Sign in to follow this
Natez
Bushes/Rubbers, what do buy and where to get it from??
Hey
I need basically the whole cars suspension redone, bushes id like to start with, all buy a few are either cracked, or about to crack under some pressure...
I want to go urathane, and i know you can get some adjustability out of these in some areas of the car....
Energy Supension sell a kit for the 240, which is 180US, ive gone though most of the parts catalogs for australian brand urathne bushes and havn't been able to find a kit for the whole car, so can anyone help me out??? what have you done, or what are you thinking of doing...
strut wise, if it matters, will be shortend struts with coil over sleeves... if that makes a differance... but i need to get the bushes for a RW anyway
Share this post
Link to post
Share on other sites
Hi
I got all mine from GT Suspension on Mt Alexander Road Flemington back in 2002. From memory they were made in Qld. Give them a call 93760777.
Warren
Share this post
Link to post
might go there on the way to work tommorow, i bought a few things from them over the years for other cars, and they are helpful, will asked them...
Share this post
Link to post
well going from there website...
www.gtsuspension.com.au
Control arm - inner F 2 1 N51945
Radius rod F 4 1 N81147 12.8mm I.D.
Radius rod F 2 1 N81075 16mm I.D.
Steering coupling F 1 1 N11044 Fitting kit supplied
Steering rack mounts F 2 1 N12075
Sway bar - link F 8 1 N21135
Sway bar - mount 22mm F 2 1 N21332 22mm - measure bar size
Diff.mount moustache brace R 2 1 N91045 Incl. crush tubes
Trailing arm - inner R 4 1 N61946
Trailing arm - outer R 4 1 N61948
Trailing arm - inner(adjustable) R 4 1 N62145 Toe/camber adjustable
that is all the parts that they have for the 70-74 240z, be the same for 260 as well, i presume....
i'll see during the week what gt suspensions want for all these parts, with the 22mm sway bar, they also got the adjustable rear trailing arm part which is better for the lowred vehicles, if gt suspension is around the same price, im just going to get it from noltec, and get it locally
The energy suspension Hyper-Flex package, goes on ebay for $185US which is AU$240 +postage, say $40, = Au$280 for what is below
This set includes
front and rear control arm bushings,
front strut rod bushings,
front and rear bump stops,
rack and pinion bushings
, differential carrier mustache bar bushings
, steering coupler bushings,
front end links and tie rod end boots
Share this post
Link to post
For Noltec
N51945
N81147
N11044
N12075
N21135
N91045
N61946
N61948
$370...
This is using only 1 radius rod bush, no 22mm sway bar D bush (will come with whiteline bar), and the non adjustable bushes for the Rear trailing arms. You will be hard pressed to find a better price on those parts, i promise....
For Superpro
SPF1215K - $55 - F Control Arm
SPF0050K - $15 - F Steering Coupling
SPF0033K - $30 - F Steering Rack Mount
SPF0927K - $40 - F Radius Rod
SPF0246K - $65 - R X-member
Sid
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
