Tacho problems.
27 replies to this topic
#1 peter t
peter t
    OLD RETIRED Z FART
  • 1,902 posts
Posted 21 September 2011 - 06:01 PM
Have searched the threads but don't seem to notice this same problem. My tacho works most days but now and then it stops working. It can start up while driving or just stop. Doesn't affect the motor. Start up and go and get the paper, Works. Jump in start up and it don't work, drive down the road a bit and it may start working or it may not. What to check? Thanks for any help. ??? ???
#2 benny
benny
  • 1,734 posts
Posted 21 September 2011 - 06:31 PM
mine is the same peter... will be going over it in the next weeks so will let you know if i have any ideas!!
#3 Zedman240®
Zedman240®
  • 5,198 posts
Posted 21 September 2011 - 06:34 PM
A guess would be within the tacho itself...poor connection?
#4 peter t
peter t
    OLD RETIRED Z FART
  • 1,902 posts
Posted 21 September 2011 - 06:52 PM
Thanks guys, I have a spare so will rig that up as described in another thread and see what happens. Let me know how you get on with yours Benny and I will do the same as soon as I figure it out.  8) I saw some talk of a fuse. Is this inside the tacho or elswhere? 8)
#5 peter t
peter t
    OLD RETIRED Z FART
  • 1,902 posts
Posted 11 October 2011 - 05:45 PM
Pulled it out and put it in. Don't mean to be rude but still have problem with both gauges. Checked all fuses and all OK. Might try a new ballast resister and see what happens. 8)
#6 gilltech
gilltech
  • Donating Members
  • 1,231 posts
Posted 12 October 2011 - 07:24 AM
My 260 tach was doing the same thing when I put the car into storage some years ago. I couldn't figure out what was causing it at the time, it seemed to be getting power OK, so I had a niggling suspicion that it was probably linked to the dizzy, as in whatever triggers the tach reading was causing a very irregular fault. Just an idea though.
#7 BobsYourUncle
BobsYourUncle
  • 339 posts
Posted 12 October 2011 - 08:42 AM
Peter, is your tacho a 3-wire (inductive) or 4-wire? My 74 2+2 had the 3-wire type, and it never worked. I tried a spare, and it didn't work either - I was under the impression the inductive type tachos didn't work too well with electronic injection?
#8 peter t
peter t
    OLD RETIRED Z FART
  • 1,902 posts
Posted 14 October 2011 - 06:26 PM
8)
#9 peter t
peter t
    OLD RETIRED Z FART
  • 1,902 posts
Posted 14 October 2011 - 06:29 PM
Not sure what you mean. Don't have injection. Played with the wires at the resistor and now it is going. Tomorrow may be different.
#10 BobsYourUncle
BobsYourUncle
  • 339 posts
Posted 14 October 2011 - 06:33 PM
Oops, I meant electronic ignition. My bad...
#11 peter t
peter t
    OLD RETIRED Z FART
  • 1,902 posts
Posted 19 October 2011 - 08:19 PM
Wacked a new connector on the green/white wire that goes on the basalt resistor and seems to have fixed it.  8)
#12 peter t
peter t
    OLD RETIRED Z FART
  • 1,902 posts
Posted 20 October 2011 - 06:33 PM
@@@@@@@@ It has stopped working again. :'(
#13 wildy55
wildy55
  • 428 posts
Posted 21 October 2011 - 07:37 AM
Hey there
Can't answer your problem (sorry) but maybe you can answer mine. Pulled everything off the inner wings to spray and have everything back and working apart from the tacho. Was working fine before. It's the connections around the coil I want to check. I put an electronic module on for the ignition, so did away with the balast resistor. Do I need that to make the tacho work? So far I've worked out that the b/w wire should go to the + terminal of the coil (is this correct?). I've tired that but no luck. Can you tell me what wires you have coming from the terminals on the coil please?
#14 pauly_adams
pauly_adams
  • 1,160 posts
Posted 21 October 2011 - 12:13 PM
it must be an epidemic mine keeps working then stopping all week, it has happend to me before so i pulled it appart and cleaned it but it still would not work then one day it just started working again so its got me stumped.
wildy i went out to have a look at my setup but i cant help i have replaced that side of the wiring in my car
cheers pauly
#15 peter t
peter t
    OLD RETIRED Z FART
  • 1,902 posts
Posted 21 October 2011 - 06:45 PM
Hey there
Will have a look for you in the morning and let you know.  8)
#16 peter t
peter t
    OLD RETIRED Z FART
  • 1,902 posts
Posted 22 October 2011 - 08:50 AM
Hey there
PM sent. 8)
#17 wildy55
wildy55
  • 428 posts
Posted 24 October 2011 - 11:18 AM
Thanks for looking for me, Peter.
Got no joy with it at the mo so have tried all combinations. All but one resulted in no movement of the tacho's needle, but one combo has the needle jump slightly on cranking but then motionless when the engine's running. Any of you clever fellas know why and where to from here?
Cheers Martin
#18 BobsYourUncle
BobsYourUncle
  • 339 posts
Posted 24 October 2011 - 11:48 AM
That's how the tacho behaved on my 2+2. What sort of tacho do you have? Can you take a photo of the back of it? Can anyone confirm that the inductive loop pickup style tacho works with electronic ignition?
#19 NZeder
NZeder
  • 2,292 posts
Posted 24 October 2011 - 12:18 PM
http://forums.hybrid...__1#entry947120
I my self had a new tacho drive installed inside the stock housing so it is now setup like a modern tacho - however if that above post is correct it should be just a matter of installing a resistors - but what size and where? Who knows?
I have not read this yet but it might help (just found the link)
http://www.dinoplex....achoconversion/
#20 Daedalus-Z
Daedalus-Z
  • 33 posts
Posted 22 November 2011 - 03:41 PM
Hi Guys,
              Not 100% sure without actually pulling it out again, but I reckon my 260 has a three wire tacho and it's no better or worse using an electronic ignition module (pertronix ignitor), still occasionally jumps up to 8k or falls down to zero. Obviously wouldn't work if you went to coil on plug or anything without the distributor, or so my somewhat vague understanding of the system leads me to believe. Probably some sort of dodgy connection somewhere, but I'm not really sure where... wiring diagram for the tach is pretty simple so may actually be an issue in the tachos themselves (they are pretty old and not exactly what you'd call 'solid state' devices).
