Removing 260z rear control arms
5 replies to this topic
#1 paddles
paddles
    Member
  • PipPip
  • 13 posts
Posted 12 February 2010 - 08:36 PM
Hey guys,
Turns out I'm a derp and am having trouble getting the rear control arms off a 260z to change the bushes. The problem lies with the rear hub connecting to the outside of the control arm. Are they connected by a single large stud about 200mm long with a nut on either end? I have removed the nuts but cant work out how to disconnect the hub from the control arm. Maybe I'm having a dull moment, so any help would be great!
#2 Zedman240®
Zedman240®
  • 5,198 posts
Posted 13 February 2010 - 08:43 AM
Hope you remembered to remove the cotter pin that's about halfway along the pin virtually under the hub. You will see a 10mm nut and the pin comes out underneath. But be careful removing it, you don't want to bash it with a hammer. look exactly like an old bicycle crank cotter pin but a lot more stubborn to get out!
#3 paddles
paddles
    Member
  • PipPip
  • 13 posts
Posted 13 February 2010 - 09:31 AM
Yep we have removed the pin - it's still not keen to come out though! Is the mount just a threaded rod from front to back?
#4 V8Datto
V8Datto
  • 223 posts
Posted 13 February 2010 - 11:35 AM
here, this might help
http://www.viczcar.c...pic,2808.0.html
#5 Mr240z
Mr240z
  • 1,067 posts
Posted 13 February 2010 - 12:00 PM
This is the best link you'll find.....Good luck you'll need it.
http://atlanticz.ca/...rend/index.html
#6 paddles
paddles
    Member
  • PipPip
  • 13 posts
Posted 14 February 2010 - 08:28 PM
Don't suppose anyone knows where to get a pair of new lower rod mount thingies? Saw a set on ebay for 80usd - surely they are available elsehwre cheaper?
