3.1l rebello engine
40 replies to this topic
#41 DatZed
DatZed
  • 101 posts
Posted 18 July 2009 - 09:19 PM
Hi mate, the biggest issue with the standard stroker setup is the rod ratio. The deck height really isn't high enough to give you a decent rod ratio with an off the shelf piston. With the run of the mill setup using the 133mm rods, you get about 1.6:1 which is shit. If you can get your hands on the ld28 block you are in business as it's got another 20mm deck height so you can run something like an l20b rod or even a modified chev rod.
The only other option would be custom made forgies with a pin height of about 25mm, this way you could run a 3sgte rod without too much fuss.
Big throttle plates are a must, I would say 48mm minimum, preferrably 50mm. No carbs, if you are serious.
Just my thoughts on the matter.
