Prince GTB Carbon Fibre Airbox - expressions of interest
52 replies to this topic
#41 Riceburner
Riceburner
  • 3,261 posts
Posted 11 October 2013 - 07:02 PM
I thought I may as well post here as it's semi related. I ended up going with this air box from R-factory, Aluminium backing plate, fibreglass outer with a knife edged 'egg ring' with steel mesh screen fitted. It's bewdiful  :-* Most important is it will let me run big stacks.
Will the mesh effect air flow into the box, it's similar to flywire only it's stainless steel?
This one is for Alan Fields, what brand airfilter do you use in the 280 airbox? My plan at this stage is to duct it in a similar style to your green 260Z.
Thanks, Gareth.
#42 NZeder
NZeder
  • 2,291 posts
Posted 11 October 2013 - 07:13 PM
Well done the R-factory item is a nice unit, tappered like the Prince/Nissan item and as close as you can get in an aftermarket unit.
#43 Riceburner
Riceburner
  • 3,261 posts
Posted 11 October 2013 - 07:28 PM
I'm considering cutting out the mesh, if it will improve the airflow.
Without your suggestion Mike I may have never even considered it, Thanks.
#44 benny
benny
  • 1,733 posts
Posted 11 October 2013 - 08:27 PM
Any sort of material introduced into the intake system will have some effect on flow/performance i guess it just depends how much(if even measurable)
#45 luvemfast
luvemfast
  • 4,136 posts
Posted 11 October 2013 - 09:35 PM
Loose the mesh.
Especially if your running a filter in front of the radiator.
#46 260Coupe
260Coupe
  • 596 posts
Posted 12 October 2013 - 09:52 AM
[quote author=Gareth. J. link=topic=9091.msg139874#msg139874 date=1381482145]
Hi Gareth
I use a 280z filter housing (from the US 280z - S30 body with injected L28)......can be found on Ebay for very little $$$ although shipping can be exy from the US......think mine cost around $50 all up plus another $50 to sand blast and powder coat
Filter is R31 Skyline.....fits perfectly.
#47 NZeder
NZeder
  • 2,291 posts
Posted 12 October 2013 - 03:51 PM
That is what I will be running also - and I am yet to purchase a K&N Panel Filter for the factory S31/HLS30 aka EFI Fairlady Z (S31) and USDM EFI 280z (HLS30 - not to be confused with the HLS30 USDM 240z lol)
#48 Riceburner
Riceburner
  • 3,261 posts
Posted 12 October 2013 - 06:59 PM
Thanks Alan.
Mike, I did see uni filter do a washable filter for the R31 skyline, looks to be the same material as their socks.
#49 NZeder
NZeder
  • 2,291 posts
Posted 13 October 2013 - 07:54 AM
Thanks Alan.
Looking up the unifilter catalog R31 = TT267-155S a Z31 = TTN-4200S if I lookup a cross reference for the K&N for the 280z (USDM) I find the following.
K&N = 33-2010 (correct for the 280z and Z31 300ZX) this cross references to Ryco A345 which cross references to TTN-4200S
Going backwards from the R31 I get
TT267-155S = Ryco A360 = K&N 33-2031 which as K&N have the sizing on their site is thinner and other dimensions are slightly different
K&N 33-2010 = 35mm H, 270mm L, 156mm W
K&N 33-2031 = 29mm H, 279mm L, 167mm W
#50 BAM083
BAM083
  • 33 posts
Posted 14 October 2013 - 07:47 PM
Has anyone got a link to where to buy the R-Racing airbox? Have had a google but can't seem to find them.
#51 NZeder
NZeder
  • 2,291 posts
Posted 14 October 2013 - 08:06 PM
not r-racing but r-factory see here http://www.r-factory.com
#52 NZeder
NZeder
  • 2,291 posts
Posted 14 October 2013 - 08:20 PM
I found the message from Alan who confirmed the R31 filter does fit the stock 280z (HLS30)/Fairlady Z (S31) factory housing I must have been blind when I posted that stuff above.
So I will pickup one up soon.
#53 Riceburner
Riceburner
  • 3,261 posts
Posted 14 October 2013 - 08:40 PM
Airbox measurements are roughly: 670mm long, 135mm deep at the front tapering down to 110mm at the rear, 160mm high. Check your engine bay clearance, especially to the strut tower.
