Clutch Slave Cylinder - Interchangeable with gearbox conversions?
8 replies to this topic
#1 sexual_sushi
sexual_sushi
  • 1,298 posts
Posted 13 September 2009 - 02:48 PM
I'm looking to replace my clutch slave cylinder...
Firstly are the slave cylinders interchangeable between 240z, 260z and 280zx? I assumed they were and a lot of ebay listings list 1 slave for the 240z, 260z and 280z (not zx). As a side note, black dragon lists a different slave rebuild kit for 70-72, 73-75, 75-83 and 81-83 (turbo).
Secondly, if the answer to the above question is no, I would assume that a 240z with a 280zx box has a 280zx slave cylinder? (My 240z came with a 280zx box)
Thirdly, if I have since converted to a s14 5 speed gearbox and kept the slave cylinder that was on the car, what should I replace it with?
#2 NZeder
NZeder
  • 2,292 posts
Posted 13 September 2009 - 05:23 PM
Well I know when I was at the track with my old 240z - I lost the clutch slave cylinder (old and leaked before I even raced - the drive to the track killed it) anyway the local REPCO did not have any stock for a 240z/260z/280zx so I just asked for a Skyline unit (which they had) I was told by the PFY (for those that need to know PFY = Pimple Faced Youth) it would not work as it was for a Skyline not a Datsun 240z. I told him just to sell it to me. At the track it was installed and worked perfect bolted right up and was the same size and stroke (as I knew it would be). The only use was the return spring from the clutch fork as this new cylinder did not have the location for the spring to hock into - so I used a different spring (longer) and hocked it around the bleed nipple.
Also I know the Datsun 240z slave cylinder will bolt up to the Skyline 71C box as this is the setup in my mates racecar.
Also the S13/14 uses the same clutch slave cylinder the skyline unit I installed R31/R32/R33 push type (ie RB20DE/T,RB25DE/T)
#3 Mr240z
Mr240z
  • 1,067 posts
Posted 13 September 2009 - 05:29 PM
Clutch slave cylinder  JB4055
This slave cylinder fits them all.........
#4 xa1973
xa1973
  • 666 posts
Posted 13 September 2009 - 05:48 PM
You dont by chance work for an Auto Parts Group do you Pauly...
Im impressed with the speed you always source and list parts and NO's
#5 Mr240z
Mr240z
  • 1,067 posts
Posted 13 September 2009 - 05:57 PM
Jeff I managed Autopro Homebush for 15 years...
For the last 4 years I've been working for a council cutting grass, Big change..
#6 xa1973
xa1973
  • 666 posts
Posted 13 September 2009 - 06:12 PM
All good Mate...I thought that might have been the case.....
#7 NZeder
NZeder
  • 2,292 posts
Posted 13 September 2009 - 07:04 PM
That also cross references with a Celica ST162 too
#8 Zedman240®
Zedman240®
  • 5,198 posts
Posted 13 September 2009 - 08:29 PM
With my RB gearbox in the 240, I tried using the Skyline cylinder but it didn't have enough travel. installed the zed one, worked fine. Compared the two bores, Skyline one was larger = less travel, zed cylinder was smaller = more movement for given pedal travel.
#9 sexual_sushi
sexual_sushi
  • 1,298 posts
Posted 14 September 2009 - 08:16 PM
Thanks for all the info guys!
So basically it sounds like one slave cylinder fits every car ever made haha (joke).
I shall order a JB4055 tomorrow.
