Hoist Jacking Points
24 replies to this topic
#21 garvice
garvice
  • 1,037 posts
Posted 04 May 2011 - 10:22 PM
Actually my hoist is two mechanical screws. It keeps itself aligned with a throttle cable and a limit switch on a spring. You could do the same with four me mechanical jacks.
#22 NZeder
NZeder
  • 2,292 posts
Posted 05 May 2011 - 06:45 AM
So when are you buying the house for poles down.
sounds like a plan but there is one major issue with that - I already own that :( The poles are already on the block we have, the neighbour has 3 phase it is just getting a cable from the transformer down there up to my shed. I could have had the shed build down there but then the zed would never get out as the steep goat track of a road would be too rough for a normal car let alone a sports car :(
You see it would be cheaper to build a new shed with the correct stud height for a full hoist than install 3 phase.....so just might have to do that one day....but that would be 5-10 year plan. 2 month plan get the zed higher where it is now. Just get a better trolley jack is the simple answer. I don't like simple I like to change things and do things different ;)
check this out - I like the bit of video when he show how much flex the car gets on the 2 post hoist :(
#23 garvice
garvice
  • 1,037 posts
Posted 05 May 2011 - 06:54 AM
Ha, if that sort of body flex was happening from my car I would be more worried about the structural integrity of the car rather then the issues of lifting it with a hoist. The dollies seem interesting but you also then need to take the wheels off. I have seen something similar that uses the pinch welds to have the car high and mobile, I think it was in the repco trade catalogue, will try and find again.
#24 Six_Shooter
Six_Shooter
  • 736 posts
  • Tagline:Canuckian
Posted 18 August 2011 - 09:26 AM
When I use a hoist under my S30, which I have done plenty lately, I place the front pads under the TC mounts, and the rear pads under the bulge in the floor, just inside the pinch weld and in front of the rear tire.
As far as lifting just 500 to 800 mm, there's a ramp system, that a few guys on Hybrid Z have bought, where you drive up on it, then using a jack, lift the platform up and set to level. I've seen one in person and it's a neat set-up. There are optional pieces that span the middle that you can use for botle jacks and jack stands to remove the wheels.
I'll see if I can find a link/more information.
*edit*
Kwiklift: http://www.kwiklift....eatures-all.htm
Also there is this: http://www.restorati...document&part=3
#25 aussie240z
aussie240z
  • 159 posts
Posted 18 August 2011 - 01:12 PM
I needed ramps/hoist and watched evilbay for the car yard style ramps and bought a matching pair from a mechanics yard that was closing down.  I can move/adjust to suit any vehicle and apart from the fact that you are still on the wheels when you are on the ramp, the scope to work around/under/over is pretty good. I have a flat cross member I use across the ramps if I need to raise the zed on axle stands while on the ramp and remove/work on wheels/brakes etc. The attached pic is a set closed out recently on ebay at $641. I was lucky, mine were less than $300. They don't come up that often but when they do,  worth a look as an alternative.
Ian
