Fuses are also fine.
The globes are 60/55 and shouldn't blow anything.
OK
The new indicator stalk turns my indicator switch into the high beam switch so I can have high beam but not low beam and indicators.
The new headlight switch makes me lose all lights and functions except windscreen washers.
Does anyone have an idea at all???!!!!
#13
Posted 06 April 2012 - 10:35 AM
Both headlight switches now work to a point where the tail and dash lights come on but not the hi low beams.
The new indicator switch definitely turns the indicators left right switch into high beam on.
So I guess. the headlight switch is not to blame here.
#14
Posted 06 April 2012 - 11:18 AM
Im not sure if i understand you correctly but, it sounds to me like the switch or switches may have come from a car with a different wiring loom? And when you energize the right or left indicator it is actually sending current down a headlight conductor.
Do you think this is possible?
If so I think it means you might just have to reconfigure the wiring at the plug.
Hope I'm not sending you on a wild goose chase.
Mick
#15
Posted 06 April 2012 - 11:38 AM
