S13 coilovers into S130, 280ZX
26 replies to this topic
#21 luvemfast
luvemfast
  • 4,143 posts
Posted 18 February 2012 - 07:36 AM
Resurrecting an old thread.
I've found a mint set of Tein coil overs. But the fronts aren't base height adjustable.
The rears are practically new. But they have a 4kg spring rate, about 220lb
What spring rates would be best suited?
I was thinking 350lb fronts and 300lb rears  :-\
#22 luvemfast
luvemfast
  • 4,143 posts
Posted 18 February 2012 - 08:38 AM
Just spoke to the guy.
He also has some HKS springs to fit. But the only markings on them at 14.0
I hope that's not 14kg
That's 840lb  :o
#23 PZG302
PZG302
  • 1,778 posts
Posted 18 February 2012 - 10:44 AM
Probably is 14kg Simon, and not unreasonable. I ran 900lb springs in my 180B 3j street sedan. When we went to IPRA to drop the ride height the good old ghetto way used as we also wanted to up the spring rate to keep the rear trailing arms as close to a live rear end as possible. I think we ended up with around 1200lb  springs, and concussion every time I drove over a white line, let alone a bump.
#24 luvemfast
luvemfast
  • 4,143 posts
Posted 18 February 2012 - 10:53 AM
Not quite what I want though?
#25 d3c0y
d3c0y
  • 2,951 posts
  • Tagline:Forum Jerk
Posted 18 February 2012 - 06:07 PM
Being a track car you are going to want at least springs in the 300lbs region.  I think the coilovers i got are 400 and 450lbs. But i wouldnt get the non height adustable ones anyway its a waste when you can get the good ones for pretty much the same price.
#26 nat0_240_chevZ
nat0_240_chevZ
  • 845 posts
Posted 01 March 2012 - 11:41 AM
may be easier for others in trying this, to cut the s30 strut tube off at the lower casting,
machine up some round bar approx 150-200mm long , 2 holes (1 is a slot) and 2 flats eitherside to suit the rexe style knuckle clamps,
holes and flats suit the strut clamps, and you can keep Z steering, but now achieve lots of camber without interference of tyre to strut, due to the ecentricity / offset of strut tube to the ball joint pivot, so easy and yet so overlooked. oh and very little fab req'd, just weld in the bar inserts.....
nat0
#27 d3c0y
d3c0y
  • 2,951 posts
Posted 01 March 2012 - 02:39 PM
Do you have a pic of what you mean im having trouble visualising it.
