acf321 Posted February 1, 2011 Share Posted February 1, 2011 How long is a piece of string? It is a bit like that, but given I have not driven a 240Z for at least 10 years, but am very close to getting the 'Brown Hornet' on the road, I wanted to ask all you experts (because you actually have the ability to drive the things), and boffins (because you can probably work it out), what type of 0-100kph you think my car will get, and its top speed, based on a series of inputs. Ok... So as you know, I have build a very standard 1971 240Z, with the exception of the now rather worked engine. So what do you think is a reasonable estimate of what it should / could do? assuming; - NA 250hp L24, with very light flywheel and internals, on 10.9:1CR - standard L26 tranmission, so assume factory delivered gear ratios. - standard 3.9:1 diff without LSD, but assume NO wheel spinning. That is, get it off the line to minimise 0-100 acceleration time, - OEM diameter 205/60/R15 tarmac rally style (read very sticky) purpose made rubber Reason for asking is I just saw Clarkson talk about the Mazda6 MPS, with 256HP, and 0-100 in about 6 secs. The difference between this car and my 71 zed, is about 500KG weight, and 4WD. What do you think my Zed will do? The engine IS hot, and the car has been kept 'lightish' as say 1075kg or so. Would love to know. mmm now will it be UNDER 7 secs, or UNDER 6 ?? Cheers Adam Quote Link to comment Share on other sites More sharing options...
Sirpent Posted February 1, 2011 Share Posted February 1, 2011 Adam, Id think it comes down to torque as oppossed to HP. Quote Link to comment Share on other sites More sharing options...
handsandwhich Posted February 1, 2011 Share Posted February 1, 2011 A piece of string indeed! A 240z with about 215hp pulled 6.2 seconds to 100 so you'd think you should sneak under the 6's Top speed of around 160mph maybe? Quote Link to comment Share on other sites More sharing options...
peter mc Posted February 1, 2011 Share Posted February 1, 2011 the 3.9 diff will slow you down in the 0-100 time but top speed will be around 140mph . it will be hard to get it not to spin the wheels and that will slow you down my bet low 6 or hi 5 Quote Link to comment Share on other sites More sharing options...
Whittie Posted February 1, 2011 Share Posted February 1, 2011 - NA 250hp L24, with very light flywheel and internals, on 10.9:1CR That is some engine. Is that engine power measured at the flywheel or power at the wheels? I'd say in the region of 5's for sure. But then your gearbox might not like you for long with that sort of power! Quote Link to comment Share on other sites More sharing options...
Administrators gav240z Posted February 1, 2011 Administrators Share Posted February 1, 2011 Yeah I'm guessing within the 5 seconds range. Should be interesting . Quote Link to comment Share on other sites More sharing options...
Moderators Zedman240® Posted February 2, 2011 Moderators Share Posted February 2, 2011 With my first 260 2 seater, with the throttle bodied L28 and 74' cam and a passenger (timing), 3.9 LSD and semi's on Burwood Hwy on a nice and clear afternoon, we had an approx time of 5.5 seconds as my speedo read just over the 100 Kph from a set of traffic lights. No wheelspin but just a tad of riding the clutch to avoid any. Then as I backed off the throttle, a Z32 twin turbo came from my left...I didn't even know I was running with him! Ha! Quote Link to comment Share on other sites More sharing options...
theremm Posted April 20, 2015 Share Posted April 20, 2015 Hi Adam, Digging up an old thread as I am curious to know what the final figures were. I realise that you recently sold the car. Are you able to confirm what 0-100 time you were able to achieve and with what HP/torque & performance mods? Cheers Quote Link to comment Share on other sites More sharing options...
