What Ampage fuse for fuel pump wiring.
22 replies to this topic
#21 zeds4ever
zeds4ever
  • 870 posts
  • Tagline:Old Member
Posted 09 January 2012 - 07:33 PM
;) These figures would be suffice to cover the max length used in most vehicles.It stands to reason that the longer the wire more volts are reqd to force the reqrd Amps thru.
                                                        Regards: Alan.  :D
#22 Six_Shooter
Six_Shooter
  • 736 posts
  • Tagline:Canuckian
Posted 18 January 2012 - 07:55 PM
                                                        Regards: Alan.  :D
That's not how electricity works though.
If there is too much resistance in the wire the current will go up, which causes the wire to heat up, which causes increased resistance, which causes the current to rise, which causes more heat.....
Including the wire length in the spec "max current capabilities" of wire gauge is very important. There are some wire lengths in vehicles that are only a few inches, while others are several feet long, which can change the required wire gauge drastically.
#23 peter mc
peter mc
  • 1,573 posts
Posted 18 January 2012 - 08:17 PM
mate your car has a aftermarket loom autronic from memory and they have a 15a fuse for the fuel pump for a 044 style pump .but if you have a lift pump as well you should run a separate relay and fuse or you may have a problem
