Light Weight 240z?
71 replies to this topic
#61 .
  • 1,083 posts
  • Tagline:Past member
Posted 02 July 2009 - 06:41 PM
4th is straight through anyway isn't it??? If so ditch the gear box and connect a drive shaft to the crank  ;D
#62 sco_aus
sco_aus
  • 2,484 posts
  • Tagline:Scott
Posted 02 July 2009 - 06:46 PM
4th gear, 4.4:1 ratio diff and we are off
#63 .
  • 1,083 posts
Posted 02 July 2009 - 07:27 PM
Now we just need to work out a way to eliminate the diff.....I'm thinking some sort of belt arrangement.
Then there's the suspension. Maybe a few tenis balls in some conduit.
Steering = a couple of cords run down to the front wheels
We'll have this car down to 100KG before you know it :)
#64 waxhead
waxhead
  • 533 posts
Posted 02 July 2009 - 09:11 PM
you could cut the floor out under the seats
you dont need them and you can chuck your rubbish straight on the road no one will know it was you
plus getting rid of rubbish will keep car lighter
#65 Zeddophile
Zeddophile
  • 987 posts
Posted 02 July 2009 - 09:41 PM
if you make a hole in the seat to go with the floor hole, it serves two purposes:
When you crap yourself coming into that corner way too hot, it doesn't stink out the car, and you get lighter (therefore faster, causing you to release more excess 'weight' at the next corner  ;D)
#66 waxhead
waxhead
  • 533 posts
Posted 02 July 2009 - 09:54 PM
But what does the sphincter grab when your coming into hot. your better of removing the brake pedal
Less weight and it will definitely increase your corner speed
#67 Zeddophile
Zeddophile
  • 987 posts
Posted 02 July 2009 - 10:21 PM
very true.... Might as well cut the floor away under the pedals too, so you can push the accelerator down further.  That makes you go faster, right?
*edit* in the interest of keeping some sensible discussion going among all the crap thats flying around  ::), I'm surprised no-one has mentioned the benefit of reducing rotating masses - flywheel, balancer, tailshaft, wheels, brake rotors.....  You get a small weight reduction, but also the benefit of a bit less driveline power and torque losses.  Small gains, but it all adds up.
Pity you can't machine as much off a Zed flywheel as an Alfa, but on the flipside zeds don't have a bloody great big tailshaft spinning at engine speed with another flywheel at the other end!  And yes, the ring gear was working its way off the standard flywheel  :-\
#68 V8Datto
V8Datto
  • 223 posts
Posted 02 July 2009 - 10:26 PM
But seriously, I removed the roof skin off my 240z the other day and dam....... at least 3 times heaver than I was expecting. no KG amount yet
That weight is sitting up at the highest point of the car too, Didn't benzed or someone do a CF roof skin? probley very $$ and it's a structural part aswell
#69 Zeddophile
Zeddophile
  • 987 posts
Posted 02 July 2009 - 10:46 PM
If you have a roll cage though, the roof is probably nowhere near is critical as it would otherwise be.  If you can work out how to bond the CF roof on properly, it would be probably stronger than the steel - the Alfa Romeo SZ actually used a carbon fibre (or similar composite) roof from the factory, it acchieved (I believe) the highest lateral G-force of any road car at the time.  Also, many late model cars have the windscreens bonded in with urethane - in these cars, the windscreen is an integral part of the cars structural rigidity!
Photo shows you just why it was dubbed 'Il Mostro' (the monster).  Ugly, but very brutal.
#70 Add
Add
  • 181 posts
Posted 02 July 2009 - 11:53 PM
Has anyone suggest a Carbon Fibre or a lightweight composite tailshaft? I imagine that some weight could be lost here.
#71 NZeder
NZeder
  • 2,291 posts
Posted 03 July 2009 - 07:06 AM
Lots of good ideas (some that put a simile on my face reading them).
There is a guy in Japan that makes the following parts all in GRP - and I am sure with enough $$ CF could be made to.
1. Roof
2. Guards - all corners fron and rear (rear goes up to the roof line = matches his roof)
3. Bonnet
4. Panel between bonnet and screen (you know where the wipers go)
5. Sills
6. Doors
So that is basically the whole outer of the zed. Put a cage in with all this lot. Use a R180 with good LSD centre, stick with a L6 box and don't go to a SR/RB 71C as they are heavier (just a bit), convert to CV's and use some light weight alxes and the CF drive shaft. Put all these body panels on with either alloy rivets or bolts. Stick with rotors that fit with-in 14" rims (maybe 15") ie 11" rotors front and rear (stock is 10.8" on the front and 9" drum - but all you guys know that :) ) so 280mm x 20mm and some alloy 4 pots. Get the lights 3 piece rims you can find/afford (and don't hit the ripple strips or they might bend if they are that light). Sticking with 14" rims for lighter rubber. So now work the steel that is left in the car. Use hole punches were possible to take extra metal our of the car
Install FG/CF dash with alloy frame - remove heater and all extra not needed - strip the loom down to just all that is needed and no more and replace with smallest gauge wire possible for the given current draw.
Strip all sound proofing off the uni-body put just enough paint on to cover and give the colour required and no more. Use lexan for the side and rear windows. Remove the window regs and have the lexan window either with a sliding window or just a leather strap with holes that hock into a latch to set the ride height of the window (aka early morris minor)
Maybe get one of those late model L28 rocker covers that is made of plastic and compare the weight to the stock alloy unit. Use good light weight rods, pistons and take some weight out of the flywheel and balancer.
Use the earliest 240z shell you can get as these are lighter I am lead to believe (ones with out the tool boxes is the ideal). Also use 240z suspension not the 260z stuff as it lighter (not as strong) but then the whole car will be lighter too.
The list goes on and on when you think about it. But none of this is worth effort if the driver is like me and 15-20KG overweight so I need to go on diet before my car which is why I have 260z 2 seater as they are heavier than the 240z from the start = light weight is not a concern (well I guess I should loose KG before the car)
#72 Scando
Scando
  • 932 posts
Posted 03 July 2009 - 01:10 PM
I saw some good tricks in my kart racing days.  Hole saws through plastics and the fibreglass seats.  Tie rods taken to with a file, etc.  Funnily enough, the poeple that did this didn't seem to finish many races......
