3.1l rebello engine
40 replies to this topic
#21 NZeder
NZeder
  • 2,292 posts
Posted 15 May 2009 - 12:48 PM
Good posts guys, nzeder I'm working on a new site as well with a blogging function, i know what you mean about it guys/panel beaters haha :)
Devilz good to hear some positive feedback for the stroker :)
Re the blogging function - me too - I am in the middle of updating my website to a blog setup
Strokers are good to drive the torque is something else. Mine was building using L14 rods and Cosworth Forged items. Personally I would not want to go though all the trouble of getting the LD28 crank, rods, machine work balancing etc just to put a truck piston on the top (reads KA24 piston) the rings are large, the piston is heavy. Great if you want a cheap stroker (is there such a thing you have to ask) but for a few $$ more you get some nice light weight pistons, with a much smaller ring (not the truck sized of the KA24)
This is just IMHO - take it as you will.
#22 mtopxsecret6
mtopxsecret6
  • 377 posts
Posted 15 May 2009 - 05:34 PM
good meaty info, i'll have to take some time to read it all.. instead of buzzing through the posts.. thanks for the info fellas.
#23 gav240z
gav240z
    Administrator
  • 12,944 posts
Posted 16 May 2009 - 02:48 AM
This is why I decided to travel OS for a while instead of continue with my L31 build. I realised how expensive it is to do it right. Plus to be honest I'm not sure I want to blow all that money on an L-series engine straight up.
I'm thinking of learning to build an engine on my own first, take a block apart, prep it clean it up, balance it a little, even give porting and polishing a go myself. Stick a mild cam in it and put the Triple Mikuni's on it, have some fun but keep it relatively tame.
I kind of want to build a real junkyard motor, that is a motor built with cheap parts in a junkyard and just see what I can achieve from it in terms of power and drivability. A well sorted L28 can be pretty damn quick.
I already have L14 rods and LD28 crank (thanks to Nzeder for completing my set of L14 rods). However the more I think about it the more I want to build something a bit different like an L24 with L28 crank :). Plus for me there's other areas of the car to attend to, such as the bodywork, brakes, suspension, interior.
Not trying to put anyone off, just putting it out there that a monster L28 is great but to be honest very expensive. Plus I'm the type that likes to learn (do it myself) and do things on a sensible budget.
#24 NZeder
NZeder
  • 2,292 posts
Posted 16 May 2009 - 05:51 AM
thanks to Nzeder for completing my set of L14 rods.
No problems - I keep my eye and ear to the ground on the hunt for more all the time too :)
That would be a L26 you are after then - same block P30 code, L28 crank and 83mm bore only different is the block is notched for the larger exhaust valves of the L26 E88 head = this is what you want anyway just get a L26 engine and be done with it.
Now if you were thinking a L28 with a L20a crank then you are talking different. Displacement would be around the factory mark at 2.4l but with a much shorter stroke of 69.7mm vs the 73.7mm of the L24 but with the larger bore of 86mm vs stock L24 at 83mm should rev hard.
#25 stevo_gj
stevo_gj
  • 1,561 posts
  • Tagline:Steve
Posted 16 May 2009 - 09:22 AM
Wouldn't it be sweet if we had enough Zs in Aus to buy a cheapo one as a 'budget' racer the same as those guys (i think swiss?) in that top gear episode who build race cars to a set budget (say $3K) and if someone offers to buy the car at the end of the race they have to sell it for $3K.
That would be such a good way of learning to how to build your own motor, and you could experiment as much as you liked.
I visited Josepf's house the other day and he had the the head out and was in the process of bolting the carbys and exhaust manifolds back on, made me crave to have a project Z.
#26 gav240z
gav240z
    Administrator
  • 12,944 posts
Posted 16 May 2009 - 09:41 AM
No problems - I keep my eye and ear to the ground on the hunt for more all the time too :)That would be a L26 you are after then - same block P30 code, L28 crank and 83mm bore only different is the block is notched for the larger exhaust valves of the L26 E88 head = this is what you want anyway just get a L26 engine and be done with it.
Nah I was thinking of using the original L24 block that came with the car from the factory. The original owner still had it and was throwing it out on ebay. I picked it up from him and have it in the garage. I still want to build the L31 but I figured I'd practice by building up the original L24 first and see what I can do with it.
Like I could use L24 rods with the L28 crank in the old L24 (P30) block. Then fit some slightly oversize pistons. Stick an early E88 or E31 on it and do some port work valve work, then stick the Triple Mikuni's on it with a wild camshaft. Keeping it original and matching numbers.
Then again maybe I'm just being too romantic about it. Hence the reason I decided to travel, I couldn't make up my mind properly and I didn't want to blow all my coin on an engine yet. I guess I was thinking along the lines that I had most of the parts I needed already and may as well use them to build that engine. Otherwise I'll be waiting several years to finish the project.
#27 gav240z
gav240z
    Administrator
  • 12,944 posts
Posted 16 May 2009 - 09:43 AM
Yeah it can be good fun alright. Its not fun when its off the road for a long period of time though. As much as I miss driving the Zed, I do miss having something to tinker with and work on. There is a certain satisfaction from taking something run down and crap and turning it into something wonderful again.
#28 .
  • 1,083 posts
  • Tagline:Past member
Posted 16 May 2009 - 04:28 PM
I agree with the principle. Racing on a budget is fun. But theres no need to wait for a 3K category. You just have to set your own budget and be diciplined enough to stick to it. It also means putting yourself up against oponents with a similar car or budget and ignoring the hords that seem to have endless bank accounts.....You just can't compete against those cars.
#29 Sirpent
Sirpent
  • 2,294 posts
  • Tagline:John.O.
Posted 18 May 2009 - 08:53 PM
Guys
I know this should be posted in the Ebay thread but I note some of you are chasing this item based on the thread..............
L14 Rods
http://cgi.ebay.com....:0|293:1|294:50
#30 gav240z
gav240z
    Administrator
  • 12,944 posts
Posted 18 May 2009 - 09:58 PM
Guys
L14 Rods
Thanks, can't hurt to have some spares. With 4 more I can complete 2 sets.
#31 Cdr Zero
Cdr Zero
  • 454 posts
Posted 18 May 2009 - 11:20 PM
I heard you can use Honda pistons instead of L24 ones, KA24 I believe?  Any pros\cons to this?  (could be rods I'm thinking of, not sure)
#32 gav240z
gav240z
    Administrator
  • 12,944 posts
Posted 19 May 2009 - 03:05 AM
From Wiki Wiki Wa Wa Pedia :)
LD28
The LD28 is the diesel-version of the L28 engine.
Applications:
    * Nissan Gloria 430 and Y30
    * Nissan Cedric 430 and Y30
    * Nissan Laurel C31 and C32
    * Nissan Skyline C210 and R30
    * Datsun 810
[edit] L2.9 ~ 3.2
When fitting an L28 with an LD28 crankshaft with standard bored cylinders it increases the engine displacement from 2.8 L (2753 cc) to about 2900 cc. It was never actually produced by Nissan but it is a very easy and common modification to the L28 done by many Skyline and Z car enthusiasts. The most popular modification is the 3 mm overbored(89 mm) L3.1 liter(3096cc) some add a turbo or two, but the more common settup is the triple Solex or Weber carburators. The only downside is that it is very hard to find an LD28 crank in good condition but fully counterweighted 83 mm stroke and even 85 mm stroke cranks can be bought from aftermarket companies such as Crower.
Without increasing bore size, fitting an L28 with the longer stroke LD28 crank will only result in 2.9L. In Japan and other parts of the world the popular "poormans mod" was the 3 mm~ overbore using the 89 mm ~ 90 mm Honda FT-500 / XL-500 motorcycle pistons along with the L14 rods. The real poorman would use the much cheaper/heavier 89 mm FJ20 or even KA24 engine pistons. All of these cast pistons and had low endurance and would often fail when subjected to high compression and advanced ignition timing compared to custom forged pistons from makers such as Arias or other forged pistons.
I like that description 'the real poorman'. I think the Honda PFT-500 / XL-500 motorcycle pistons would be much lighter than the heavy KA24 ones.
#33 gav240z
gav240z
    Administrator
  • 12,944 posts
Posted 19 May 2009 - 03:11 AM
HKS Surgetank anyone?
http://page2.auction...6024#enlargeimg
#34 waxhead
waxhead
  • 533 posts
Posted 19 May 2009 - 06:45 AM
That looks good
i think i would rather this intake however
http://page18.auctio...ction/w22992624
#35 Cdr Zero
Cdr Zero
  • 454 posts
Posted 19 May 2009 - 07:39 AM
Thanks for the info about KA24 pistons gav  :)
Google translate gave me this on the surgetank:
HKS is a surge tank. The attachment is used to SOREKKUSU, I come up hard goods. I KYABUTABO also be used for OER SUPOTSUINJEKUSHON. NA SOREKKUSU might look good with INDAKUSHONBOKKUSU instead. I have seen KAKKOYOKATTA the past. State is cracking, and cracks. For long storage period, there have been things such as internal corrosion of aluminum. I'm going to clean it a little shake if the BURASUTOMEDIA. There are no mounting screws,
NOKURE, please NORITA.
Please feel free to question. We also exhibited, please see if you like.
Cracks and internal corrosion don't sound too good, and it's 51,000 yen already! :(  Wonder if it's worth breaking in to the piggy bank for.
Edit: And now I see the end date was May 18 2007. :( :(  Oh well, at least my money is safe I suppose...
#36 gav240z
gav240z
    Administrator
  • 12,944 posts
Posted 19 May 2009 - 10:30 PM
I managed to grab another set of L14 rods. So I now have 12 in total. Enough for 2 sets of 6 or 3 sets of 4 :).
These don't come up very often at all. So when they did I had to grab them.
http://cgi.ebay.com/...em=390051335307
To me these are much harder to find than an LD28 crank.
#37 Neuby
Neuby
  • 290 posts
Posted 20 May 2009 - 07:16 AM
Spool conrods have been making L28 rods for a while now and I enquired a while ago as to getting a set of custom rods made up to L14 length.  There is a minimum 36 rod order limit.  :'( I thought I would mention this while people are talking about the honda piston/L14 rod combo.  Spool conrods are cheaper per conrod than it is to fully prep the standard ones.
#38 fufu
fufu
  • 423 posts
  • Tagline:NO NO NO!
Posted 20 May 2009 - 09:01 AM
I was only thinking about that just a few days ago, spool with L14 rods and they could mas-market it around the world.
Anyway spotted some stuff in Japan auction related to 3.1L stroker engine.
First off we have a LD28 Crank that has been warp corrected, journal lapped and balanced:
http://page6.auction...ction/f80384857
Tomei adjustable sproket
http://page13.auctio...ction/r55223670
Kameari conrods with ARP studs
http://page8.auction...tion/h130051636
Kameari 89mm pistons
http://page13.auctio...ction/r55509277
lastly,
Kameari cam 77 degree G model
http://page.auctions...ction/118500164
#39 Sirpent
Sirpent
  • 2,294 posts
  • Tagline:John.O.
Posted 20 May 2009 - 09:20 AM
Good to see my Ebay trolling past time payed off for you Gav, now if you come across a complete set or 260Z 2 seater door trims/cards (genuine SH) in your travels a heads up would be appreciated........... ;)
#40 sexual_sushi
sexual_sushi
  • 1,298 posts
Posted 20 May 2009 - 09:23 AM
i think edii just posted that they are available from nissan
http://www.viczcar.c...icseen.html#new
edit: oh just saw the genuine SH thing.....
