Sign in to follow this
Scoota G
Engine Weight Chart
Thats Brilliant Scoota !
Should drop it into a spread sheet and post it in this thread.
John
Share this post
Link to post
Share on other sites
Mmmmmm supercharged Jag 4.2 now youre talking Scoota!
Share this post
Link to post
Good info Scoot, I had considered for awhile, dropping a Jag V12 in one of the Z's, I have 2,.... V12's............and Z's.
weight was a worry.
I dropped a P76 alloy V8 into an Anglia sportsedan  in the 70's, not a lot of BHP but just a tad less Toque than the L34 Torana V8. :)
that really got mobile :)
V12's have alot of torque ::)...............the 300BHP wouldnt go astray either ;D
Share this post
Link to post
the V8 Anglia? Amaroo hill climb...........19secs......... Amaroo Main......61's.. only run those 2 as I sold it shortly after....lots of potential :)
V12  Z. still looking at that, I have 2 Jag/ Daimlar V12's and a spare V12. no gearbox...have 2... 2seaters an a 2+2
one 2 seater is getting the L28/P90/webers treatment...........bit like a 240 I had back in 1970ish, webers,E31/L26.....180BHPRW @5000 but have learned abit since then.
I have an early 240 but wont stuff it with mods as some do, all original chassis/engine number, even have the original wheels/wheelnuts/hubcaps.
I saw a Z somewhere with a Jag V12 fitted, 5.2 which I think is a 327? make a good hill climber :)
Share this post
Link to post
how fast did it go back in the 70's?? ;)
Lap Times?????
;D ;D ;D ;D
Behave You Two!!!!!
Share this post
Link to post
What does a stock L24/26/28 weigh? The one in the chart looks like it must only be a four cylinder L-series. Cheers. :)
Share this post
Link to post
Rough estimate that should be close to the mark, devide the L4 weigth by 2 and multiply by 3 LOL
Share this post
Link to post
that kind of works, doesnt it? ;D
only if you put down the 5 and carry the 83.......LOL
Share this post
Link to post
Either that John or the answer is too heavy! I have had to lift the things with one other person and they weigh a ton or thereabouts! ;D
Share this post
Link to post
other person ,they weigh a ton or thereabouts! ;D
Brabham, is that the engine or the other  "person"? LOL
Share this post
Link to post
Trying to lift the engine and the other person is even harder I have found ;D They also usually object to being attached to the engine crane ;D
Thanks for the weight picture roastbeef, very informative. Wonder if there is much difference between L24/26/28, the blocks were all they same external dimensions, only bored out, were they not?
Cheers.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
