Fuel Hose Sizes eg. AN6 AN8
5 replies to this topic
#1 benny
benny
  • 1,733 posts
Posted 27 May 2011 - 10:34 AM
Hey Guys,
Quick question on say an AN6 hose does this mean that the I.D is 6mm and the same on an AN10 is it 10mm I.D??
Benny
#2 RB30X
RB30X
  • 1,981 posts
Posted 27 May 2011 - 11:48 AM
http://en.wikipedia.org/wiki/AN_thread
Why for you ask this here question young Benny?
#3 NZeder
NZeder
  • 2,292 posts
Posted 27 May 2011 - 11:50 AM
AN is a thread standard it does related to a pipe size but does not have to. I have AN6 fittings weld on my 8mm fuel hardlines.
#4 benny
benny
  • 1,733 posts
Posted 27 May 2011 - 11:53 AM
just ordering some different fuel hose and want to make sure i get the right stuff!!
cheers for the info!!
#5 RB30X
RB30X
  • 1,981 posts
Posted 27 May 2011 - 11:58 AM
-6 is heaps big enough for fuel, but only use this hose for the dash (speedflow) fittings.
If this is just for your normal barb fittings on your carbs and normal fuel line get 1/4 or 3/8 etc
#6 jamo240
jamo240
  • 429 posts
Posted 27 May 2011 - 07:41 PM
Hey Benny
AN refers to the American standard 'Ármy Navy'...hence ÁN'.
AN6 refers to 6/16 outside diameter (OD) of the tube. Hence the tube would have an OD of 3/8". The inside diameter (ID) of the tube is not specified under this system, hence the ID can vary depending on the application and material...there is a way of determining this too, depending on material etc. In the case of hose, it can generally be assumed AN6 corresponds to 6/16 (3/8) ID. Obviously the ID of hose is generally set up to match the OD of (metal) tube.
AN8 relates to 8/16 or 1/2"diameter, and so on.
For fuel, AN6 is plenty.
