new koni and kings help
17 replies to this topic
#1 mossy
mossy
  • 1,797 posts
Posted 15 May 2009 - 01:23 PM
I've just got some koni reds and king low springs for my 71 240z, on the front springs one end of the coils are bound closer than the other, which end goes to the top and I don't have any bumpstops, would these be recommended?
#2 luvemfast
luvemfast
  • 4,161 posts
Posted 15 May 2009 - 03:51 PM
For the sake of a few $'s. Put in bumpstops.
It is unlikely but, it only takes one big bang of a speedhump or large pothole to overtravel the suspension. Especially for a lowered vehicle with adjustable shocks.
#3 Zedman240®
Zedman240®
  • 5,198 posts
Posted 15 May 2009 - 04:02 PM
Bad thing about the Koni's, once they bottom out, time for rebuild to fit new valving!
#4 Mr240z
Mr240z
  • 1,067 posts
Posted 15 May 2009 - 05:27 PM
I used monroe strut mates.. They come with strut boots and bump stops.
#5 mossy
mossy
  • 1,797 posts
Posted 15 May 2009 - 05:34 PM
I think your right I should just install some bumpstops, I've got some for the other z so I'll just use them, did anyone cut their bumpstops down?
I did check over at hybridz in regards to which way the front spring goes and it seems to be divided, if i install in reference to the writing right way up on the spring the bound coils would be at the bottom, they also say the rear spring is usally longer, whereas these are slightly longer in the front ???
Pauly I thought you installed koni red earlier this year?
#6 Mr240z
Mr240z
  • 1,067 posts
Posted 15 May 2009 - 05:41 PM
Yes mossy I have Koni Red's and I used Monroe Strut Mates with them..
If your paying out good money on Koni's a $100 more wont hurt..
Strut Mate
Too often a new strut or cartridge is fitted with the old original and damaged suspension travel limit bushing (compression bumper) and dust boot. The Monroe Strut Mate kit includes a high quality, soft entry urethane compression bumper, a new dust boot, retaining strap and fitting instructions.
Product features
Premium quality microcellular urethane bumper
#7 mossy
mossy
  • 1,797 posts
Posted 15 May 2009 - 05:47 PM
Ahhh I'm with you now, I misread your previous post thinking you installed monroe struts. ;D
#8 Lurch ™
Lurch ™
  • 5,736 posts
Posted 15 May 2009 - 06:09 PM
Got a P/N for those Pauly? ;D
#9 Mr240z
Mr240z
  • 1,067 posts
Posted 15 May 2009 - 06:16 PM
Monroe Part No..PK004 or Pk008  Both fit .
I save all part numbers.
#10 Lurch ™
Lurch ™
  • 5,736 posts
Posted 15 May 2009 - 06:38 PM
Hence why I asked you :P
Thanks, pumpkin :)
#11 Mr240z
Mr240z
  • 1,067 posts
Posted 15 May 2009 - 07:01 PM
Thanks, pumpkin :)
You are a crack up....Sweetness
#12 mossy
mossy
  • 1,797 posts
Posted 16 May 2009 - 03:06 PM
Had the rear konis put in today and fully tightened the gland nut but noticed it doesn't tighten all the way down against the strut, is this okay?
#13 Zeddophile
Zeddophile
  • 987 posts
Posted 16 May 2009 - 04:11 PM
If you mean the nut doesn't get to sitting flush to the strut tube before it clamps down on the shock insert, then yes, I'd say its okay.  Pretty sure mine did the same thing....  As long as the shock itself is held firm, should be fine.
#14 mossy
mossy
  • 1,797 posts
Posted 16 May 2009 - 06:48 PM
Here is a pic, the nut has been tightened as far as it will go, so there is a couple of mm gap.
Posted Image
#15 luvemfast
luvemfast
  • 4,161 posts
Posted 16 May 2009 - 07:11 PM
You don't want it to tighten all the way down as it means that its not tight on the insert. About 1mm or so is good. That looks like a big gap, is there full thread engagement? If all the thead is in (from memory there is an undercut before the shoulder), it should be ok.
#16 zzzzed
zzzzed
  • 2,691 posts
Posted 17 May 2009 - 11:47 AM
now i dont know what to belive ??? I have been told the opposite, with the tighter windings to the top
But i dont think it realy matters to much
#17 zzzzed
zzzzed
  • 2,691 posts
Posted 17 May 2009 - 11:56 AM
im going to sac my tafe lecturer then  ;)
#18 mossy
mossy
  • 1,797 posts
Posted 19 May 2009 - 11:15 AM
Yep there is full thread engagement, I just bought another 240 strut for my other z and it looks the same with a gap so should be good.
In regards to the front springs I rang kings and they told me to put the closer bound springs at the top.
