Jimbo Posted September 7, 2011 Share Posted September 7, 2011 Any advise appreciated.... I am going to replace my t/c rod bushes but what with??. I have read (1) rubber is best--- then some say too soft (2) poly is best--- some say too harsh or (3) replace the front bush with rubber & rear bush with poly, the best of both worlds. This is what I have read on various forums!! So what has anyone on here done with their cars.. Thanks Jim Quote Link to comment Share on other sites More sharing options...
Riceburner Posted September 7, 2011 Share Posted September 7, 2011 Hey Jim, I've gone the solid front t/c kit(from ebay). These are supposed to stop castor change under braking/cornering by eliminating any compression in the bush. My brother runs them in his daily 1600 and thinks they're good also. We both found less wandering when braking and more direct steering particularly while cornering, with no added harshness. I guess it may be over kill for a daily, kinda depends on what driving you will do. Track, daily, weekender? Check these out... http://cgi.ebay.com/ebaymotors/DATSUN-510-610-710-T-C-Kit-2851610-G-Machine-/260818285606?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cb9fb3426 Quote Link to comment Share on other sites More sharing options...
zr240 Posted September 7, 2011 Share Posted September 7, 2011 Got a link for that kit gareth? Would like to get or make a set Ash Quote Link to comment Share on other sites More sharing options...
Riceburner Posted September 7, 2011 Share Posted September 7, 2011 Added link above. 1600/510 are the same kit as 240z. Quote Link to comment Share on other sites More sharing options...
DAZDA Posted September 7, 2011 Share Posted September 7, 2011 Like Gareth has pointed out, it depends on what you plan on doing with the car. If you are considering track days, etc then polyurethane bushes or spherical joints are a must for geometry control under pitch and roll. In my opinion, the polyurethane bushes really aren’t that harsh. A factor many people forget is how much ‘crush’ (preload) is put on the bush once the retaining nut is done up. Some poly bush kits have shorter crush tubes giving more preload on the bush. More preload = less give. Quote Link to comment Share on other sites More sharing options...
Jimbo Posted September 8, 2011 Author Share Posted September 8, 2011 Thanks for the replies Boys, My car is certainly no rocket, now a weekender, occasional trip away & the odd sprint track day. I would like to find out if anyone has heard of the rubber/poly combination & what the outcome was.. Thanks Jim Quote Link to comment Share on other sites More sharing options...
Whittie Posted September 12, 2011 Share Posted September 12, 2011 Thanks for the replies Boys, My car is certainly no rocket, now a weekender, occasional trip away & the odd sprint track day. I would like to find out if anyone has heard of the rubber/poly combination & what the outcome was.. Thanks Jim I went the full poly route and snapped the T/C rod and almost my neck in a possible accident so now religiously tell people to avoid full poly! I was barreling down the back straight at 200 kph, down hill in to a 90 degree right hander, and had the right hand T/C rod snap at the bush. I can tell you I made the corner without hitting the sand, I even didn't brown my pants but MY GOD it was close! If you want to keep the standard rod then you use poly on the front to keep from compressing and away from all the altering geometry goodness under braking and a rubber bush on the rear to make sure there is still play enough so the rod doesn't snap due to stress. Think of the rod like a paper-clip. If you use poly front and rear there is so little movement in the mount that the rod is constantly bending under suspension movement, eventually, just like the paper-clip, it will snap. Rubber on the rear allows the rod to move vertically without allowing it to squirm around under heavy braking loads. Personally, I have gone to and swear by Techo Toy Tuning spherical ball jointed T/C rods, but they really are a race only mod and are excessive on a street car, not to mention likely illegal. Quote Link to comment Share on other sites More sharing options...
Jimbo Posted September 13, 2011 Author Share Posted September 13, 2011 Thanks Whittie, I think I will stay away from poly and stay with the OE rubber front & back, which I can get. It sounds like you were lucky to get out of your predicament without any damage or injury. Jim Quote Link to comment Share on other sites More sharing options...
Whittie Posted September 13, 2011 Share Posted September 13, 2011 Don't get me wrong, poly it's still a very worthwhile upgrade around the whole car, you just have to be careful with the t/c rods. Everywhere else benefits enormously from the installation of poly bushings and they're likely cheaper than oem parts too. Quote Link to comment Share on other sites More sharing options...
Riceburner Posted September 13, 2011 Share Posted September 13, 2011 Pretty lucky escape there Whittie, especially at track speeds. I do recall seeing a beautiful Yellow Alfa gtv break a T/C rod in targa, sent him off into the shrubs and trashed the car. The T/C kits come with a measuring gauge to ensure the bushes are not overtightened and allow enough movement to prevent flexing the rods. I ran urethane for around 7-8 years, it was one of the first mods I did to the car when I got it, T/C rod bushes as well.... Maybe it was just luck that mine survived. I've never really paid that much attention to them, but I think from now on I'll be removing before events and checking them for straightness, twisting, corroision, streching of thread. It's the first I've heard of it on a zed, could it just be 30+yrs of stress and fatigue... Corrosion? Quote Link to comment Share on other sites More sharing options...
Whittie Posted September 13, 2011 Share Posted September 13, 2011 Very lucky escape! It was simply stress, the rods looked in fantastic condition. It was the first track event after the old man and I did 1000 k's around bathurst at the old FOSC meeting, so my guess is the dipper broke it. We'd raced the car for 5 years before this happened so it was very unexpected. However, the zed gurus around the country all said they'd heard of it before and use the poly and rubber trick to avoid it. Stewert Wilkins also does a custom, thicker, threaded rod that looks good if you need/want a standard looking part, otherwise for the same price you can get in the TTT rods. Be careful with them too tho, as I had one of the retaining nuts come loose and fall off :s I seem to be cursed with these rod issues! However, I came away fine and now just spend that much longer going over the car between events on the day and have a pretty extensive between race meets check list. Quote Link to comment Share on other sites More sharing options...
DAZDA Posted September 13, 2011 Share Posted September 13, 2011 ... and had the right hand T/C rod snap at the bush. Whittie, did it snap at the end of the threaded section or at the step where the larger washers sit? P.S. MS Paint for teh win Quote Link to comment Share on other sites More sharing options...
Whittie Posted September 14, 2011 Share Posted September 14, 2011 Snapped at the front, at the step you've indicated. almost had the wheel collapse under the car. Quote Link to comment Share on other sites More sharing options...
Paulo Posted October 26, 2011 Share Posted October 26, 2011 I installed the Stuart Wilkins T/C and he gave some advice re the poly products - he has experienced several customers cars with advanced deterioration with a certain product (I will leave it up to you to enquire/do your own research, but they are still on the shelves and are blue in colour). The T/c is certainly stock looking, but I doubt if you will have any problems with the retaining nut he supplies. Whittie, may be the way to go? Paulo Quote Link to comment Share on other sites More sharing options...
handsandwhich Posted October 26, 2011 Share Posted October 26, 2011 My rod is thicker than standard The rods that are on my car do not have the step down like in the drawing that DAZDA posted and are 17mm thick the whole way through so they limit the stress point where they normally can break. I have got one of those t/c bush kits like the one below, but since it won't fit over my large rod, I am willing to let them go if someone wants them for $25 + postage. http://www.ebay.com.au/itm/170700782324?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 Quote Link to comment Share on other sites More sharing options...
Whittie Posted October 26, 2011 Share Posted October 26, 2011 I went with the techno toy tuning tc rod. Nothing ever in bending, solid mounting, rod ends, it's the bees knees. It's also a race only part unfortunately so is not appropriate for every application. Quote Link to comment Share on other sites More sharing options...
Riceburner Posted October 26, 2011 Share Posted October 26, 2011 What rods do you run Tom? Quote Link to comment Share on other sites More sharing options...
Whittie Posted October 26, 2011 Share Posted October 26, 2011 www.technotoytuning.com/productdetail.php?p=668 Quote Link to comment Share on other sites More sharing options...
Riceburner Posted October 26, 2011 Share Posted October 26, 2011 Whoops I should have been more specific The other Tom aka Handsandwhich Quote Link to comment Share on other sites More sharing options...
handsandwhich Posted October 26, 2011 Share Posted October 26, 2011 Haha! I did wonder if you were asking me. I did tell a lie. The ones I have do have the step down, but the threaded section is 17mm diam and the rod is 20mm diam. So a lot more "meat" there and gives a little adjustability with the longer threaded section? Quote Link to comment Share on other sites More sharing options...
handsandwhich Posted October 26, 2011 Share Posted October 26, 2011 Personally, I have gone to and swear by Techo Toy Tuning spherical ball jointed T/C rods, but they really are a race only mod and are excessive on a street car, not to mention likely illegal. Just on a side note to this. When I last spoke to the Vicroads engineer, he told me that they would not necessarily knock back rose jointed/rod end suspension points, but he would need the technical data and strength test results (if any) before he could pass them for street use. Quote Link to comment Share on other sites More sharing options...
Riceburner Posted October 27, 2011 Share Posted October 27, 2011 Hey Tom (handsandwhich) I'll grab that t/c kit if you still got it? Cheers, Gareth. Quote Link to comment Share on other sites More sharing options...
Johnboy Posted October 27, 2011 Share Posted October 27, 2011 Just on a side note to this. When I last spoke to the Vicroads engineer, he told me that they would not necessarily knock back rose jointed/rod end suspension points, but he would need the technical data and strength test results (if any) before he could pass them for street use. Looking at these TC rods also, the following is from TTT. John We use the same rod end on all our parts. FK bearing part number RSM10T and RSML10T (right and left versions). They are massive overkill for what we use them for, but we have a lot of off road rally customers, so I design everything to handle absolutely nutty abuse. In 10 years, we've never had a single one of these rod ends fail. Full Specs here; http://www.fkrodends.com/RSMRSMT17.html Load Rating: 16,613 lb Gia & Gabriel Tyler www.TechnoToyTuning.com Quote Link to comment Share on other sites More sharing options...
Whittie Posted October 27, 2011 Share Posted October 27, 2011 Just on a side note to this. When I last spoke to the Vicroads engineer, he told me that they would not necessarily knock back rose jointed/rod end suspension points, but he would need the technical data and strength test results (if any) before he could pass them for street use. Well, there you go. The easiest thing is probably just to not let rego lapse and don't get caught :-\ John, I can vouch for the over kill of these rods, they are HUGE. 1" tube for the rod and the mount is made of 1/8" (guessing here) steel. It's not going to fail any time soon, that's for sure! They also weigh a metric tonne tho, a kilo or more each compared to the standard rods. You do neeed to keep an eye on the nuts that hold the rod-end to the body mount, I had one rattle loose and fall off, which was totally my fault for not checking they were tensioned. TTT make all of their stuff far stronger than it needs to be, it's one of the reasons I have pretty much their entire catalogue installed on my car now, purely ease of mind knowing I'm not going to snap something like I did with the standard t/c rod. Quote Link to comment Share on other sites More sharing options...
handsandwhich Posted October 27, 2011 Share Posted October 27, 2011 Thanks for posting that info Johnboy. I will ask the gingerbeer about it next time I see him. T/C kit sold to Gareth. Quote Link to comment Share on other sites More sharing options...
