L28 into 240z
#1
Posted 06 January 2010 - 12:11 PM
been reading books on this lately but need actual experience to do this any here have done this conversion? can someone lead me through this as its completely different from my 280zx.
#2
Posted 06 January 2010 - 12:54 PM
#3
Posted 06 January 2010 - 03:03 PM
#4
Posted 06 January 2010 - 03:42 PM
If yes then there is a little work around the loom/wiring and fuel area's but should be simple enough if you have some skills.
Without EFI it is easier, take out the L24 install L28 with manifolds then put on the L24 manifolds ie carbs. If you want to keep it easy just swap over the dizzy also and if the timing is on the mark and you connect all hoses etc up you should be down the road in a few hours 1/2 days work. If you want to run the 280zx electronic dizzy this is a simple conversion again do able in the same 1/2 day.
So real question is EFI or no EFI?
#5
Posted 06 January 2010 - 04:27 PM
The worst things if you keep the EFI is working out where you want to hide the ECU, what to do about mounting the air flow metre and air filter, and for some people working out what wires to connect to what. Also having to setup the fuel system for EFI is a little time consuming.
#6
Posted 06 January 2010 - 09:37 PM
http://www.xenons130.../reference.html
I'd definately head down there to give you a hand if I had the time but things are going to be a bit of a rush while I'm on break this time. The engine and everything is the easy part to just bolt in and as NZeder said you can bolt on your carbs etc and run it like that. If you want to run the EFI then you'll need the wiring diagram to run power to the ECU and Fuel pump. But it isn't too hard. You don't need torun all the pollution gear either so if you have a look here you can see what you need nad don't need to run for vacuum.
http://forums.hybrid...ad.php?t=156720
Hope this helps.
#7
Posted 07 January 2010 - 11:46 AM
#8
Posted 07 January 2010 - 01:10 PM
In the later 240Z's they used the 71B gearbox's which don't have the flange.
#9
Posted 08 January 2010 - 10:59 AM
#10
Posted 08 January 2010 - 12:23 PM
#11
Posted 09 January 2010 - 11:17 AM
It's really a no-brainer physically, which you will discover once you get tinto it!
#12
Posted 09 January 2010 - 03:43 PM
You may have to do a sump-swap too, depending on what the L28 is fitted with.
sump!!!! what do u mean sumo swap? why would i need to swap it??? what sump of what car do i replace, if i need to replace it?
#13
Posted 09 January 2010 - 04:03 PM
#14
Posted 09 January 2010 - 05:20 PM
The 240z/260z/280zx all require rear sumps. So you need a L28 fitted with a rear sump to be a straight swap without removing the sump and installing the sump of the L24.
The other sump configurations were mid sump - used on JDM sedans aka 280C/Laurels etc
Then there was the Front sumps used on the later L6 power cars. Most LD28 we find here in NZ are Front sump configs as these come from late 80's Laurel aka C31
#15
Posted 09 January 2010 - 07:09 PM
#16
Posted 09 January 2010 - 09:02 PM
You shouldn't need to swap the sump. Even if you wanted to swap it you could just put the sump from your L24 onto it.
What he said
Don't stress - all I meant is that you may have to fit your L24 sump & pickup onto the L28. If you for some reason had a front-bowl engine, then you would also have to extend the oil pickup.
But since you have a rear-bowl 280ZX engine, then all will be well!
#17
Posted 11 January 2010 - 07:35 AM
#18
Posted 15 February 2010 - 02:08 PM
#19
Posted 15 February 2010 - 02:29 PM
Rev.
#20
Posted 15 February 2010 - 05:19 PM
