Lurch
Lurch’s ‘Early Girl’ 240Z!
A quiet but progressive build..........
No wonder, it has a
"Rust Whisperer'"
"L Series Whisperer'
and a 'Mikuni Whisperer'
all working on it.
Share this post
Link to post
Share on other sites
Lurch, you mentioned in your early girl thread, that the car had a 280ZX injection manifold  and was controlled by a Wolf V4 ECU. Looks like it had a 45mm throttle body also(mentioned above)
Do you remember what injectors were used? And what was the throttle body from?
I remember seeing a street reg rally car many years ago with a similar set up.
280ZX injection manifold and std injectors, a larger Ford throttle body(can't remember what model or size) and an Autronics ECU.
Got to drive it a few times on bitumen and I have to say it went really well, very driveable on the street with a shitload of go when needed.
It had a 2.9 litre bottom end and extensive port work to the head.
Share this post
Link to post
Hi
Have a look at this thread re larger AFM's for Bosch L-Jetronic
http://www.viczcar.com/forum/topic/6951-larger-afm-for-a-280zx/
PB
Share this post
Link to post
The 280ZX manifold had an adaptor plate welded to the front of it to take a 60mm Ford XF throttle body.
Injectors were - IIRC - Bosch V8 Mercedes items.
The 280ZX manifold isn't a nice item as it's designed for economy & torque.
Small runner length & a tiny plenum.
I got rid of it as soon as I could afford to :)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
