. Posted April 22, 2009 Share Posted April 22, 2009 I realised the other day the EFI plenum I have on my L28 in my 240z is smaller than the plenum on my 280zx. Anyone got any thoughts on the result this would have? I have a spare one in the larger size but I son't want to swap it all over if it isn't going to have a benefit. Let me know. Quote Link to comment Share on other sites More sharing options...
RB30X Posted April 22, 2009 Share Posted April 22, 2009 "Apparently" plenum volume should be around the same cc's as the engine displacment. 3L for a 3L engine etc. I'm not sure if this changes with forced induction, or whether that was for forced induction and it is different with na. I believe the length and diameter of the runners effect your torque for an na more than your plenum size. At the end of the day it's not about the size, it's how you use it. Quote Link to comment Share on other sites More sharing options...
waxhead Posted June 4, 2009 Share Posted June 4, 2009 Size does matter http://www.amsperformance.com/pdfs/intakemani.pdf Quote Link to comment Share on other sites More sharing options...
PZG302 Posted June 4, 2009 Share Posted June 4, 2009 There are three or four logs for the L28. There is the standard one butterfly log, a two butterfly log, the turbo log which is a single butterfly, but at 64mm diameter from memory, bigger than the combined area of the two butterfly log, and also the NAPS log which I can't remember the size or number of butterflies. You may also have the log from the L24E, which is different in size again. I have the turbo log on my L30 and the difference in diameter between it and the XF throttle body is less than a mm so not worth doing the mod for the dollars it would cost. Matt Quote Link to comment Share on other sites More sharing options...
kalium Posted August 3, 2009 Share Posted August 3, 2009 I used to have a GTR plenum kicking about and was thinking about how it would go on an L series... Looks like someone else also had a similar idea... Quote Link to comment Share on other sites More sharing options...
waxhead Posted August 3, 2009 Share Posted August 3, 2009 Thats the motor in japan huh I looked at that but man it was expensive Quote Link to comment Share on other sites More sharing options...
kalium Posted August 3, 2009 Share Posted August 3, 2009 Thats the motor in japan huh I looked at that but man it was expensive Yep Pretty spec'ed out motor though. Quote Link to comment Share on other sites More sharing options...
waxhead Posted August 4, 2009 Share Posted August 4, 2009 I missed out on one in japan with itb,s etc on it 'then they offered it to me again because the winner( there bidder) backed out I will see if i can find a pic Quote Link to comment Share on other sites More sharing options...
