SU Ram Pipes\Velocity Stacks
16 replies to this topic
#1 fomoco_44
fomoco_44
  • 40 posts
Posted 03 June 2009 - 12:40 PM
Hi All  :D
Me again....must be getting sick of me by now.
I'm looking at getting some ram pipes for the HS6 SU's I have, and I noticed there are several on the market available. Main difference seems to be length of the pipe, as pictured.
Does anyone have any info\opinions on what is better?
I'm thinking of using the short type so that I can still fit them under my Redline Chrome filter housing, instead of buying socks.
#2 twosixty
twosixty
  • 96 posts
Posted 03 June 2009 - 12:52 PM
According to my memory of internet lore, shorter tubes=more hp , longer tubes=more torque.
NFI on whether this is true or a complete load of bollocks.
#3 sexual_sushi
sexual_sushi
  • 1,298 posts
Posted 03 June 2009 - 01:06 PM
Norm the 12 second su dude's cheap velocity stack. If you look half way down the page he says...
he had a section covering SU's and they saw a 5% increase in power with the stub stacks and a 3.5% power increase with the longer air horns. Althouh the longer airhorns did make slightly more torque at a lower rpm.
If you are running a real racetrack where you have to slow down a lot then I'd say those would be the better option, but for the drag strip, HP will win out over low end torque unless you are really hoooking hard off the line and even then increased HP will normally win. I've tuned my car both ways and it's about a tenth slower in the 1/8 mile when tuned with a slight bias towards increased low end torque.
http://www.zcar.com/.../2050673/page=1
http://www.zcar.com/.../read/4/2051341
#4 fomoco_44
fomoco_44
  • 40 posts
Posted 03 June 2009 - 01:20 PM
Awesome...thanks guys ;D
#5 260Coupe
260Coupe
  • 596 posts
Posted 04 June 2009 - 11:22 AM
If you have a standard 240z filter housing ....use it......they make the more HP than ram tubes. This has been dyno tested numerous times (noise does not equal HP)
#6 fomoco_44
fomoco_44
  • 40 posts
Posted 04 June 2009 - 12:04 PM
Unfortunately, I only have the original Flat-top 260z filter housing...which I assume is unsuitable due to dimensions+square opening.
#7 DaveDimo
DaveDimo
  • 67 posts
Posted 10 July 2009 - 08:27 PM
make adapter plates. ive seen it done with stud sunken in the adapter plates then that gets bolted to the carbs. easy
#8 nuclear_z
nuclear_z
  • 247 posts
Posted 15 July 2009 - 12:18 PM
The longer the stack the better for Hp and Torque. Having a longer inlet track that is straight smooths the airflow allowing it to be sucked in faster...
Maybe the reason that a standard cover works best is the cold air??? I would bet its not the flow characteristics. Make a plenum with the stacks in it and it would be SWEET :D Have a look at the V8 supercar stacks and they're about 10cm long.
-EDIT- Cannot remember if they were Supercar stacks or otherwise that I saw at a race meeting recently...
#9 Scoota G
Scoota G
  • 4,213 posts
  • Tagline:Mark
Posted 15 July 2009 - 01:49 PM
I read on another forum that Ram Tubes are for smoothing out the incoming air flow but on yet another forum they say that it's a no no to polish the inside of your intake manifold as the air fuel mixture is mixed better traveling through the rough surface of a standard intake that still has the casting marks on it! Please Explain?
#10 Zedman240®
Zedman240®
  • 5,198 posts
Posted 15 July 2009 - 02:07 PM
Apparently, the rough surface is supposed to help turbulence in the airflow to help atomise the fuel so it burns more efficently. If you have EFI, you can polish as the fuel is already atomised better than what a carb can do. One thing you want to avoid is fuel condensing on the intake manifold walls..
#11 Scoota G
Scoota G
  • 4,213 posts
  • Tagline:Mark
Posted 15 July 2009 - 04:37 PM
Yea i read the same but what i'm asking is why would a ram tube be used smoothing the air out only to go through the turbulence stage in the manifold?
#12 RB30X
RB30X
  • 1,981 posts
Posted 15 July 2009 - 05:07 PM
You smooth out the air flow increasing velocity in the stacks before the fuel gets added in the carb then the air/fuel travels through the turbulent walled manifold and port.
#13 Scoota G
Scoota G
  • 4,213 posts
  • Tagline:Mark
Posted 15 July 2009 - 07:24 PM
And where did that info come from may i ask?
#14 chris240
chris240
  • 2,186 posts
Posted 15 July 2009 - 07:57 PM
Oprah........ ;)
No, in all honesty I think rb30x is correct.. anything to increase velocity speed is defintely a plus. supercharging follows the same basic principle..
#15 (Locky)
(Locky)
  • 143 posts
Posted 15 July 2009 - 08:44 PM
my car didnt come with any airbox or anthing off the carbs
so i got the redline ones
Posted Image
Posted Image
might try and rig up a bit of a CAI once its on the road
#16 RB30X
RB30X
  • 1,981 posts
Posted 16 July 2009 - 08:38 AM
Combustion Engines 101.
#17 Zedman240®
Zedman240®
  • 5,198 posts
Posted 16 July 2009 - 08:50 AM
This might help explain..
http://en.wikipedia..../Velocity_stack
