sexual_sushi Posted April 11, 2011 Share Posted April 11, 2011 If it's rock hard when you put your foot down is that a type of foot fetish? Sounds like an interesting day haha. Would love to hear the feedback about the conversion, I think I have r31 brackets lying around here somewhere.... Quote Link to comment Share on other sites More sharing options...
MaygZ Posted April 11, 2011 Share Posted April 11, 2011 I can now confirm that there was No problem with air in the system, seems the 'NEW' Master cylinder was faulty and caused all the drama at the end of the day. I replaced it with my old Tokico one and now have a Rock Hard pedal. Scoota, have you pulled the master cylinder apart? What was wrong with it? Quote Link to comment Share on other sites More sharing options...
Scoota G Posted April 11, 2011 Share Posted April 11, 2011 Scoota, have you pulled the master cylinder apart? What was wrong with it? Be doing that tomorrow so will advise, Sierra Coca Oscar Oscar Tango Alpha out. Quote Link to comment Share on other sites More sharing options...
luvemfast Posted April 11, 2011 Share Posted April 11, 2011 Charlie not Coca Delta Alfa Golf Quote Link to comment Share on other sites More sharing options...
Riceburner Posted April 11, 2011 Share Posted April 11, 2011 Rodger, what's your vector victor? We need more clearance Clarence Quote Link to comment Share on other sites More sharing options...
Moderators Zedman240® Posted April 11, 2011 Moderators Share Posted April 11, 2011 Rodger, what's your vector victor? We need more clearance Clarence Under, over, over, done. Quote Link to comment Share on other sites More sharing options...
Scoota G Posted April 13, 2011 Share Posted April 13, 2011 Charlie not Coca Delta Alfa Golf Actually i can think of anothe "c" word more fitting than that. Quote Link to comment Share on other sites More sharing options...
KatoKid Posted April 13, 2011 Share Posted April 13, 2011 Sierra Charlie Oscar Oscar Tango Alpha did you take photos particularly for handbrake mods? Quote Link to comment Share on other sites More sharing options...
Scoota G Posted April 13, 2011 Share Posted April 13, 2011 We found a very easy way of modifying the handbrake, if you shorten the stock R31 handbrake Bracket and bolt by 50% and use right Caliper on right side, left on left, the Handbrake hooks up in almost a stock Position. The bracket is a bit thick and also the hole is a bit small. A little grinding and you're ready to rock. Dimitri's also has another way of hooking it up which we should get a photo of. I just got a 1 Inch Master today so i'll fit that and we'll do a write up. Quote Link to comment Share on other sites More sharing options...
Gyra Posted June 19, 2011 Share Posted June 19, 2011 Hi folks, I'm just in the middle of putting the R31 rear brakes on my 240. It seems to be taking a massive amount of stuffing around! Scoota, did you mount the calipers up top (12 o'clock position)? How much clearance did you get between the handbrake cable and the axle flange? I found that shortening the handbrake bracket by 12mm seems to give the right length of travel for the 240 cable. Thanks, G Quote Link to comment Share on other sites More sharing options...
Scoota G Posted June 20, 2011 Share Posted June 20, 2011 Hi folks, I'm just in the middle of putting the R31 rear brakes on my 240. It seems to be taking a massive amount of stuffing around! Scoota, did you mount the calipers up top (12 o'clock position)? How much clearance did you get between the handbrake cable and the axle flange? I found that shortening the handbrake bracket by 12mm seems to give the right length of travel for the 240 cable. Thanks, G You'll need too mount the calipers facing toward the front of the car, at 12 o'clock they will foul on the strut. Also you will need to suspend the hand brake cable by a spring or cable tie, it's close but it still goes. I really need to do a write up on this, does the oracle have the photos? Quote Link to comment Share on other sites More sharing options...
C.A.R. Posted June 20, 2011 Author Share Posted June 20, 2011 Yes. Quote Link to comment Share on other sites More sharing options...
Scoota G Posted June 20, 2011 Share Posted June 20, 2011 Yes. Cool, do you want to send them to me and i'll do the write up or how would you like to do it? Quote Link to comment Share on other sites More sharing options...
C.A.R. Posted June 20, 2011 Author Share Posted June 20, 2011 PM me your email addy & I shall send them over. Quote Link to comment Share on other sites More sharing options...
