NZeder Posted November 14, 2009 Share Posted November 14, 2009 Fairlady Z from Japan with a RB30DE installed - twin exhaust setup - this is sim to how my will be setup so I hope it sounds like this too Quote Link to comment Share on other sites More sharing options...
zzzzed Posted November 17, 2009 Share Posted November 17, 2009 370z v mustang the 370z easily out performs the mustang Quote Link to comment Share on other sites More sharing options...
Cdr Zero Posted December 13, 2009 Share Posted December 13, 2009 Another Z cleaning up on the track in Japan Quote Link to comment Share on other sites More sharing options...
WogsRus Posted December 13, 2009 Share Posted December 13, 2009 dam that thing is QUICK. dam it. what's in it Quote Link to comment Share on other sites More sharing options...
NZeder Posted December 13, 2009 Share Posted December 13, 2009 dam that thing is QUICK. dam it. what's in it Here are some more of the same car and this one with a stronger field including a Nissan R380 Le-Manns car Now about the car and what is in it - I can answer that as I have Japanese magazine article on it. First before we get to the engine lets understands other aspects of the car. RIMS are Longchamp XR4 in 15x9 -15 offset fronts and rears are 15x9.5 -21 offset. Rapped in 215/50/15 front and 225/50/15 rears both Advan A048 (yes it has ZG overfenders installed and a large wing on the rear front spoiler is the normal single piece setup and it has light covers with chrome rings). Front brakes are the good brembo 4 pots and rear are also the good brembo 4 pots. These run with an AP adjustable valve and no booster but still a single MC. Fitted with a bolt in half cage. Running 260z (as we know them) stub axles in the rear - not sure on the diff or gearbox setup. Ok the engine. It runs a surge tank and 2 pumps - assume pre and post surge tank. A thick cross flow raditor. On the side of the engine are 3 x 50mm mikuni carbs running open trumpeted feed from air taken from in front of the radiator (ie 3 or 4" pipe fitted via radiator support panel). Under these sucky things is a wrapped header that is 45mm and 6-2-1 design. Still running a Dizzy but electronic and controlled by the Wako CD-1200 CDI unit. Now for the engine inside bits. An L3.0 running 89mm bore and a 80mm stroke (ie L28 crank offset ground or smaller journal to add the extra 1mm stroke - that is an assumption on my part) running standard 44mm inlet valves and 35mm exhaust with a 78 cam (this is what I can make out of the Japanese Kanji) which is 12mm of lift I think. And what I think is an AP twin plate clutch setup (again my Japanese Kanji is no existent so this is my best guess) So does that help? Quote Link to comment Share on other sites More sharing options...
Cdr Zero Posted December 13, 2009 Share Posted December 13, 2009 Thanks NZeder Quote Link to comment Share on other sites More sharing options...
WogsRus Posted December 14, 2009 Share Posted December 14, 2009 Dam, as long as my L26 sounds like that i'll be happy. Love teh amount of drive he can get out of teh corners, i think it's a very soughted car. Any idea on Hp figures? Quote Link to comment Share on other sites More sharing options...
NZeder Posted December 14, 2009 Share Posted December 14, 2009 Dam, as long as my L26 sounds like that i'll be happy. Love teh amount of drive he can get out of teh corners, i think it's a very soughted car. Any idea on Hp figures? Re the drive out of the corner - found the spring rates 11kg/mm and 12kg/mm (616lb/in and 672lb/in) no wonder it sits so flat that thing must hardly move. Re the power output - no figures indicated but if other correctly build 3.0l are used as a guide it should have 250-280ps at the wheels. Quote Link to comment Share on other sites More sharing options...
Cdr Zero Posted December 16, 2009 Share Posted December 16, 2009 90's Japanese Tuner showdown including the Excellent Speed S30Z (love their names!) showing the young'uns a thing or two! Until the incident that is. :-\ EDIT: Mind the random panty shots. Part 1 http://www.youtube.com/watch?v=n61WYPqgHJM Part 2 http://www.youtube.com/watch?v=LPpxkgpXmtk Quote Link to comment Share on other sites More sharing options...
Riceburner Posted December 16, 2009 Share Posted December 16, 2009 There's no way i'd go on the track with those nutters, you'd end up getting shunted into the fence! hehehehe. Love the 240z off the start line Quote Link to comment Share on other sites More sharing options...
Administrators gav240z Posted December 30, 2009 Administrators Share Posted December 30, 2009 Cool video from JCCS this year I think http://videos.streetfire.net/video/Classic-Japanese-Iron-on_715775.htm Quote Link to comment Share on other sites More sharing options...
mossy Posted January 3, 2010 Share Posted January 3, 2010 Some cool classics in this one Quote Link to comment Share on other sites More sharing options...
C.A.R. Posted February 7, 2010 Share Posted February 7, 2010 'Hako' GTR: http://www.youtube.com/watch?v=wC6mlV88UsI Oh the NOISE! Quote Link to comment Share on other sites More sharing options...
Stivva Posted February 11, 2010 Share Posted February 11, 2010 One I haven't seen before Quote Link to comment Share on other sites More sharing options...
Administrators gav240z Posted February 11, 2010 Administrators Share Posted February 11, 2010 240z restoration videos: http://www.youtube.com/watch?v=CFhZem4xyyo http://www.youtube.com/watch?v=DjL0vFvlMvA http://www.youtube.com/watch?v=ySsxmue1hkY Quote Link to comment Share on other sites More sharing options...
Thomo260 Posted March 1, 2010 Share Posted March 1, 2010 The chick in this film drives a 240Z while a van plays 8 track tapes and terrorizes motorists. http://www.youtube.com/watch?v=nH2koVXuDlM&feature=grec Quote Link to comment Share on other sites More sharing options...
ricardo Posted April 22, 2010 Share Posted April 22, 2010 You've probably all seen this before, but you will want to see it again. Sounds fantastic and looks like big money!! I hope it isn't too hard to get a 'regular' L28 to sound like this... Quote Link to comment Share on other sites More sharing options...
NZeder Posted April 23, 2010 Share Posted April 23, 2010 Thought I would post some links to video's of my mates Ricky's BRE Tribute car that he recently posted on youtube. Both handicap races. Quote Link to comment Share on other sites More sharing options...
mossy Posted May 9, 2010 Share Posted May 9, 2010 http://www.youtube.com/watch?v=XNlIerQhUUY Quote Link to comment Share on other sites More sharing options...
Moderators Zedman240® Posted May 9, 2010 Moderators Share Posted May 9, 2010 Excellent find there... Quote Link to comment Share on other sites More sharing options...
Moderators Zedman240® Posted May 24, 2010 Moderators Share Posted May 24, 2010 Found a nice vid of some NA EFI RB20 / RB30 carbed engines being compared; a bit old but a good view for anyone thinking about this sort of setup. The first car was how I wanted my RB to go and sound like but never got that far! Worth a look! http://www.youtube.com/watch?v=H-c-nYpic6A&feature=related Quote Link to comment Share on other sites More sharing options...
Cdr Zero Posted May 25, 2010 Share Posted May 25, 2010 3.1L L28 S30Z doing it's thing on the racetrack Quote Link to comment Share on other sites More sharing options...
C.A.R. Posted June 16, 2010 Share Posted June 16, 2010 10.9 @ 198mph - EEEK! Watch from 1:20 Quote Link to comment Share on other sites More sharing options...
Administrators gav240z Posted June 16, 2010 Administrators Share Posted June 16, 2010 10.9 @ 198mph - EEEK! Watch from 1:20 L28 Baby, L28. Quote Link to comment Share on other sites More sharing options...
C.A.R. Posted June 16, 2010 Share Posted June 16, 2010 It aint at 2.8ltrs any more Gav! http://e-system.e-autosalon.net/gene_site/2010_g_works/g_works_cars_8.php Quote Link to comment Share on other sites More sharing options...
