AFTERMARKET FRONT WINDSCREEN DEMISTER, Where to get one????
8 replies to this topic
#1 Sooley
Sooley
  • 86 posts
Posted 30 March 2007 - 12:49 AM
Hi All
To get my car registered I will need to run a front windscreen demister. I am looking for an aftermarket one which I believe is available but can't find it anywhere.
I have heard its like a fan with a heater element in it that can be mounted to send heat to the front window when swithced on.
If anyone knows where I can get one that would be great.
Sooley
#2 Rod F
Rod F
  • 101 posts
Posted 30 March 2007 - 07:53 AM
What's wrong with your factory heater and fan?
#3 mayhem
mayhem
  • 305 posts
  • Tagline:speed is a life style
Posted 30 March 2007 - 08:46 AM
They are avaliable i can find out if there is one in oz im an auto elec but they are not called for much they use similar things in buses i guess you gutted it out to rally huh ..... I will look around :wink:
#4 mayhem
mayhem
  • 305 posts
Posted 30 March 2007 - 09:07 AM
Quick i know!!! a company in melbourne do stock them
W-519mm
D-203mm
H-129mm it weighs 4.85 kg
its not electric though.
The only thing is it has no ducts its a open face with grill it would be easy to set all that up but at around $400 + gst and freight you would be better off putting factory one back in cheap and easy :?
a caravan mob might have 12v elec heaters i know what your chasing but a small one will be hard to get
#5 sco_aus
sco_aus
  • 2,484 posts
  • Tagline:Scott
Posted 30 March 2007 - 10:43 AM
A friend of mine used 12V computer fans attached to the ducts, but im not sure about the heating side of things.
#6 Bruce
Bruce
  • 301 posts
Posted 30 March 2007 - 10:53 AM
there is these units on ebay, not sure if they are too big though:
link
#7 sco_aus
sco_aus
  • 2,484 posts
  • Tagline:Scott
Posted 30 March 2007 - 10:57 AM
Not bad at all, i might even have a look for something like that for both datto and troopie.
#8 Mr Camouflage
Mr Camouflage
  • 986 posts
  • Website:http://www.wazcars.com
  • Tagline:www.wazcars.com
Posted 30 March 2007 - 10:27 PM
I think some guys on ozdat used 12volt portable hair dryers. just wired it up to a switch and stuck the end in the tube that leeds to the vents under the dash.
something like this:
http://www.sailgb.co...12v_hair_dryer/
#9 Sooley
Sooley
  • 86 posts
Posted 30 March 2007 - 10:35 PM
YEAH! great work guys
I looked for an hour and couldn't find a thing
They one from eBay for $149 looks good but I would still need the factory heater piping and I was trying to get an electric one.
Found this, looks ok
http://cgi.ebay.com....81644&rd=1&rd=1
To get my car registered in NSW I need a front window demister and seeing as I am putting in the S15 Silvia dash, the factory unit wont fit, so something like this would work a treat.
Will give it a go I think
Anthony
