Riceburner Posted November 17, 2011 Share Posted November 17, 2011 With 260z hubs it bolts on, but the discs need to be drilled to suit zed pattern, centre hole matched to hub bore and the caliper needs to be widened to suit the TP magna 23mm disc. This happened the same way to me but I have a 260z 2+2 parts car that has been very helpful. So my hubs came straight off that. I think 50% of the 'bolt on mods' I've done have been anything but bolt on The bad thing is it's only discovered after the car is in bits. Quote Link to comment Share on other sites More sharing options...
MaygZ Posted November 17, 2011 Share Posted November 17, 2011 I thought this was meant to be a bolt on upgrade? Hey Beeber, I think there are bolt on versions of this upgrade, and then there are ways to make it just a little more complicated. George Quote Link to comment Share on other sites More sharing options...
luvemfast Posted November 17, 2011 Share Posted November 17, 2011 Hey Beeber, I think there are bolt on versions of this upgrade, and then there are ways to make it just a little more complicated. George LOL Quote Link to comment Share on other sites More sharing options...
Scoota G Posted November 17, 2011 Share Posted November 17, 2011 I thought this was meant to be a bolt on upgrade? Sure are, if you use solid rotors. Quote Link to comment Share on other sites More sharing options...
luvemfast Posted November 17, 2011 Share Posted November 17, 2011 Sure are, if you use solid rotors. Oh, I see. Quote Link to comment Share on other sites More sharing options...
Riceburner Posted November 18, 2011 Share Posted November 18, 2011 Also the vented calipers come very close to my wheels, there would be 2mm clearance between the caliper face and the wheel spokes. I run konig rewinds 16x8 zero offset. So fitting the spacer plates between the caliper halves could cause more trouble.... Quote Link to comment Share on other sites More sharing options...
luke240ZED Posted November 18, 2011 Share Posted November 18, 2011 Luke, I can't recall who did it, but someone here made a plate to fit between the two halves of the caliper to create the gap which you seek. Someone else may be able to remember who did it and post the link. MaygZ I have seen this thread, the modded plates that went between the calipers looked pretty damn serious. With the tools in my shed, certainly not an overnight job. And as for Gareth's call, "I think 50% of the 'bolt on mods' I've done have been anything but bolt on The bad thing is it's only discovered after the car is in bits." This is spot on at my house mate. My Zeds been up on stands now for 2 months as I problem solve my "bolt on" mods, but with the help I'm getting in here, the light is now at the end of the tunnel Cheers Luke Quote Link to comment Share on other sites More sharing options...
EMPRACING Posted January 14, 2012 Share Posted January 14, 2012 These "bolt on" mods can be trying cant they? I've been searching for answers on all these s12?? calipers for yonks and i mean over 10 years on and off it only gets worse haha I already have the +8s done that in about 98 they flew on there with only the backing plate mod i cant remember the hilux exactly but i think i was looking for 86 4x4 Utes that time now I'm up to my armpits in the vented set up with my s12w's 91 4runner v6 and the "disk" options are killing me! i was going to go magna but there 24mm so that's out unless i get the slot enlarged when there apart the machining will be done on the disk what ever i end up with and i have the r31 rear brackets to get done too! I'm going to rip the old fronts (s12+ off tomorrow and see if there the larger ones its been to long to remember Those chaps at Toyota sure like to change there mind on there calipers a lot don't they? hope everyone else is having more luck now. pics of calipers to compare turns out my +8's are the narrow ones so ill use the new ones with silvia disk and to confirm that 513 16x8+0 will clear and this is without caliper bolt spacers that will make more room Quote Link to comment Share on other sites More sharing options...
Mitx Posted January 29, 2012 Share Posted January 29, 2012 Here are the calipers side by side as requested and a pic of the caliper gap, which is 23mm. This should suit the S13 rotors at 22mm nicely . Cheers Luke This is a very interesting thread for me because I bought the S12-8 rebuilt callipers for the 20mm vented rotors. And I was surprised to measure the gap for the rotor at 20mm instead of 23mm like Luke measured. So it means I either received the calliper for the solid version or my calliper have been machined and they reduced the gap by 3mm during the rebuilt. EMPRACING, could you measure the gap on the S12-8 for solid rotors please? Is it 20mm? Quote Link to comment Share on other sites More sharing options...
MaygZ Posted January 29, 2012 Share Posted January 29, 2012 G'day Mitx and welcome aboard. Yes there are two models of 's12+8'. One with a gap of 23mm (ish) for vented discs and one at 20mm (ish) for solid rotors. Obviously the 20mm ones can be used with standard rotor and the 23mm ones can take a larger and ventilated disc. We always talk of them as Hilux calipers, but I would like to remind people that the same calipers are on Landcruisers and Surfs (less common here in Oz). I pulled mine off a 60 series 'cruiser that had vented discs, so I knew they were the right ones. I would love to see some pictures and story of a Swiss Zed, please Quote Link to comment Share on other sites More sharing options...
Mitx Posted January 29, 2012 Share Posted January 29, 2012 G'day Mitx and welcome aboard. Yes there are two models of 's12+8'. One with a gap of 23mm (ish) for vented discs and one at 20mm (ish) for solid rotors. Obviously the 20mm ones can be used with standard rotor and the 23mm ones can take a larger and ventilated disc. We always talk of them as Hilux calipers, but I would like to remind people that the same calipers are on Landcruisers and Surfs (less common here in Oz). I pulled mine off a 60 series 'cruiser that had vented discs, so I knew they were the right ones. I would love to see some pictures and story of a Swiss Zed, please In fact I ordered the callipers for a HJ60 series landcruiser with the good reference number, and I believe that the wrong callipers were put in the parcel. This is what I ordered: http://www.123piecesderechange.ch/cgi-bin/atm_shop.pl?dsco=26&language=fr&ansicht=autoteile&suche=autoteile100027&pag_goto_page=0&pag_select_items_per_page=10&&zubdetails=ERSA-221046&FZGNR=6765 Here is my presentation, http://www.viczcar.com/forum/index.php/topic,10612.0.html Quote Link to comment Share on other sites More sharing options...
EMPRACING Posted January 29, 2012 Share Posted January 29, 2012 Hey again the +8s that i have are for the solids the guy thats doing my disks had a +8 with the bigger gap they DO fit over the silvia disk but man its tight and so is the s12w that i have ill break out the verniers when i can find them but i think theres some factory variance because the "solid" calipers gap i have are WAY narrower by eye than the vented also i now need to get the caliper moved out to clear the 280mm disk because i cant machine the outside down and dont want to waste the disks and the s12w is probabyl too big to make work on the street at this rate i should have put vt fronts on!!! Quote Link to comment Share on other sites More sharing options...
d3c0y Posted January 30, 2012 Share Posted January 30, 2012 How are S12Ws to big for the street? Quote Link to comment Share on other sites More sharing options...
EMPRACING Posted January 30, 2012 Share Posted January 30, 2012 "edit" the +8 gap on my calipers is 15mm sameish as the stock calipers oops some of the message got lost there and I'm not even sure what i said! basically the guy at the shop reckons ide need a bloody 1 1/16 MC to make it work and even then it would be feel crappy on the pedal it seems telling him that heaps of people run with the 1" and its OK didn't win that argument? unless he got them mixxed up with 13s? also told me you cant weld caliper brackets and get them teched i don't freekn know anymore ill have to have a long chat with an engineer real soon! Quote Link to comment Share on other sites More sharing options...
dat2kman Posted January 30, 2012 Share Posted January 30, 2012 I am using a four piston caliper, not hilux toyota, my vented discs did not clear both diameter and thickness, but not by much. I had a mobile brake disc machinist guy come by, knocked off couple mm on diam, and faced the pad surface arwa down 0.8 mm each side , 1.6 mm. It clears all fine, and no issue. Ok you wont have the stamped markings on edge to tell you min thickness, no biggie, and you wont need to weld and redrill caliper to leg mounts to run the full diam. BTW none of mine is on a Zed, but principle is the same. If needing to offset caliper ie fit a waher between strut leg caliper mount ears and caliper ensure you use hardened steel washers, not plain washets, i had to use 2 mm thick hard washers. My rotors went from 280 to 278 diam, and 22 to 20.4 thick, plenty meat left! Quote Link to comment Share on other sites More sharing options...
Riceburner Posted January 30, 2012 Share Posted January 30, 2012 1 1/16th master.... Does that size even exist? I run s12+8 vented and R31 rears on a 15/16 and it performs faultlessly on road and on race track, with less pedal travel than a new car. You'd want to be Arnold schwarzenegger to push that 1 1/16th brake pedal hard Quote Link to comment Share on other sites More sharing options...
Mitx Posted January 30, 2012 Share Posted January 30, 2012 "edit" the +8 gap on my calipers is 15mm sameish as the stock calipers It's what I thought it would be that's why I'm surprised to have 20mm gap if it's for the solid caliper. So to summarize, the gap for: 'vented' S12+8 calliper is 23mm 'solid' S12+8 calliper is 15mm and mine are 20mm -> What's the problem with mine? I suppose they machined it too much during rebuild. Is this possible? What do you think? Could there be a third version of this calliper? Quote Link to comment Share on other sites More sharing options...
Agno Posted January 30, 2012 Share Posted January 30, 2012 1 1/16th master.... Does that size even exist? I run s12+8 vented and R31 rears on a 15/16 and it performs faultlessly on road and on race track, with less pedal travel than a new car. You'd want to be Arnold schwarzenegger to push that 1 1/16th brake pedal hard 17/16th BMC can be found on Z32s and GTR Skylines if I remember correctly. Quote Link to comment Share on other sites More sharing options...
EMPRACING Posted January 30, 2012 Share Posted January 30, 2012 i wouldn't be surprised if there where different sizes just on a production line or different factory's? and yes there are common 1 1/16 and even 1 1/8 MC around just not really direct fit ill check to see if he thort i had the s13 cruiser calipers or something i really didn't get where he was heading with his there too big comments remember i was going to use the s12w (4 big pistons) not my +8s (2 are smaller) the whole you cant legally weld caliper brackets isn't a big problem just makes the price go up making custom ones like i said before i better get the low down from the guy that will accept or deny the mod plates before i stress to much (toooo late!!!) and lastly i know i could trim the outside of a normal disk just the t2's run the slots way out close to the edge if i trim them they could crack all i know is for an everyones doing it no problems mod I'm having an awefull hard time of it Quote Link to comment Share on other sites More sharing options...
EMPRACING Posted January 31, 2012 Share Posted January 31, 2012 got my 12w calipers and the r31 rears back from the shop today they needed a total rekit north of 800 bucks!!!! these things are going on the car no matter what now!! also i had half a win today got the rear calipers out of the "treasure chest" and worked out you dont need to weld calipers mounts for r31 if you only get the center machined to 81 or so but you have to take the axels out meh got that done easy enuff but the bracket will have redundent bolt holes now i have to see what they say about that!! welding them is totally out of the question oh and i measured the gap on the 12w it is around that 23mm like the other guys just to confirm Quote Link to comment Share on other sites More sharing options...
Ben Posted February 3, 2012 Share Posted February 3, 2012 I ran the S12 setup for a few years, but now have the S12W (or is it S12+8?) on my car with Z31/DR30 discs and the MSA adapter kit. Pads are WRX/R32/R33 with a little bit ground from a couple of corners. FWIW if there's anyone that wants a set of S12 (solid) callipers and near-new 240Z discs - I have a set that are surplus to requirements (seen in the left of this shot): . They clear my new 16x7 8-spoke superlites with ease (but fouled the old 10-spoke design): Quote Link to comment Share on other sites More sharing options...
EMPRACING Posted February 4, 2012 Share Posted February 4, 2012 thats at least a 12w def not +8 look good too mine would have too if i the silvia disk had of cleared the caliper mount flange I have to get a bit of feed back from other 260 converters but ide say looking at it that silvia disks arent what we want 240 hubs seem to be fine thow and i know i could make them clear but theres a right way and a really right way wtb pug disks..... eoi s13 "lightened" disks that wont work on a 260 hehe but i can now tell you that xxr 513 16's will clear the calipers just everything else for my "bolt on" brakes and "they fit stop asking!!!" wheels is a prob haha Quote Link to comment Share on other sites More sharing options...
EMPRACING Posted March 24, 2012 Share Posted March 24, 2012 Ok took a while but i got the "bolt on" hylux conversion dialed now First off there's a loot of people on forums that will flame people for asking questions about this conversion and the old "this and that works" line they get is in hindsight a bit disappointing. Maybe its because these z's are a bit different maybe its just my 260z 2+2 that wont work with s13 rotors? but it wont! SO.... we started again with the pug rotor and blam there on no probs at all so lets see a pic or two? not sure if you can see the problem here but the disk is rubbing on the flange there so we go get pug rotors that have a realistic hat offset and..... Oh and p.s yeah the blues a bit much and yeah that's a hub centric ring machined into the hub worth it BTW cheers here's the new clearance and cos theres no spacer the caliper sits out a bit so will the wheels fit..... YES! now i got to get them to clear the strut and swaybar and...... Quote Link to comment Share on other sites More sharing options...
d3c0y Posted March 25, 2012 Share Posted March 25, 2012 just everything else for my "bolt on" brakes and "they fit stop asking!!!" wheels is a prob haha So in summary everything does work and bolt on? If you had researched a bit more and found out hat heights vs the different hubs you wouldnt have bought the wrong rotors. I guess the info isnt spelled out in the thread but the numbers are listed in various posts. Maybe PM Lurch and get him to ammend his sticky. First off there's a loot of people on forums that will flame people for asking questions about this conversion and the old "this and that works" line they get is in hindsight a bit disappointing. No, people are happy to answer new questions about this conversion. A lot of your questions were answered in this thread, like your ones about the master cylinder. Quote Link to comment Share on other sites More sharing options...
EMPRACING Posted March 25, 2012 Share Posted March 25, 2012 ok some fair comment probably comes down to my car but words like tutorial kinda make you think you will be ok i know the hats taller i know the hubs different i searched for months on these things! maybe im to old but i missed any mention of this being enuff of a problem in the end "my" hub vs rotor height just dident come up right hey where talking about 2mm tops here.... and yes i get some answers to questions its not always correct in all cars is probably where im coming from lastly i really hope nothing i have writen sounds like an attack on anybody these cars are truely all over the place at times and being a bus i have the hardest to get right of them all Quote Link to comment Share on other sites More sharing options...
