Larger AFM for a 280zx
33 replies to this topic
#21 stevofoxono
stevofoxono
  • 309 posts
  • Tagline:My quarter life crisis car Z
Posted 10 May 2011 - 08:40 PM
just tried.. no success :(
#22 peter mc
peter mc
  • 1,573 posts
Posted 10 May 2011 - 08:56 PM
G'Day Mate,
Try removing the plug from the air flow meter and look at the terminals to make sure that they are still in the right position, some times when you remove them and replace them the terminals slip back into the plug.
Also check the wiring behind the plug to make sure you don't have a broken wire.
Don't replace any other parts at this stage, as the fault was introduced with the air flow meter.
#23 Pacey
Pacey
  • 33 posts
Posted 10 May 2011 - 09:42 PM
Hey guys
Sorry to hear you have a couple of issues.
I didn't have a problem with the throttle body side of the AFM size, cause I had a larger 70mm throttle body from a Commordore on there, Galderdi you mentioned that the throttle body side of the Toyota AFM was 90mm, this doesn't sound correct, I'm sure mine was 75mm to 80mm no more, I might remeasure it tomorrow and check.
Does the Toyota AFM look the same as my pictures ??
Stevo
Not sure why you have the idling problem, did it run ok ??
Maybe check the water temp sensor for the ECU, I had this problem recently when the plug came loose, and the car wouldn't idle, was extremely rich.
Alan
#24 .
  • 1,083 posts
  • Tagline:Past member
Posted 11 May 2011 - 10:42 AM
Yeah you are probably right I was working from memory. 80mm does sound right. Yes it is identical to the one in your pic other than the code numbers.
#25 stevofoxono
stevofoxono
  • 309 posts
Posted 11 May 2011 - 06:07 PM
still no luck.. I've got the camry+280 afm and neither of them make my car work. I've got a feeling its the plug.. would cutting the wires and crimping on the camry plug work? gonna check compression+change over the coil leads tomorrow
#26 .
  • 1,083 posts
Posted 11 May 2011 - 06:46 PM
I tried mine this afternoon. I had a bit more luck the car wants to run but is hunting on idle. I'm not sure where to look for the cause. Any suggestions? Maybe an adjustment of the bypass?
#27 Pacey
Pacey
  • 33 posts
Posted 11 May 2011 - 07:07 PM
Wow, I'm amazed, I had no such things happening at all.
Galderdi, you might need to adjust the coil spring if it is hunting, maybe running to lean or rich at idle, first I would try the idle air adjuster on the Toyota AFM there is a cap in the same position as the 280z AFM has for adjusting the air flow that goes thru the AFM for idle air ratio, if you haven't drilled out that cap, it's time to do so..
Better still if you had and Air Fuel gauge, but you will tell straight away when you adjust the screw..
Stevo
I wouldn't be cutting and crimping just yet, pull the original plug to the AFM on the 280z loom apart and check it out. Try a multimeter test for resistance on all pins. Then maybe try and test the wires back to the ECU, maybe a wire broke when you were first changing the AFM.
Are the injectors clicking ??
Is there voltage at the AFM when cranking ( test the larger prong in the Toyata AFM with a multimeter, should be a small voltage there when cranking 2 - 4 volts ??
Have you checked the water temp sensor.
Let me know how you go guys.
#28 .
  • 1,083 posts
Posted 15 May 2011 - 12:16 PM
OK so I proved that the AFM was my problem bt leaving it in but pluging the old one in and jamming it open with a screw driver while I started the car....no issue. So I took the new one back out and checked the resistance values, the ranges were similar to the nissan item but the pins were in a different order. So I have made an adaptor out of a spare EFI harness swapped the pins over and I seem to have solved the issue.  Wooo hooo!!!
#29 stevofoxono
stevofoxono
  • 309 posts
Posted 15 May 2011 - 08:07 PM
there are 7 pins in the camry plug comparing the 5 in the datto. Any improvement using the camry one? To me both look the same except for the plastic lid on the side
#30 .
  • 1,083 posts
Posted 16 May 2011 - 10:52 AM
I will be able to answer with a direct comparison of track times after Saturday. The Toyota unit is significantly bigger. The smallest part of the air passage with the flap fully open is (by looks) around 15-20% bigger. So I suspect performance would be unchanged until you exceed the air flow through the smallest part of the nissan unit. In other words it should extend the power at full revs with full throttle.
#31 Pacey
Pacey
  • 33 posts
Posted 16 May 2011 - 05:13 PM
Galderdi
Yeah my performance was much better over 4000rpm but also idles much better.
Still love the new AFM.
Not sure why the rewiring had to happen, my loom has only five pins that went directly in without change.
I know the Toyota AFM has two additional pins for the fuel pump cutoff but that doesn't come into play on my loom.
Glad to hear you've got it going..
Now it's time for a Jaycar Digital Fuel Adjuster, I have had one for a while, and gives me lots of control over the AFM to ECU voltages..
Alan
#32 PZG302
PZG302
  • 1,778 posts
Posted 16 May 2011 - 06:24 PM
Not quite Greg, though times will give you an indication if the new AFM has made a difference, but there are way too many variables for a direct comparison of performance. Also will depend on what other mods you have done since the last day out and even down to the number of heat cycles through the tyres you are using.
#33 .
  • 1,083 posts
Posted 16 May 2011 - 09:13 PM
I agree with the logic but in my case it has only been a few months, no other modifications and only one extra heat cycle on the tyres (and that was in wet conditions so I'm not sure if it even counts). The only other variables worth mentioning are track and air temp but we'll have to wait and see on those.
By the way I had the bonnet open on my 93 cruiser tonight and the AFM in there looks the same as the 99 camry unit.
#34 PZG302
PZG302
  • 1,778 posts
Posted 17 May 2011 - 07:56 AM
About the only way to get a direct comparison on any engine mod is to do a power run on the dyno, swap the component and then do another run as soon as possible after to ensure all conditions are as consistent as possible.
Looking at the weather and the rain we have had, don't be suprised if times are a little slower as the track may not have a lot of rubber on it. Air and track temp should be good for the day though.
