Looking for 16x10/16x11 or 15x10/15x11 Wheels
32 replies to this topic
#21 benny
benny
  • 1,734 posts
Posted 23 June 2011 - 04:51 PM
how about when you get your desired wheels and flares you go to the tyre shop and get them to mount up a 205 and a 225 to find which is better??
#22 1600dave
1600dave
  • 627 posts
Posted 23 June 2011 - 05:18 PM
Arrow wheels ?
http://www.arrowwhee...tom Wheels.html
#23 Riceburner
Riceburner
  • 3,266 posts
Posted 23 June 2011 - 08:15 PM
It might pay to check what the legality regarding tyre stretching and camber are. Those zeds look cool but Vic roads and the fun police might not think to highly of them.
After all we do live in the nanny state  :-\
#24 saxon
saxon
  • 407 posts
Posted 24 June 2011 - 09:19 AM
Good point.
Arrow wheels ?
couple grab me. emailing them, thanks.
Yeah.. I've seen a zed lowered to 10cm... it's not as mean. I'll probably just end up going a little bit beyond what's legal and if when I get defected I'll just take it on the chin.
#25 gav240z
gav240z
    Administrator
  • 12,969 posts
Posted 24 June 2011 - 09:34 AM
I hate to state the obvious but as cool as these cars look aesthetically when this low and wide. Practically when you drive on the roads and try and avoid every pot hole it's not so fun. I just hope you realise it's going to scrape and smack into everything?
Not trying to kill your dream or anything, but have you ever driven a car this low?
It's also going to destroy the underside of the car, which might be ok if you don't mind the repair bills but most Z's are pretty tired now and rusty underneath so you could be driving like Fred Flintstone yabadaba dooo! if you get my drift?
Not to mention you could end up destroying the handling going too low. Given your control arms will be at different angles (causing bump stop) and your struts could bottom out / not have enough travel.
I don't know if you are thinking of coil-overs or not? But it would be a good idea, that way you can drop it on it's arse for photos or what have you and raise it again for driving on the street?
#26 saxon
saxon
  • 407 posts
Posted 24 June 2011 - 10:02 AM
Be positive dude! We all have a dream of how we want our car to look. My dream is just slightly less practical than everyone elses. I'll make it work... somehow.
#27 luvemfast
luvemfast
  • 4,147 posts
Posted 24 June 2011 - 10:19 AM
Seen these guys recommened elsewhere.
http://www.newaywhee...au/profile.html
#28 saxon
saxon
  • 407 posts
Posted 24 June 2011 - 11:42 AM
Couldn't find anything about buying wheels on that site. Couldn't see anything beyond repairs and maintenance. Cheers.
#29 luvemfast
luvemfast
  • 4,147 posts
Posted 24 June 2011 - 02:31 PM
Try calling them and speaking with someone.
I have heard they can do custom jobs.
#30 bryan3976
bryan3976
  • 365 posts
Posted 25 June 2011 - 02:29 PM
15x9 -10 will sit the same as a 10 +2
#31 NZeder
NZeder
  • 2,292 posts
Posted 25 June 2011 - 02:43 PM
But at 10 +2 you will have spring perch and strut clearance issues vs the 9 -10 which will have 1" less backspace.
This will help - stock spring perches you need around 4.5-4.6" backspace to be safe. Coil overs depends on the length of springs you run (a hard 8" aka 200mm should sit above the wheel) but 5.25" is the largest I have heard of.
http://www.autoloung...irespacing.html
#32 saxon
saxon
  • 407 posts
Posted 27 June 2011 - 02:21 PM
Yeah was looking at 10 with a decent amount of negative offset, not +2.
I have been using http://www.willtheyfit.com/ and comparing wheel/tyre combinations to what has been on cars I like, to check that everything is possible and will look similar to what I want. It gives me a nice little picture of what they will look like. So I don't think I should run into any problems now in terms of getting wheels that don't fit.
#33 Agno
Agno
  • 1,335 posts
Posted 01 July 2011 - 03:03 PM
I would maybe recommend using some cheap wheels with known offsets and then using spacers to make them sit the way you want. That way you can very cheaply see what your optimum offsets are.
Just don't drive on the street on 40mm worth of spacer :P
