Some more cool Z videos - youtube.com
1015 replies to this topic
#61 zedls1
zedls1
  • 207 posts
Posted 01 August 2009 - 11:11 PM
Check this 240z commercial..
John
#62 gav240z
gav240z
    Administrator
  • 12,974 posts
Posted 02 August 2009 - 07:06 AM
John
Its a great laugh, although I think it must have been a school project or something its too new to be an 'old' commercial.
#63 gav240z
gav240z
    Administrator
  • 12,974 posts
Posted 04 August 2009 - 10:08 PM
Nice looking 240z done up to Fairlady style specification. Watch for the end when he gives her a bit of stick.
#64 dat2kman
dat2kman
  • 4,085 posts
Posted 06 August 2009 - 08:57 PM
Oh, here's a couple of tubers, part 1 and part 2, from  May 2009 Historics at Eastern Creek.
The Blue Z No 28 is Jason Lea. Qld, the White Z is Brian Potts NSW, and the yellow Z is Peter Lang also NSW.
I had flat spotted my fronts, the car was pushing on corner exit, and I was wrenching the nth degree out of the thing to keep up with Pottsy, and keep the Alfa at bay through the twistys, and then Langy comes scooting through the lot of us.
The Porsche just wouldnt move over.
Footage taken from an Alfa gtv. Thanks Danny Gatto. ( Mick's son???)
Note the engine note at the start, and when the Alfa's window (RHS) is next to the LHS of the blue Z at some parts.
Bit noisey! Some rpm's there too !!!
Ahh it's just an engine.
#65 mossy
mossy
  • 1,788 posts
Posted 13 August 2009 - 07:13 PM
240zg
#66 Cdr Zero
Cdr Zero
  • 454 posts
Posted 25 August 2009 - 08:22 PM
432 revving the S20
Nostalgics racing in 2008
280ZX at the same race
#67 Cdr Zero
Cdr Zero
  • 454 posts
Posted 29 August 2009 - 12:56 AM
TE71 Corolla Levin vs. S30 Fairlady Z 2+2
Good old fashioned cop chasing baddie stuff!
#68 Cdr Zero
Cdr Zero
  • 454 posts
Posted 07 September 2009 - 08:53 PM
Found a trailer for the Wangan Midnight 9101 box set that was released
#69 gav240z
gav240z
    Administrator
  • 12,974 posts
Posted 08 September 2009 - 06:18 AM
Nice Fairlady Z cruising through Japan.
Enjoy!
#70 Cdr Zero
Cdr Zero
  • 454 posts
Posted 17 September 2009 - 05:43 PM
1987 Drag meet in Japan, lots of Zeds and 1st gen RX7's plus a few other datsuns.
#71 Cdr Zero
Cdr Zero
  • 454 posts
Posted 03 October 2009 - 05:42 PM
Short scene from the end of the original Wangan Midnight movie plugging the Speed Shop Shinohara S30Z
K'z meeting 2009 in Hamamatsu - 1974 NISSAN S30Z Powered by 1981 OS GIKEN TC24-B1 Head
#72 Cdr Zero
Cdr Zero
  • 454 posts
Posted 07 October 2009 - 06:01 PM
Drag race practice, taken yesterday
#73 gav240z
gav240z
    Administrator
  • 12,974 posts
Posted 09 October 2009 - 08:21 AM
Check out Jeremy Clarkson's T-shirt
#74 Cdr Zero
Cdr Zero
  • 454 posts
Posted 23 October 2009 - 06:51 AM
S30Z Racing in Japan
Part 1
Part 2
#75 zzzzed
zzzzed
  • 2,691 posts
Posted 14 November 2009 - 11:37 AM
zed guide
#76 NZeder
NZeder
  • 2,292 posts
Posted 14 November 2009 - 03:43 PM
Fairlady Z from Japan with a RB30DE installed - twin exhaust setup - this is sim to how my will be setup so I hope it sounds like this too ;)
#77 zzzzed
zzzzed
  • 2,691 posts
Posted 17 November 2009 - 10:36 PM
370z v mustang
the 370z easily out performs the mustang
#78 Cdr Zero
Cdr Zero
  • 454 posts
Posted 13 December 2009 - 11:48 AM
Another Z cleaning up on the track in Japan
#79 WogsRus
WogsRus
  • 351 posts
Posted 13 December 2009 - 04:30 PM
dam that thing is QUICK. dam it. what's in it
#80 NZeder
NZeder
  • 2,292 posts
Posted 13 December 2009 - 05:01 PM
Here are some more of the same car
and this one with a stronger field including a Nissan R380 Le-Manns car :)
Now about the car and what is in it - I can answer that as I have Japanese magazine article on it.
First before we get to the engine lets understands other aspects of the car.
RIMS are Longchamp XR4 in 15x9 -15 offset fronts and rears are 15x9.5 -21 offset. Rapped in 215/50/15 front and 225/50/15 rears both Advan A048 (yes it has ZG overfenders installed and a large wing on the rear front spoiler is the normal single piece setup and it has light covers with chrome rings). Front brakes are the good brembo 4 pots and rear are also the good brembo 4 pots. These run with an AP adjustable valve and no booster but still a single MC. Fitted with a bolt in half cage. Running 260z (as we know them) stub axles in the rear - not sure on the diff or gearbox setup.
Ok the engine.
It runs a surge tank and 2 pumps - assume pre and post surge tank. A thick cross flow raditor. On the side of the engine are 3 x 50mm mikuni carbs running open trumpeted feed from air taken from in front of the radiator (ie 3 or 4" pipe fitted via radiator support panel). Under these sucky things is a wrapped header that is 45mm and 6-2-1 design. Still running a Dizzy but electronic and controlled by the Wako CD-1200 CDI unit. Now for the engine inside bits.
An L3.0 running 89mm bore and a 80mm stroke (ie L28 crank offset ground or smaller journal to add the extra 1mm stroke - that is an assumption on my part) running standard 44mm inlet valves and 35mm exhaust with a 78 cam (this is what I can make out of the Japanese Kanji) which is 12mm of lift I think. And what I think is an AP twin plate clutch setup (again my Japanese Kanji is no existent so this is my best guess)
So does that help?
