Engine stand. What size.
10 replies to this topic
#1 Bigfella
Bigfella
  • 388 posts
  • Website:http://www.viczcar.com/forum/index.php/topic,7636.0.html
  • Tagline:Owner of rust
Posted 29 August 2010 - 03:04 PM
I am looking at getting an engine stand. I am thinking that the z engine will be stored on this. So it could be there for a while.
I'm curious what experience people have had with their stands.
Most places advertise their heavy duty stands @ around 500kg, is this enough.
I found http://cgi.ebay.com....rts_Accessories this and it is rated at 900kg. Do you think it is over kill. or do you think I would be just as well off as with a $90 super cheap.
Thanks
#2 FLEXZED
FLEXZED
  • 779 posts
  • Tagline:Loui
Posted 29 August 2010 - 03:21 PM
hey Bigfella
i have a rb30 sitting on a 500kg cheap ebay engine stand for over 2 months now and havent had a problem, easy to move around etc
Also used 2 cheap 500kg engine stand to make my rotisserie
so weight wouldnt be a problem
Loui
#3 RB30X
RB30X
  • 1,981 posts
Posted 29 August 2010 - 03:50 PM
The only thing is when you move them around you have to be a little more careful with a three wheeler considering the 6 pot is quite long and there is more weight over the front wheel.
#4 FuzzyDropbear
FuzzyDropbear
  • 471 posts
Posted 29 August 2010 - 05:07 PM
Hey mate, check out your local engineering supplier, they should stock a range of engine stands that will do the job and be a lot less than the ebay one. I think I paid $80 or so for my stand.
#5 Bigfella
Bigfella
  • 388 posts
Posted 29 August 2010 - 05:54 PM
Great tip. I will have to fine my local Engineering supplier.
#6 bryan3976
bryan3976
  • 365 posts
Posted 29 August 2010 - 06:30 PM
i payed $77 for mine at super-cheap holds my engine ok
#7 Bigfella
Bigfella
  • 388 posts
Posted 29 August 2010 - 06:45 PM
Has it been on there long term?
#8 bluerat
bluerat
  • 540 posts
Posted 29 August 2010 - 11:30 PM
Mine is a Supercheap Jobbie Big'n, and my poor lonely L28 has been on it since  late 2008 with no problems, hope this helps.
#9 NZeder
NZeder
  • 2,292 posts
Posted 30 August 2010 - 06:59 AM
I too have 2 of the supercheap items. One has had my L28 on there also since 2008 and the other my RB from late 2008 also. I recommend the 4 wheel version for easy of movement. The ones I have are like the 3 wheel version but have an extra bar at the front that hold the 2 front wheels. Not as easy to store stuff under the stand/engine as the 3 wheelers or the larger 4 wheelers (which have a U shape setup) but safer than the 3 wheel version when moving around.
#10 Bigfella
Bigfella
  • 388 posts
Posted 30 August 2010 - 07:58 AM
Thats great thanks guy.
Sounds like the 4 wheel version is defiantly the go.
#11 Six_Shooter
Six_Shooter
  • 736 posts
  • Tagline:Canuckian
Posted 31 August 2010 - 02:38 AM
If you're planning on storing the engine on the stand for a while, consider getting an engine dolly, or cart, whatever name you want to call it. It sits the engine low, only a few inches off the ground, supports from under the engine, and not by the bellhousing bolts, which means less worry about it toppling over or letting go, and you could also store the engine under a work bench, which means more floor space. I have a few of these for engines I'm not working on, but just storing undtil I get the chassis' they are supposed to be in done.
