Prince GTB Carbon Fibre Airbox - expressions of interest
52 replies to this topic
#1 260Coupe
260Coupe
  • 596 posts
Posted 13 April 2011 - 12:44 PM
Hi guys
I went and met Freddy from Topstage Composits today and got a price on reproducing my Prince GTB airbox in carbon fibre. (BTW his work is first class!)
The price on a repro airbox in 100% carbon fibre will be $450 ex gst if I can get a minimum of 10 (ten) firm orders (this is my break even price).
Once I get 10 orders I will then request a 50% deposit to cover materials and initial labour (CF is exy at $85 per sq/m) , I will then remove the induction system from my Zed and get Freddy to start work on the mould. (Allow four weeks to manufacture mould and 10 x air boxes)
The airbox will be supplied with a blank rear panel to be hole cut as required so it can be fitted to most triple carb applications
(Ram tubes and 90 deg elbow not included in price)
The benifit is that this airbox is dyno proven, slim line and allows for crank case and rocker cover venting to be connected (EPA friendly)
Alan Fildes
Life Member
NDSOC
#2 Riceburner
Riceburner
  • 3,266 posts
Posted 13 April 2011 - 12:49 PM
This would be fantastic. Definately put me down for one Alan! Thanks.
#3 Zedman240®
Zedman240®
  • 5,198 posts
Posted 13 April 2011 - 01:25 PM
Hoping the funds will allow but yeah...I'd be in it..
#4 GV260
GV260
  • 203 posts
  • Tagline:HS30 000408 Concourse Tarmac Rally Car
Posted 13 April 2011 - 01:26 PM
Will it come with the vent hole already pre-drilled? If not then I will order one as well.
#5 260Coupe
260Coupe
  • 596 posts
Posted 13 April 2011 - 01:48 PM
there will be no holes in the airbox at all (only the 80mm inlet hole in the top cover) so you can cut holes to suit your particular application (triple carbs, injection throttle bodies etc)
BTW- shipping interstate at additional cost
So we have
Gareth
Dimitri
GV260
I may get a few more buyers at the Zed Nationals over Easter to make up further numbers
cheers
Alan
#6 benny
benny
  • 1,734 posts
Posted 13 April 2011 - 02:56 PM
us there an option for glass only as a cheaper alternative to make up numbers?
#7 260Coupe
260Coupe
  • 596 posts
Posted 13 April 2011 - 04:07 PM
There may be some possible savings if made in F/G however the glass will be considerably thicker to get the same rigidity, labour is the same so it will only be the materials cost saving.
I will look into a Fibre Glass option
Alan
#8 260Coupe
260Coupe
  • 596 posts
Posted 14 April 2011 - 01:24 PM
Fibre Glass option could be made available for aprrox $270 ex gst
#9 mossy
mossy
  • 1,788 posts
Posted 14 April 2011 - 01:32 PM
Put me down Alan for a F/glass one.
I notice the MJP airbox comes in a mesh pattern glass mat which looks similar to carbon, I wonder if the topstage one will be the same?
#10 GV260
GV260
  • 203 posts
Posted 14 April 2011 - 01:37 PM
Can you clarify how much thicker (ie depth measurement increase) the FG version would be?
#11 260Coupe
260Coupe
  • 596 posts
Posted 14 April 2011 - 02:18 PM
No idea on the thickness of the F/G V's the C/F until the mould and some prototypes are made............and these can't be made until I get 10 x firm orders with deposits
Sort of a chicken and egg thing
Alan
#12 NZeder
NZeder
  • 2,292 posts
Posted 14 April 2011 - 05:19 PM
what would it look like if mounted on the other side of the engine bay aka a triple throttle bodies RB engine ;) no idea what the bottom looks like and if flipped would look ok? I could be down for one if it looks good when flipped. Not sure if F/G or C/F
Don't worry about my location I will have some in Melbourne collect and store for me ;)
#13 mossy
mossy
  • 1,788 posts
Posted 23 April 2011 - 08:45 AM
C'mon guys, we need some more! :)
#14 Sirpent
Sirpent
  • 2,294 posts
  • Tagline:John.O.
Posted 30 April 2011 - 09:55 AM
Geeeeeeeeeeez
Looks like this died a quick death, what happened?
#15 mossy
mossy
  • 1,788 posts
Posted 30 April 2011 - 12:15 PM
Looks like there was only around 6 interested :(  I might have to look at the MJP box then.
#16 Kent
Kent
  • 149 posts
  • Website:http://www.project240k.com
Posted 10 May 2011 - 01:09 PM
if it ever pans out, you can put me down for a fiberglass one.
where would you get the elbow pipe attached to the box shown in the picture?
Kent
#17 260Coupe
260Coupe
  • 596 posts
Posted 11 May 2011 - 11:54 AM
Kent
still not enough committed interest to warrant making the mould
90 deg elbows in various sizes can be sourced from auto and truck supply specialists.........there is a local supplier here in Melbourne where I found the silicon 80 to 65mm reducer
Alan
#18 Kent
Kent
  • 149 posts
Posted 11 May 2011 - 12:31 PM
no problems.. just let me know if the numbers do eventually get up there.
thanks
#19 NZeder
NZeder
  • 2,292 posts
Posted 14 August 2013 - 08:53 AM
Can we try and get this going again for the 3rd time?
I would be down for 1 100%
#20 Riceburner
Riceburner
  • 3,266 posts
Posted 14 August 2013 - 02:21 PM
Would it be possible to get some dimensions Allan, especially the depth of the outer half of the airbox. As you know, I have an odd ball setup with long ram tubes, but I may be able to customize it to fit.
Would it be ok to buy just the outer half?
