Sign in to follow this
ChiprZ
Auto rotisserie
Considering purchasing an auto rotisserie just to make life easier with re building.
Has anyone used them to do their projects?
Does anyone know where you can get these and how much?
Is anyone willing to part with one they no longer use? (PM me)
Share this post
Link to post
Share on other sites
My Rotisserie Design:
http://www.shaun-maluga.com/ProjectZ/Rotisserie.html
Rotissereies on Atlantic Z Car Site
http://www.atlanticz.ca/zclub/techtips/body/bodywork/stand/stands.htm
I (by I I mean me and dad :) ) built a rotisserie, we just need to build the brackets to hold the car on. The design is on my web page (follow the first link) however we changed from that design slightly. Its a little bit overkill but I know the stands are going to hold up and I would prefer to be safe.
Problem is the amount of steel used, this pushes the price up. I can't remember exactly but it was somewhere around $400-$500. And from what I remember it would have only cost an extra $100 to build 2 lots (due to the cost of buying steel per length or meter).
Design:
In progress:
What we changed was the sliding bits that hold the jack and the car. They are now a 1 piece design to make it stronger and we also added a small lip around the edge of the platform to stop the jack from sliding off. We are also adding legs that slide in the base to stop the stands rolling around (or alternatively you can buy wheels with brakes)
Share this post
Link to post
I saw this in operation in Germany. Similar ones are also available in OZ, but without the worm drive, but not sure who sells them.I used one on my Mercedes 190SL a few years ago and they take all the hard work out of working underneath. This one in Germany costs about EUR 650, or about A$1000.
Share this post
Link to post
http://liqui-technik.de/kipp1_e.html
Share this post
Link to post
sexual sushi.
do you have any photo's of the completed rig? especially the design changes you made to increase strength?
it is probably a stupid question (and i am guessing the answer is no due to weight), but would it be strong enough to hold the chassis while working on fabbing diff mounts etc. and possibly reassembling rear suspension etc.
and is the rear bumper mounts strong enough to attach the rear points to (just got my Z, so not familiar with it's construction).. people seem to attach them a number of ways.. i would prefer not to have to drill into the body to make brackets etc.
Share this post
Link to post
The easist way I've found is to use 2 engine stands with a length of RHS joining them together :)
Share this post
Link to post
yeah, i discussed that with a friend, advantage of this design is it gets over the problem of having to lift the front and rear at the same time to the right height to mount to the engine stand.
and i only have 1 stand at the moment.. it may work out relatively better to make this up rather than buy a 2nd one :)
Share this post
Link to post
Your concept is good and simple
I made a set similar to yours but using two hand boat wiches ( one each end ) for height adjustment attached to a slide with pulleys and a third one for rotation to minmize effort ( you can work on your own ) with adjustable RHS for the base joiner on solid swivel rubber wheels with brakes for moving ease, good for any size car you have
Share this post
Link to post
here is a short youtube video of when i buil my rotisserie.
Before anyone says any thing i know that the center of rotation is off but this was my first attempt
i know what i have to do to fix it for next time
All up this cost me about $250 in metal and about 5 hours to build
check it out and see what you think
Share this post
Link to post
Hello Mate
I assume you used the block and tackle I see to lift the body onto the stand???
Share this post
Link to post
Based on my own experience here are a few basic points:
Two x engine stands = $50 each - eBay
Steel for mounting brackets = $75 - steel supplier
Extend the height of the stands by 300mm
Bigger 4" castor wheels x 6 off = $45 - eBay
Use existing mounting points on the shell (see photos)
Make centre of rotation 75mm above the bumper bar mounting points.
Paint red - critical for success!
(edit) Forgot to add. To mount the shell all that is required are two mates and a carton of beer!
Share this post
Link to post
Hello Mate
you would be correct. It would have been much easier if i had some one there to help me
but unfortunately i had to get it up there by myself.
I just lifted one end at a time ;)
Share this post
Link to post
Hello Mate
Looks good, personally I would still run a length of RHS along the bottom to prevent flex as you dont have gussets at your joints, but whatever works
Cheers    :)
Share this post
Link to post
khughes: sorry i wasnt subscribed to this thread for some reason. i haven't quite got around to finishing them (moved to brisbane, but they are next on my dads to do list). Im heading home for the weekend so ill take some nice big pics of the final design.
i think we were going to build the bracket to go through the taillight holes and attach on top of the rear struts (i think). I think the bumper mounts are alright assuming you have fixed all rust and aren't putting it up with too much weight on the car, like the suspension you mentioned. I personally wouldnt use the bumper mounts but we are being very cautious. We built our design overkill, we assumed it should handle being up with the rear suspension on but we haven't tested it yet.
We were going to use the engine stands originally but for the cost of 2 engine stands we could build our own that's going to take alot more weight and utilise the jacking feature. On the engine stands we have, we noticed stress just holding the l28 (due to the length of the motor)
Share this post
Link to post
awesome, that would be great..
i have to admit i had the same concern about the engine stands.. mine sagged a fair bit by just having an RB30 long block on it!
Share this post
Link to post
Here's a link to how I made mine for a 180B SSS, which probably isn't that much smaller than a "Z" shell.
http://www.ozdat.com/forum/viewtopic.php?f=27&t=8205&hilit=rotisserie
And there's a commercial one described in here. I've worked on this car mounted on the rotisserie and it is a better, more substantial rotisserie than mine. Having the ability to jack it up is much better than having to man-handle it into place as well. However, mine was cheaper  ;)
http://datnet.org/Sdc-510-Club-Car-t5539.html&st=20
Share this post
Link to post
I actually came on here to find you so I could organise shipping your gearbox (because Ozdat had crapped itself with a database error again last night). Was a bit nervous about posting on a zed forum, nearly got myself banned from the Newcastle Z forum a week or so back after my first post there  :o
Anyway, by the time I poked around here, Ozdat was back online so I ended up PM'ing you there.
Nice forum BTW, some nice cars, I wouldn't mind a zed one day. I'll be old enough to own one soon  ;D  ;)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
