Some planned changes to the Marque Sports Rules
34 replies to this topic
#21 260DET
260DET
  • 2,223 posts
  • Tagline:Tribal Elder
Posted 18 October 2014 - 06:49 PM
Did some checking just for fun, the 280ZX 2+2 is Group 3J Improved Production eligible for sure, could be a good way to get into racing with something that has some real grunt. Still checking on the Z31 2+2 which is a bit difficult because it would have to pass the cabin measurement check and I have not been able to find those. Anyone know?
The Z31 would be interesting because of the range of aluminium V6 Nissan engines available although not all of them may be eligible for use. Maybe I should start a new thread on the IPRA subject.
#22 PZG302
PZG302
  • 1,761 posts
Posted 21 October 2014 - 06:19 PM
Richard, as per your question on that forum of questionable taste  ;D The Z31 is not eligible for IPRA due to space limitations and the fact it was not run or homologated as a touring car here.
The 280ZX is eligible for both IPRA and Prod Sports as it is on the list of eligible cars for prod sports and as you said ran in the old series production races, and quite well, biggest kicker in Prod Sports is the fact it would have to run the L series, and you may or may not be able to run the L28ET engine, I would have to look up the rules for that and also if there is a requirement for that spec car to have been sold here through the dealer network.
The Z31 is elegible for Prodsports, both 2F, if you want to build a very "standard" car with few mods, or 2B id you want to go a wild build. But you would have to use the VG motor only in the Z31.
The Z32 has been raced in Prod Sports in TT form, and could be made very competitive for not a lot of money if built smart. For 2F you wouldn't bother, but in 2B the car could be competitive very easily. The only problem I know if is that they can be very hard to control cooling and still comply with the rules.
I went down the S chassis path because they are cheaper, were a better base to start with and have a greater selection of aftermarket and Nissan parts from Sklines and Z chassis to bolt on to go fast.
You need to be sure which category you want to run in if playing with the 280ZX as to buid an IPRA car is very different to a 2F or 2B car. I was looking at building my S14 for both, but the compromises to fit within both sets of rules would have made it noncompetitive in both classes. I have been racing in Marque Sports and Prod Sports since the mid '90's so that's what I am building my car to.
#23 dat2kman
dat2kman
  • 4,061 posts
Posted 21 October 2014 - 06:51 PM
This will shortly be placed in the dummy spit/too hard badket, due to not getting what is intended.
Two cars is untenable.
#24 260DET
260DET
  • 2,223 posts
Posted 21 October 2014 - 07:28 PM
Once things settle down for me then it's likely I'll look at getting the present V8 280ZX log booked as a Sports Sedan, after deregistering it and adding some bodywork extensions to run wider wheels. Of course it's never going to be competitive against a proper Sports Sedan but it would be able to do the Top Gear races and still be eligible for sprints which opens up some options.
#25 PZG302
PZG302
  • 1,761 posts
Posted 22 October 2014 - 08:48 AM
Or if only wanting to run locally in brisbane run as it is in outlaws where it should go allright. You could also run in the qr300 in that spec no problems if you want to try enduro racing.
#26 Lurch ™
Lurch ™
  • 5,661 posts
Posted 31 December 2014 - 11:57 PM
Courtesy of Gordon Dobie:
In the hope of clearing up some of the confusion regarding what was and was not allowed under the CAMS reg's under which 240/260 and 280Zs where obliged to compete, I have attached a copy of the original Group D reg's from the CAMS Manual as applied throughout the time in which I competed.
These rules were basically the same as the improved production touring car reg's of the time and were quite restrictive. The intention being to keep costs to a reasonable level whilst allowing sufficient flexibility to enable the creation of very vehicles capable of very fast and close competition.
Good luck to all Z owners
Gordon Dobie
#27 dat2kman
dat2kman
  • 4,061 posts
Posted 01 January 2015 - 11:35 AM
They're a bit old, circa 1074-5, written to stop the very free and open rules that had evolved between 1970 to 1973.
Very interesting to see, now, how they have chamged, to again, be much more "free and eady" yet once again!
At least in Historics, their rules and requirements for Production Spirts are consistent and unchanging, and with some 170 Group S cars Logbooked, there are always high numbers f cars at events.
A Group S Historic is similar to current specs for Group 2F Prod Sports.
#28 PZG302
PZG302
  • 1,761 posts
Posted 02 January 2015 - 09:59 AM
There are still changes happening with the Prod Sports rules, but don't make S30 Zeds any more competitive....
You will never be able to change the L series engine for an RB or put a RB head on an L series and comply.
The SCAA is also currently reviewing the the list of eligible vehicles for 2B and 2F cars to keep it more relevant and to also have three divisions of 2B cars, Division I as per now with 500 having to be made in a 12 month period, Division II as per now with a minimum of 10 registered in Australia in a 2 year year period, allows for things like MX5 SP's (100 made) and Honda engined Lotuses, and soon, Division III to allow import cars that are eligible for registration in their home country, like the Ginetta. And also giving the old GT cars a home, but they must be as per the homologation they raced as in the GT series and to the GT rules, ie they can't take advantage of freedoms under the 2B rules.
Also Porsche Cup cars are not eligible for 2B at this stage.
The eligibility list will also add some cars like the BRZ/86 and remove some cars, generally older models that are now used in historics only.
Some of the rules in 2B are allowing some more freedoms and some are tightening up and some are fixing glaring errors, such as the rules saying that if it is not mentioned that it may be modified then it must be standard, and nothing is mentioned about computers for EFI, so technically every car with a modified or aftermarket computer is illegal in 2B, but in 2F this is legal as it mentions that computers are free.
#29 260DET
260DET
  • 2,223 posts
Posted 02 January 2015 - 03:01 PM
Far as I know there were only three circuit events for all of 2014 which specifically included Group S. Which in my opinion makes having a Group S race car not the best option if you want to race a Zed in Q. And as you have experienced Jason a Group S Zed is too slow to do other circuit motorsport at anywhere near the sharp end.
#30 Gordo
Gordo
  • 1,112 posts
  • Tagline:Racing member.
Posted 02 January 2015 - 05:21 PM
Oh no , here we go again !
#31 260DET
260DET
  • 2,223 posts
Posted 02 January 2015 - 05:40 PM
;D Just to help anyone who is thinking of getting into racing a Zed in Q, public service announcement if you like  8)
#32 1600dave
1600dave
  • 607 posts
Posted 02 January 2015 - 05:58 PM
Last time I looked, there were 14 events on the 2015 calendar ??
Admittedly not all in cane toad country, but then all the good circuits are down south  ;D
#33 PZG302
PZG302
  • 1,761 posts
Posted 02 January 2015 - 06:16 PM
Plenty of Group S events, Capricorn up here which is 4 or 5 meetings in conjunction with both QR/Lakeside and HRCC, plus CAMS championship race meetings at Morgan Park, 5 or 6, plus Prodsports sprint series, 5 events and an enduro plus the CUE enduro for prodsports that sees races in three states, plus the 300km enduro events at QR, Wakefield and Winton and then there is all the hillclimb championships and the sprint series, so plenty of racing for a Group S car.
In outright terms it will outgunned against modern and some euro machinery, but my old banger was a top 5 car in Qld Prod sports, and will do very well in class to win a season championship where results in all races are important.
#34 dat2kman
dat2kman
  • 4,061 posts
Posted 02 January 2015 - 09:47 PM
Gordon, you know i will champion the Historics!
FFS  CloudShouter, in 2014, there were, a total of, 17 full race weekends for Group S, and a further 8 where Group S cars were invited r elegible to compete.
That's 25 Weekends, not just a single day!
Your addled mind is just not up with it anymore, you cop an absolute padting on other forums from many others, we here are a bit more polite.
'Cept me!
When you do the same lap times as the top few Group S cars, at the tracks they compete at, for the race lengths they run, then we might take you seriously!
#35 dat2kman
dat2kman
  • 4,061 posts
Posted 02 January 2015 - 09:59 PM
And, a Group S Datsun Z would, without any doubt, be the best "Bangs for Bucks" australia wide, accepted category race car anyone could get into.
Even if they are , ahem, "slow"?, going by our resident Group S Ex-Spurt!
Now, who wants a ready to race, holder of class lap records at all three Qld tracks, fully sorted Datsun Z, to go have a proper play in?
