wheel spacers
25 replies to this topic
#1 (Locky)
(Locky)
  • 143 posts
Posted 13 July 2009 - 11:21 PM
hey
trying to find some front wheels for my 240, but not sure if the ones im after will clear the strut/brakes ect
so was looking into a bolt on spacer
most of them from memory are hubcentric for a s13 in a 4x114.3 , but the "hub ring" (forget what its called) is bigger on a 240 right. i remember reading some where that someone was using s13 rotors but had to get them bored out to fit
so does anyone here run spacers ????
if so were they off the shelf or custom
#2 Lgee
Lgee
  • 126 posts
  • Website:http://www.teamslappd.com
Posted 14 July 2009 - 08:55 AM
i run spacers but not on a z, we could lathe out the centre for you
#3 luvemfast
luvemfast
  • 4,143 posts
Posted 14 July 2009 - 09:41 PM
I have some spacers that were supposed to be bolt on.
However, I had to bore out the inside diameter to get them to fit.
#4 xa1973
xa1973
  • 666 posts
Posted 15 July 2009 - 09:04 PM
Not keen on spacers, I think it would be better to source a set of wheels that suit, there are numerous posts here as to what will and will not fit.......
Im not sure if their legal on a road car for rego etc????
#5 Zedman240®
Zedman240®
  • 5,198 posts
Posted 15 July 2009 - 09:36 PM
+1 with that.
I'm sure anything that increases track width is not legal.
#6 V8Datto
V8Datto
  • 223 posts
Posted 15 July 2009 - 10:02 PM
I had trouble with track width and cop years ago,
Rules back then were from standard you could go 25mm total extra track width on the front and 50mm on the back, :note: If your car came out with a different model (same chassis) with wider rims then you could use that model of car as "the standard" and add to it.
That ment each front rim could move out 12.5mm and the rears 25mm too.
But things change and I'm not sure if the guy a Vicroads was correct in what he told me back then either.
I looked into spacers and found they were legal, but there were strict guide lines
I'm assuming racing car's use them so they can't be too bad
What were the standard rims on the 432Z?
#7 (Locky)
(Locky)
  • 143 posts
Posted 15 July 2009 - 10:47 PM
to be honest im not uber worried about legalities
the rims for the back already distroy any legal track increases (9.5-6  ;D)
anyway bought a pair of 7+5 for the front, bt still not sure if they will it out as much as i want
#8 S30Mike
S30Mike
  • 531 posts
Posted 29 July 2009 - 07:26 PM
Hey locky,
Try Justjap, they have a huge range of hubcentric spacers.
I will be spacing mine out to fill the flares once i get them on too.
#9 sco_aus
sco_aus
  • 2,484 posts
  • Tagline:Scott
Posted 29 July 2009 - 09:25 PM
I had 2x sets of the JustJap 25mm ones and I nearly lost my Simmons, be careful...
#10 xa1973
xa1973
  • 666 posts
Posted 30 July 2009 - 09:27 AM
Hey guys, please consider another route other than spacers............
#11 RBZ 260
RBZ 260
  • 1,174 posts
  • Tagline:S chassis Nutter
Posted 30 July 2009 - 01:27 PM
i got a set for mine but mine is 5x 114.3.
legalities in SA as long as they not loose and have the hub fitting snuggly. but still a mixed info.
i got a set from ebay seller performance guru from NZ. very good seller and the spacers were top notch. postage was like 3days.
even showed them to few mag wheel places and they wanted the guys details as they were lot better quality and finish. didnt give them though  ;D hehe
he does have other offset sizes and stud patterns so pays to contact him if not listed.
#12 S30Mike
S30Mike
  • 531 posts
Posted 04 August 2009 - 08:02 PM
CAn you elaborate on why they nearly came off?
im planning to use these to fill up the gaurds more... surely if you bolt the bastards on hard enough it should be fine? what part of them malfunction?
#13 sco_aus
sco_aus
  • 2,484 posts
  • Tagline:Scott
Posted 04 August 2009 - 08:06 PM
Dunno. they were on real tight, i got about 2ks from my place and i could feel the car start shaking.  Stopped and the nuts were loose...  I imagine it wasn't balanced properly
#14 Ben
Ben
  • 313 posts
Posted 12 October 2009 - 09:46 PM
You sure about that Johnny? The regulations I have clearly state that hub spacers are strictly forbidden, unless originally fitted by the manufacturer...
#15 Mr240z
Mr240z
  • 1,067 posts
Posted 13 October 2009 - 04:52 PM
My mate was just was told from an Insurance company that if wheel spacers are fitted they will not PAY OUT.
If you are in an accident, Your fault or not..unless originally fitted by the manufacturer.
#16 benny
benny
  • 1,734 posts
Posted 14 October 2009 - 01:41 PM
Had an idea the other day while talking to dad... what if you welded an aluminum spacer to an alloy wheel and used longer studs instead??  :)
#17 hunterzed
hunterzed
  • 229 posts
  • Tagline:Steve
Posted 01 November 2009 - 05:33 PM
This would be about the same effect as spacers. The other thing with this is that you will need an engineers certificate. When I was racing I wanted to run bead locks. (On a 4wd) and you can't put a continuous weld around the entire circumferance of the rim as this will creat a weak point for the rim to crack. The rules don't specify whether you weld on the outer or inner part of the rim. To be honest, your best bet would be to upgrade to 5 stud struts. Much easier to get engineered and will give you way more options for rims. You'll also have way more brake choices as well and not to mention coil over options. If you have an accident with spacers or modified rims you will NOT be covered by insurance. Unless you can keep it real quiet. Might not seam like much to think about but insurance comapanies will look for any way out of paying that they can find. You might beat them but it'll cost heaps in litegation. Just my 2 cents.
#18 (Locky)
(Locky)
  • 143 posts
Posted 01 November 2009 - 07:17 PM
borrowed a pair off a friend
cant uses off the shelf ones because the hub cover on the 240 flares out just before it goes flat
if you shve a few mm off at a 45deg andgle off the spacers they would probebly fit
#19 S30Mike
S30Mike
  • 531 posts
Posted 03 November 2009 - 12:05 AM
Well theres basically 2 options:
1. Use spacers to get that little more offset from the sportmax
or
2. Pay an extra $2000.00 for Watanabes.
:P
#20 Mr240z
Mr240z
  • 1,067 posts
Posted 03 November 2009 - 04:58 PM
You should have gone the 2nd option the first time...
Do it right the first time, Pay the money than it done for good...
That's what I do.. Being cheap the 1st time always cost you more in the long run.
Been there done that...Now I buy the best 1st time around.
Wheel spacer's ain't worth the legal stuff that can happen if it all goes pear shaped.. ;)
